3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Hydroxy Gas Generator
Step 5Electrode Materials
Electrode Materials
The material of choice is Stainless steel 316L, failing that you could use 304L or even plain old 304 SS.
The plain 304 is cheaper, but will take longer with the conditioning phase due to the higher carbon content, more about conditioning later.
Seeing as Im using M6 threaded rod and M6 nuts and washers which are only available in 304 grade, I went with 304 tubing too.
The inner tubes are 125mm long, the threaded rod is 180mm long and the outer tubes are 200mm long giving me a 60mm working space for foam, sloshing and whatnot.
2 comments
Jun 3, 2009. 1:50 PMHacker X-13 says:
Where can you get the tubes and rods cheaply?
Mar 13, 2009. 2:32 PMsabre says:
where in the world can you find stainless steel pipe without ordering it?
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
44
Author:petercd
general bloke type of tinkering
