Step 3Add the water, heated to 130 degrees F, and beat
Heat the water to 130 degrees F using a thermometer.
Add to flour mixture and beat several minutes.
Note:
once you know how many minutes it takes to get water to 130 F
in your microwave you won't have to use the thermometer.
Mine takes about 3 minutes for 2 cups of water.
Too hot water will kill the yeast, to cold will not activate the yeast.
this is known as easy mix method, and you are not adding the hot water directly to the yeast so 130F will not kill the yeast. If proofing yeast alone directly with water then use water at 110-115F.
comment
Add Comment
Add Comment
