IBC Tote Kiddie Pool
25,719
230
12
Posted in OutsideBackyard
Introduction: IBC Tote Kiddie Pool
About: I have an insatiable drive to build, so I will share my experiences with everyone.
IBC stands for intermediate bulk container.  These containers can range from 275-325 gallons and are mainly used for industrial chemicals. The IBCs used for industry are classified as returnable (re-usable) and non-returnable (disposable).  I work in industrial water treatment and we go through several non-returnable IBC totes a week.
My coworkers and I have come up with some creative uses for these containers and I will share some of my best ideas here on Instructables.com.  I will share some of my coworkers ideas as well with their permission.
Now, I present to you the IBC tote kiddie pool!
Father's Day Contest
Finalist in the
Step 1: Materials and Tools Needed
1. You need to get your hands on a tote.  For some, this will be easy.  For others, it will probably cost you.  I see totes on Craigslist for free (rarely), but usually they sell for $25-$50.  Well, that is the asking price.  If you are patient, or know someone that works in water treatment or possibly a beverage plant, you may be able to score one for little to no money at all.
The picture above is just a representative of an IBC tote.  It is not the tote I used nor should it be.  Make sure the tote you use previously stored relatively mild chemicals.  Clear and non-staining chemicals are obviously preferable.  The totes I use contained food-grade citric acid that rinses out completely after a couple of flushes.
2. Sawzall
3. Pool noodles will be used to create a protective edging around the perimeter of the pool.  We need 3 of them.
4. Zip ties.  Lots of zip ties. UV resistant is best since this thing will be out in the sun all summer long.
5. Some sort of drill.
Step 2: Cut the IBC Tote
Determine how tall you would like the pool to be.  You will need to use the sawzall with a metal cutting blade to cut just above one of the horizontal metal bands of the tote cage.  I find it useful to use the horizontal band as a guide to cut the plastic inner envelope as straight and flush as possible.  I chose the lowest rung since this pool is for a 3-year-old and I want him to be able to get in and out on his own.
Step 3: Split the Foam Noodles
This one is simple.  Use a sharp knife to split the foam noodles down one side only.  That way you will be able to slip it around the wall of the pool.
Step 4: Start Wrapping the Pool Edge
Spread open the noodle on the cut side and slip it over the edge of the tote.  Keep working around the tote until the whole perimeter is covered.  There will be some overlap at the end.  I would leave the overhang and cut it after everything else has been secured.  Try to make sure the seams meet somewhere between 2 vertical rungs. This will make it easier to lock the ends down real well.  Also make sure the ends do not meet on a corner.  The curvature of the corner makes it difficult for the ends to meet up flush.
Step 5: Drill Holes and Apply Zip Ties
I used a 3/16" bit and drilled a hole centered between each of the vertical rungs. I also drilled extra holes in the corners (you will need extra strap support there) and about 1/2 inch back from each noodle end (like the picture above shows).
Run the zip ties through the holes, making sure the "head" of the zip tie is on the outside of the pool.  Cinch it down pretty tight, but not so tight that you begin cutting into the foam.
I chose not to cut off the excess zip tie because I felt it may create a sharp edge and the whole point of this exercise is to eliminate sharp edges to protect my kids.
Step 6: Complete. Enjoy Your New Pool!
Maybe rinse it out one more time, then fill it up.  This particular pool I built holds about 75 gallons of water.  The ball valve at the bottom makes draining a cinch, plus it has a 2" cam lock fitting on it so you can adapt it to a hose to route the water wherever you want it to go.
Total cost of this build:
IBC tote: Free
3 pool noodles: 1.88 x 3 = 5.64
1 package of zip ties: 7.99
Total: $13.63
Your cost will vary depending on how you get your tote.  You can also buy a smaller package of zip ties for less money.  I just like to get the big pack because there are ALWAYS uses for zip ties around the house.
I hope this Instructable was useful and I will update it from time to time if I make any improvements or upgrades.  Thanks for reading!
  • Pocket-Sized Contest
  • Spotless Contest
    Spotless Contest
  • Trash to Treasure
    Trash to Treasure
12 Comments
Nice work! I would make sure to anyone looking to buy ibc tanks to make sure you get a potable tote and ask for the SDS sheets. I would some good deals at craigslist.com, http://www.containerreclaimer.com and http://www.ibctoterecycling.com/used-ibc-containers-for-sale/
WHERE WOULD I GET A I.B.C. FOR FREE THANK'S [ VLAD ]
lol I made one of these two years ago here in QLD Australia see pick, good to see someone else has had the same idea all I can say is that mine is still going strong I stuck the Foam noodles down but I think strapping them the way you have would be a better way.
It would make a great outdoor planter or semi raised garden for people who live in apartments!
Where could I get one of the IBC totes???
What a great concept. Now another thing to add to my "To do" list!!!
Thanks for posting!
KEn
This is an awesome idea!! I didnt know they were so cheap I want to make a hot tub now!!
Ein Kinderspass für kleines Geld Super!:-))
This is great, i got this idea for a long time to make a hottub out of 2 IBC containers, i can buy them in 1000liters version 120*100*80high, i would cut the top, keeping the totes some 70 cm high, (28 inch) cut a side of both , than try to weld them back together.
That would give me a 120*200 cm- 47*70 inch by 28 high hottub.
My only fear is that the waterpressure will be so high, that the weldlines will pop open again.
You any experience in joining 2 tubs , or more, welding, glueing, rivetting, whatever holds them together.
The foam on the top edge is an idea i have to keep in mind,
great, keep 'em comming
I am working on the hot tub right now. I know that it is possible to weld the plastic bladder, but I have not tried it yet. My design uses a single tote and it will be more like a Japanese soaking tub. It will comfortably seat two as long as you don't mind rubbing elbows (or knees, etc.) with that person :)
Good job, can't wait to see the other uses
