IA-14
318
Published
Introduction: IA-14
About: I.E. Innovation Engineering
After a long time, I finally have a new post!
IA-14
I.E. Assault rifle 2014
This build stemmed from a long desire to build a fully functioning bolt action rifle, mainly after seeing red's R5.
My main aims were to make it as compact as possible (as I have very little pieces) and to have decent power. This has resulted in two by products: a new compact trigger system and a new and easy to use rail system.
Pictures 6-10 show how the rail system works
Originally, this was meant to fire grey connector + green rod ammo, a favourite ammo of mine, but I found that ammo impossible to chamber, so I used blue rods instead, another one of my favourite ammos
Anyway, onto pros and cons:
+powerful
+has a long pin pull
+fires blue rods
+decent mag lock
+comfy
+decent rail system
-doesn't look great
-could look better with a longer fake barrel (I can't make it longer due to lack of pieces)
-low capacity mag (that's due to the size of the internal pusher I have, but it can be easily changed to have a smaller one)
Don't forget to favourite, comment and subscribe.
I'm open to any constructive criticism and suggestions
    • Oil Contest
      Oil Contest
    • Clocks Contest
      Clocks Contest
    • Casting Contest
      Casting Contest
    12 Comments
    No problem! What in particular do you like about it?
    It's hard to say as I don't have any open space to test it in, but I would say its range would be similar to the ISR-S3 which headlessknight got 90ft with
    Thanks, but this isn't my first bolt action as I had done my bbr-v1, but quite frankly that was awful and didn't work, so we shall never speak of it again
    Well I guess you go by this quote then,
    "If at first you don't succeed, destroy all evidence that you tried!"
    =D
    Only if it is as bad as that attempt!
    Thanks!
    Thanks
