I built this bike trailer by zymie
Featured
I built this bike trailer out of an old jogging stroller.
Step 1: The Hitch Mechanism
Hitch mechanism made of 3/4" flat stock and a Quick Disconnect Type 3/8-24 Fine Standard Thread Ball Joint and Rod End. http://www.amazon.com/gp/product/B002HAUWCM/ref=oh_details_o01_s00_i00
$18 with shipping
I made some teflon washers to go against the bracket and tightened the backnut against the joint to allow a little slack for y-axis movement of the arm beyond the ball joint movement.
DeeRilee says: Feb 7, 2013. 7:09 AM
great job!!!!!!
I love repurposing & recycling!
Dale_D says: Dec 30, 2012. 6:36 AM
Forgot to ask, what is the black bracket looking thing between the wheels? Is it part of the stroller wheels?
zymie (author) says: Dec 31, 2012. 12:08 PM
Yes, I used the jog stroller axle and part of the frame. I need to take some pictures of the underside.
gnach says: Dec 30, 2012. 11:02 AM
How well does it track when turning? I see that it isn't rubbing the tire in the last image but what about while rolling?
zymie (author) says: Dec 31, 2012. 12:06 PM
It tracks well. I was careful when I measured the mounting arm to make sure the trailer ended up centered behind the back tire. I've made some fairly tight turns without any rubbing.
Bradinsc says: Dec 30, 2012. 11:51 PM
Great plan! I have a set of wheels like that, and some time on my hands....... I am going to make a similar cart for the back of my power wheel chair! That will help with shopping with the wife for sure! Thanks for the great idea! I like the hitch idea as well.
onemoroni1 says: Dec 30, 2012. 11:16 PM
Good simple re-purposing. Good job.
Spokehedz says: Dec 30, 2012. 9:24 AM
Shiggy Diggy
Dale_D says: Dec 30, 2012. 6:33 AM
Great project & nicely done! I need to build a trailer for myself too. I have a set of 20" bicycle trailer wheels, but I like the smaller jogging stroller wheels better.
Here is another resource for parts like the ball joint:
http://www.mcmaster.com
I found some on their that would have cost you less, but you have to watch out for their shipping. Some were made of Stainless Steel (& shielded), and they have one that doesn't need lubrication as well (won't squeak?). Maybe some upgrade possibilities?
shumphrey1 says: Dec 27, 2012. 8:46 AM
Love it, simple, easy to do by most with a bit of diy savvy!!! ;)
eyesee says: Dec 27, 2012. 4:31 AM
good
jawasan says: Dec 22, 2012. 7:41 PM
I like the hitch. Nice.
zymie (author) says: Dec 24, 2012. 7:55 AM
Thanks, I found that hitch after scouring Google for a simple solution. If I can find the original source I'll try to add the credit.
rimar2000 says: Dec 21, 2012. 6:23 PM
Very good design, your hitch mechanism is far better than mine. Simpler, easier to use. Maybe I will copy it.
Your trailer project is very detailed! I found that hitch after scouring Google for a simple solution. If I can find the original source I'll try to add the credit.
jessyratfink says: Dec 21, 2012. 2:16 PM
It looks great. Very clean. :D
zymie (author) says: Dec 24, 2012. 7:53 AM
Thanks!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
