3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
ICY PAK LAPTOP COOLER!!!! CHEAP
Edited April 6th 2011. Alright. Been a couple of years since I wrote this instructable. So, I'm going to revise it using correct grammar and changing it abit so you can understand it more clearly then when I typed it out when I was 11/12 years old.
So anyways, I originally, had my father's laptop the overheated quite often when running games on my laptop. So I had to think cold, and thought of the hot/cold packs that contain the blue gel and thought of a way to somehow have the laptop intake be able to take the cold air from the packs to cool down the laptop.
OK......Just to let you know. Im 12.....so I play lots of games on the Computer. And I have a laptop. But it keeps overheating...so........I needed a cooler for a laptop fast. The store ones cost to much or suk..so I I thought...think cold.....think cold....and thought of this. http://www.instructables.com/id/Laptop-cooler/
Step 1Stuff
Stuff
Edited April 6th 2011: Laptop. Hot/Cold gel packs, a large zip lock bag.
The stuff you need is: A laptop that has problems overheating, ice packs, and a large ziplock bag.
108 comments
1-40 of 108next »
Jan 6, 2008. 3:56 AMTangMu says:
Anyone else worried about the moisture this setup would attract? or would it be negligible O_O
Oct 18, 2009. 12:10 AMEleriK says:
I'm not sure if this would actually work but it makes sense in my head and I hope a smarter instructableser can say if it will or not, but why not use those silica gel packets. Or make your own thin one and put that between the fans and the laptop.
Of course when I did this I used a piece of absorbent paper-towel and that laptop worked fine for years.
Aug 6, 2011. 5:29 AMmichaelcozens says:
I'm not sure the instructable as described would create too many problems with humidity. Since the icepacks are sealed in a ziplock bag, any moisture gathering on the outside of the bag was present in the room air as humidity anyway, and thus was already making its way into the computer. If anything, I would think that this method would lead to less humidity inside the laptop itself, as a good portion of that moisture would be condensing on the ziplock bag before entering the computer's air intakes.
Still, probably a good idea to keep a towel between the bag and computer, and regularly change it out when it starts to get damp. Water does tend to evaporate upwards.
Apr 22, 2011. 5:25 AMdudenitx says:
sorry,,,, sir,
but i had to mention this... it is quite a risky affair.... u cant just use it always ... it will lead to moisture or humidity intake within the lappy.... so ... just have to find other way,,,
well but a good approach.. u r just near... think of something relly awesome..
Jul 15, 2010. 8:25 AMfaizyuki says:
hey you all stop showing off your computer spec to the kid he just only want to help people overcome the overheating problem this is not a place for showing off so be mature and stop acting like a punk!
Apr 6, 2011. 7:09 AMbubble_gum_chewing_gum says:
rof! im juz kidding. really this made a thread of pcs = )
Oct 22, 2008. 12:12 AMbubble_gum_chewing_gum says:
(removed by author or community request)
Apr 4, 2011. 6:20 AMjetersaurous says:
ohhhhhhh, you're so cooool!!!
loser
Jun 25, 2010. 12:10 AMjames0071st says:
Must be nice to have parents with nothing better to do with their money!!!!!!!!!!
Feb 17, 2010. 10:29 PMmackintoshlinessless says:
wow you either have a part time job and have been saving for ever :) or your parents are rich :))
Mar 3, 2010. 11:36 PMbubble_gum_chewing_gum says:
Jun 19, 2010. 5:42 PMcomputer_guy says:
forgot to mention windows 7 ultimate 64 bit :P
lols. got my desktop computer when i was 13. custom made. intel core 2 quad 2.83 Ghz overclocked to 3.40 Ghz External 1Tb Internal 250 Gb Internal 200 Gb Internal 80 Gb 4 Gb DDR2 ram Ocz two 17" monitors NVIDIA GeForce GT 240 512 mb GDDR5 ram
Feb 8, 2010. 10:16 PMPeterOrgasmique says:
So which one of your divorced parents bought you that?? Mum or Dad?
It's called WORKING for it...
Kids...
Sep 7, 2009. 5:53 PManarchysk8 says:
lol intel is lame 3.3ghz for $1000 or AMD 3.0ghz for $200 u decide i have a custom made computer with parts i bought on frozencpu.com and directron.com asus m4a79t (only way to go all others are trash) AMD (thats right) pheonom II 955 oc'd at 4.23ghz 2x XfX raedon 4870x2 2gb 8gb ocz ddr3 16000 Liquid Cooling DangerDen block with nzxt rez Feser one 360rad+ 140/with aerocool extreme turbine (80cfm) 2x westerndigital velosciraptor 300gb Razor mouse/keyboard Ultra x3 1600w Windows 7 64bit!!!!!!!!!!!!!!!!!!!!!!! 2x dell cheapo lcd's (dell is alienware and they both are scammers) so anyways dont waste money on alienware when u can get a million times the computing for a tenth the price if u build your self
Feb 17, 2010. 10:31 PMmackintoshlinessless says:
how do you build laptops by yourself? is it like on a website and you check off the different prcessor, hard drive, etc or do you buy each part indiviually
Aug 26, 2009. 4:56 PMjunits15 says:
who cares?
Aug 11, 2009. 9:19 AMbenjgvps says:
Uhg, Alienware. Asus has a better Price/Performance ratio for laptops. Even then, you should just build a desktop that you can easily upgrade. Personally, I built a PC for $750, bought a netbook and then a 9 cell battery for it. The netbook may not be able to run the latest games, though I can play older games just fine as well as carry it around with me for up to nine hours before the 9 cell battery dies.
