The Project
I am trying to build a circuit that will allow gadgets that are usually charged by USB to be charged wirelessly. As an example I am reverse engineering an A4tech battery-less mouse. However it is too great a challenge for me and I am seeking help from you. I thought it would be better for me to turn this into a group effort than to ditch the project. I will give a detailed description of what I have built and learnt and hopefully you can tell me where I went wrong.
Remove these ads by
Signing UpStep 1: Background Information
The mouse I was talking about (see other picture) in the introduction is exactly the same as the Splashpad it uses induction to transfer power across an air gap. This is the same technology as RFID; in fact it uses this to communicate with the pad. To make our own wireless device we need to know more about induction.
Visit Our Store »
Go Pro Today »
or
.00018 uF
here's a handy link:
http://www.electronics2000.co.uk/calc/capacitor-code-calculator.php
Also, how did you wind such nice coils?
4 pegs and a pegboard
4 pencils and two friends
A very well-trained cat
...basically anything that has the ability to have four rectangularly spaced supports ought to do the trick
BTW, if you try to run the car with the two 9V batteries, they will get hot because of the power dissipated in the internal resistance.
There are these car starting packs that you can buy that are very small, and put out a very high current because their internal resistance is very low. Thus they are able to turn over the engine and start the automobile.
You say throughout the instructable that you want a high frequency. For an inductive coupling application, however, high frequency is not a good thing. To fix this you could try adding a capacitor in series with the coupled signals, as sort of a filter. You could also try lowering the frequency.
PLEASE!
Would increasing the voltage and number of coils on the primary also provide a marked improvement?
Anyone has infomation on how to determine the mutual inductance or coupling factor? And also the equation to determine the inductance of the coils?
hope if anyone can help me :(
rgds
alex
M=N1*N2*Phi=K * (L1*L2)^.5
where N1 is the # of turns on the primary, N2 is the # of turns on the secondary, and Phi is the permeance of air.
From this you can extract K, the coupling factor,
K= (N1*N2*Phi) / (L1*L2)^.5
As for determining the inductance of the coils, if you do not have a multimeter or some other device to measure this, you can sweep the frequency on a frequency generator looking at the voltage across a parallel cap and your coil. The peak voltage is then related to 2*pi*f = 1/(L*C)^.5
also, where is the power regulation for the mouse?
why not sine wave ?
What is you simply had an wall wart that supplied 9VAC after it conevrted the '120 VAC. Then run a transistor so the 555 timer, turns the Wall Wart on and off at 120 kHz, providing you with the 120 kHz square wave, AC signal at 9VAC
Does anyone here know more about this? It seems to me that a magnetic field, unless it was really, really strong, would not be able to do this kind of thing.
can you not simply use all the stuff from the mouse to power it?
OH also i just remembered, you can buy cheap electric toothbrushes that use inductive charging. they have 2 AA batteries in them that charge through it.
one thing you may be able to do is what i am currently doing, use a dc/dc converter to up the voltage going into your primary circuit.
this instructable
http://www.instructables.com/id/A_high_power_LED_torch_using_a_single_AA_battery/
is the one i am using, also just look around
http://www.rmcybernetics.com/projects/DIY_Devices/homemade_pulse_controller.htm
I'm really exited now and for your info, my supply is just only 9V battery....
To increase the voltage output at the secondary, i just increase my supply voltage..
Once again, i don't this this circuit is using the resonance effect..
Thanks...Hope This can help you..
TQ
NE555 timer tech page: http://www.uoguelph.ca/~antoon/gadgets/555/555.html
The problem seems evident to me as the following:
The vibrator circuit cannot reach the frequency that might become helpful with this project. This is how TV flybacks work. At 25kHz, you can use only about 3-5 turns of 18AWG wire around a 10mm core and induce 12VDC on that coil, where as static DC would be a direct short. The balance is that higher frequencies degrade to a larger degree in an air-core transformer, so you need to make your switching speed higher, but also increase the efficiency of your transformer.
If you need a few ideas, take apart the head motor of a VCR, noting the contactless coupling between the heads and the drum itself. Magnetic fields decrease by a factor of 4 per distance. For example, if the field is (x) gauss at 1mm, it will be 1/4 of (x) gauss at twice the distance, and continuing exponentially by a factor of exponential decay.
