loading
I built this bike trailer out of an old jogging stroller.
Step 1: The Hitch Mechanism
Hitch mechanism made of 3/4" flat stock and a Quick Disconnect Type 3/8-24 Fine Standard Thread Ball Joint and Rod End. http://www.amazon.com/gp/product/B002HAUWCM/ref=oh_details_o01_s00_i00
$18 with shipping
I made some teflon washers to go against the bracket and tightened the backnut against the joint to allow a little slack for y-axis movement of the arm beyond the ball joint movement.
Step 2:
I made the mounting bracket from a zinc plated strut pipe clamp- $0
Step 3: The Tray
The wheels and from were from a jogging stroller that had been decaying in the back yard. The box is a spare drawer from our kitchen remodel. $0
Step 4: Tubing
The tubing was from the jogger handle. -$0
 I used stainless deck screws to fasten the tubing to the tray.
Step 5: In use
The trailer loaded with 5 bags of ice, 12 pack of soda, and some misc groceries.
great job!!!!!! <br> <br>I love repurposing &amp; recycling! <br>
Forgot to ask, what is the black bracket looking thing between the wheels? Is it part of the stroller wheels?
Yes, I used the jog stroller axle and part of the frame. I need to take some pictures of the underside.
How well does it track when turning? I see that it isn't rubbing the tire in the last image but what about while rolling?
It tracks well. I was careful when I measured the mounting arm to make sure the trailer ended up centered behind the back tire. I've made some fairly tight turns without any rubbing.
Great plan! I have a set of wheels like that, and some time on my hands....... I am going to make a similar cart for the back of my power wheel chair! That will help with shopping with the wife for sure! Thanks for the great idea! I like the hitch idea as well. <br>
Good simple re-purposing. Good job.
Shiggy Diggy
Great project &amp; nicely done! I need to build a trailer for myself too. I have a set of 20&quot; bicycle trailer wheels, but I like the smaller jogging stroller wheels better. <br> <br>Here is another resource for parts like the ball joint: <br>http://www.mcmaster.com <br> <br>I found some on their that would have cost you less, but you have to watch out for their shipping. Some were made of Stainless Steel (&amp; shielded), and they have one that doesn't need lubrication as well (won't squeak?). Maybe some upgrade possibilities?
Love it, simple, easy to do by most with a bit of diy savvy!!! ;)
good <br>
I like the hitch. Nice.
Thanks, I found that hitch after scouring Google for a simple solution. If I can find the original source I'll try to add the credit.
Very good design, your hitch mechanism is far better than <a href="https://www.instructables.com/id/Foldable-bike-cart-carrito-plegable-para-bici/#step12" rel="nofollow">mine</a>. Simpler, easier to use. Maybe I will copy it.
Your trailer project is very detailed! I found that hitch after scouring Google for a simple solution. If I can find the original source I'll try to add the credit.
It looks great. Very clean. :D
Thanks!
About This Instructable
22,373views
152favorites
License:
More by zymie:I built this bike trailer
Add instructable to:
