Step 2Start Cuttin Cards..
and marked off where the spot for the ipod to go,
then I started using the exacto blade to cut out the rectangles.
After a while this got very tedious so i pinched the stack with vice grips and taped up all the sides
so they wouldnt move. then i started using the dremel tool with a tiny saw bit on it.. that did the trick.
KEEP test fitting the Ipod to make sure you dont remove too much material.
One your done that use double faced tape to stick the back onto the stack..
Now that the Stack will stay put, use the knife or dremel to remove the headphone hole at the bottom of the pack.
I Then made one more card without a center to cover the headphones hole over..
Add Comment