Sep 7, 2009. 5:59 PManarchysk8 says:
thank you alienware is the biggest ripoff since taxes and i agree with you fully on the asus its way better and the mtbf is way higher (mtbf= mean time between failures) with alienwares laptops having only 30000 hours and asus's newest netbooks have 1000000+hours mtbf
Aug 10, 2009. 5:00 PMGamer917 says:
well i have a 14.1 inch toshiba that has a 6 cell battery, an overclocked (3.0 ghz) intel core 2 duo, Vista Home Premium 64- bit, 4gb DDR2 800mhz ( soon to be upgraded to 8gb), a 330gb hard drive, the battery lasts for 3 hours on high performance settings, AND i'm getting an HP Pavilion Elite for my 13th birthday and it has an intel Core i7 965 EXTREME EDITION quadcore,3.33ghz, 12gb DDR3, a Bluray disc drive, a 23 inch HD monitor, 640 Gb hard drive (i dont believe in having a 1tb drive if you don't edit video alot), a Wifi-N card, Bluetooth, an ATI Radeon 4850 HD 1gb dedicated memory and i might upgrade to ATI CrossFire X cards. BEAT THAT bubble_gum_chewing_gum
Aug 10, 2009. 5:15 PMGamer917 says:
btw the reason im not paying for at least part of my new desktop is because i ran out of money after buying a replacement ipod touch so don't call me spoiled
Apr 18, 2009. 3:37 PMcotton says:
ok thats spoiled
Mar 15, 2009. 5:54 AMHolden_vy_s says:
Alienware? Shoot yourself.
Jan 18, 2009. 6:10 PMelectronicfreak22 says:
Uggghh, you're so lucky I just got a dell Inspiron 1100.. which is pretty old, but I'm "pimping" it out haha and 2TBs? I didn't know you could get that size for a laptop.. I need to update my knowledge:p
Dec 22, 2008. 5:38 PMbengerszewski says:
everythings great except the screen size. if your gonna do gaming, wouldnt you want a big screen? and how much did that cost?
Aug 26, 2009. 5:00 PMjunits15 says:
ty cleaning out the heatsink, that usually is the cause of an overheating laptop, just a word of advice, there is no way in hell you will be able to open your laptop without your manuel, (that is without breaking anything)
Sep 7, 2009. 5:56 PManarchysk8 says:
lol ummm ok i thought normal people can use screwdrivers without the manual but i guess not i did with my compaq when it got dirty but i guess im talented or somthing
Sep 7, 2009. 6:13 PMjunits15 says:
you must hav ahad one that was particularly easy to open. I tried numeroust times with no success until I used the manual. (and it was a compaq too)
Sep 8, 2009. 8:57 PManarchysk8 says:
really? thats weird just inside the bay covers were 6 screws that let me in the whole computer minus the screen (lol and the keyboard wasnt even fixed by screws just compression fittings) but i guess it depends on what year and how compact the computer is
Aug 20, 2009. 7:29 AMAdultoys says:
When did Instructables become a bragging contest for children? If I'm someone who takes the time to read peoples comments to get more info/opinions/tips/ratings/etc on the instructable, I don't want to read about the stats for everyones computers & how you came up with the money to buy whatever it is.... Please... comment on the "INSTRUCTABLE" not about yourself !!!!! Thank You !!
Aug 10, 2009. 5:16 PMGamer917 says:
i hope your acer lasts longer than mine, the motherboard got fried on mine
May 11, 2009. 7:35 AMladyharley05 says:
you should have more space on the bottom of the laptop for air to circulate. I would think the fan would mess up without air flow
May 15, 2009. 10:54 PMrens23 says:
yea that think i too
Jan 6, 2008. 7:07 AMbenjgvps says:
Wow, a 12 year old with a laptop. Kinda spoiled if I say so for myself. If I want a computer I have to buy it myself. Thats why I have a PowerBook 150 and an eTower 533i (Spent more than $150 total in upgrades for this thing). I just hate it when I hear about someone much younger than me getting better stuff for free from their parents and not taking full advantage of it.
Apr 18, 2009. 3:35 PMcotton says:
wow rude much, i payed half for my netbook and ur calling him spoiled because he got a laptop. so he got a laptop shouldent he take full advantage of it before it fails i am. i do everything on this netbook wuts next im spoiled?
Apr 16, 2009. 6:00 PMreese08_93 says:
exactly, kids these days... don't know a hard days work. I'm 15 and will work 2 jobs this summer. I have 1 beast laptop, 1 beast desktop, and a crap desktop. And I've payed every cent of it.
Aug 10, 2009. 5:09 PMGamer917 says:
i worked for a loooong time, made $500, and a year after that, when i lost my ipod, i bought a replacement with my own money. My advice to you is to sell the crap desktop so you can buy upgrades for the other desktop
Aug 11, 2009. 3:02 PMreese08_93 says:
chia i make 500 bucks in two weeks now
Oct 20, 2008. 9:05 AMshmuley95 says:
im 14 i have a laptop i think its a very common thing now... i asked my dad for my macbook pro and he said it was educational so why not, hey i mean u can learn so much from the internet just look at instructables!!!
1-40 of 108next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
23
Author:dkfa
I'm in Highschool. =] Love paintball. Old Instructables member. Have been featured on the homepage and most viewed award. =]
