I-Beam Keyring
2,328
16
Published
Introduction: I-Beam Keyring
About: Happy in wood shavings YouTube: http://www.youtube.com/c/WOmadeOD Patreon: https://www.patreon.com/WOmadeOD
The best design is often the simplest - and it doesn't come much simpler than this I-Beam Keyring
You'll find it hard to loose your keys again!
Here's how I made it...
Oh, and a video is also available here
Step 1: I-Beam
The I-Beam is a rolled steel joist (RSJ), which you can purchase from building supply merchants, but you don't need much so try local steel fabricators and builders, who will often discard cut-offs.
They come in lots of sizes, so just pick one that will suit your needs - small enough to fit in a jacket pocket is good.
Step 2: Cut to Width
Now comes the hard part!
A metal fabricator will cut you off what you need (about 3/16", 10mm) for a fee, but if you have a hacksaw then you can do it yourself whilst getting a workout
I used a table saw, with a tungsten carbide tipped (TCT) blade made for both wood and metal. A regular TCT blade will probably cope okay, although it won't be much good for cutting wood afterwards! I cut slowly, with shallow passes through the top and bottom of the 'I', and then held the beam over the blade and raised it slowly to finish the cut.
WARNINGCutting with a powered saw produces a lot of sparks - These are extremely hot little fragments of metal and will embed themselves in clothes and flesh, etc. Keep a guard between yourself and the action, and wear safety glasses, breathing and ear protection.
Step 3: Filing
Cutting will leave surface marks and sharp edges
The quickest way to deal with these is to use a sharp file
Work on the cut surfaces first, then ease the edges a little
Make sure there are no sharp edges before moving onto sanding, as they may cut through the sand paper
Step 4: Sanding
Sanding is optional really, since all the sharp edges should have been remove by now
You can work through finer and finer grits of sandpaper to achieve the finish you want
You could even move onto metal polish and take it to a mirror finish
I left the cut surfaces a satin finish by sanding down to 240 grit
I also left the uncut surfaces altogether, for a more industrial look
Step 5: Finishing Up
When it's looking how you want it, then you can install a plain keyring ring
For a little protection against rust, I've applied some furniture wax
Thanks for reading my Instructable, I hope you enjoyed it.
Now watch the video:
https://youtu.be/ElMmE8y8SAk
Cheers, Mitch
    • Oil Contest
      Oil Contest
    • Woodworking Contest
      Woodworking Contest
    • Casting Contest
      Casting Contest
    2 Comments
    It would be cool if you gave us some action pics, like maybe showing what it looks like in your pocket, you unlocking a door with it attacked to the key ring, maybe even as a paper weight.
    I could see this having potential as a. real tool, maybe as a self defence tool? Cut a slot in it to make it a functional beverage opener?
    This would be great as a pass along gift to your son, and then to grandson. Maybe engrave your name into it?
    I'm considering making myself one now, maybe I'll drill a hole in a corner and put the keyring in that for a different look. Maybe even drill lots of holes for a skeleton I beam slice.
    Thanks for sharing this with us, I'll have to try it out!
    Some good ideas there, thanks. I have a few myself, so I can see another instructable or two to follow up on this! Cheers