I dunno if this helps, but I hope it at least inspires some thoughts/ideas with you....good luck.
I have read faraday's own laws on mutual inductance and you can see it here Laws of Mutual Inductance
and they clearly state
The magnetic flux through a circuit can be related to the current in that circuit and the currents in other nearby circuits, assuming that there are no nearby permanent magnets.
My newman motor works from permanent magnets, so I know its not any standard form of mutual inductance but i sure do get a huge back emf and back spike up into the 100's of volts from just 12v input.
Bill - TheNerdGroupTheNerdGroup
good waves:
http://www.sc.ehu.es/sbweb/fisica/elecmagnet/induccion/variable1/fem1_3.gif
bad waves:
http://www.sc.ehu.es/sbweb/fisica/elecmagnet/induccion/variable1/fem1_2.gif
Inductor is another name for a coil. The voltage across an inductor equals its inductance in Henrys times the instantaneous rate-of-change of current through the inductor in Amps/s. The coil's inductance is a fixed property of the coil once you've made the coil. It's the second factor--the rate-of-change of current--you can change. How? -- By increasing the frequency you apply to it.
Do you have access to an oscilloscope? If you do, you can measure the frequency coming out of your 555 circuit, measure the voltage across your coil with a voltmeter, then divide to find your coil's inductance in Henry's. Then, using the same equation, you can figure out what rate-of-change of current you need to get a desired voltage across the coil.
Oh and I may not have made it clear. I'm not actually running it from the USB port. I'm using a stepdown transformer. From mains to 6VDC, max 800mA.
I had a look at the datasheet of the transistors I'm using. Does this have anything to do with the max switching speed?
High Current Gain - Bandwidth Product -
fT= 2.0 MHz (Min) @ IC
= 500 mAdc
On your diagram from step 10, you have those two 3.9 ohm resistors across Vs+ and 0V in series. The resistance of resistors in series are additive and thus 3.9 ohm + 3.9 ohm is 7.2 ohm. Using ohm's law, V=IR we find the current:
6V = I * 7.2 ohm
I > .833 Amps
thats over 833 mA
You said your power supply was 6VDC max 800mA, so there is basically a short across the Vs+ and 0V across these resistors. The resistor should be really be hot since 6VDC at 800mA is 4.8 Watts dissipating through these resistors. Voltage dividers are not meant to drive large loads. Their outputs are meant to be amplified.
I think I am gonna do something like this for my ap physics class, so if you want to collaborate PM me your email or IM, I don't usually check my instructables account.
6V = .6A * R
R = 10 ohm
yeah use them 10 ohm or higher
on designing an RFID system. Might have some pearls in it.
Good luck!
Here's the link:
http://www.edn.com/article/CA6501085.html?text=power+transmitter
Hope this helps! Ever since seeing the article, I've been considering trying this out for myself.
It also uses an IC555 and comparator circuit to generate a pulse signal. It can also be use as a coil driving circuit......MOSFET i think is the best component that produce the efficient switching signal...
I don't want to go into the technical details, but here are my suggestions which you can try out easily.
1) The coil might need a higher frequency to resonate. Probably in the megahertz range. (Again, this is just my hunch).
2) The power amplifier circuit I see might not give you enough power. Something looks fishy, but I dont know what exactly.
Try wiring the coil as a flyback convertor, with a simple feedback coil. The circuit will be much simpler and the frequency can be much higher. See the link below for example.
http://www.powerlabs.org/flybackdriver.htm
The transistor in this circuit can be replaced by any decent NPN power transistor. Althought the circuits shown use ferrite cores, it should work with air cores too.
I have to go now, I'll try to add more details as soon as I get home.
http://bea.st/sight/levitation/
Mike
If you want to consider an RLC model consider the Parallel RLC model, not the series RLC model. I don't have the time to think about it now, but it may help.
In a parallel RLC circuit you get the maximum reactance at the resonant frequency.
http://hyperphysics.phy-astr.gsu.edu/hbase/electric/parres.html#c1
Or I may be completely wrong and not know what I'm talking about.
I'll admit that I haven't read your entire project (yet)... But this was the first thing that came to mind - not sure if it will help as it is a slightly different concept ;)
I am not entirely sure about the theory but maybe a this may help: http://www.evilmadscientist.com/article.php/joulethief
The device steps up voltage using a home made toroid.
Good luck with it!
