Install IJDMTOY 2011-2016 Ford F250 F350 Super Duty Light Bar
Published
Introduction: Install IJDMTOY 2011-2016 Ford F250 F350 Super Duty Light Bar
About: Everything about automotive LED lights
Check out this iJDMTOY Ford F250 F350 LED Light Bar w/ Lower Bumper Grill Mounting Bracket for the 2011-2016 F-250 F-350 Super Duty. With these short and simple steps you too can be on your way showing off your new LED Light Bar.
Step 1:
Using the bolts and locknuts, bolt the bracket to the upper rear holes of the bumper and hand tighten it.
Step 2:
Put the 1/2" bolts through the bracket and bumper flange. Tighten it with a wrench using a washer on the bottom of the bracket and top flange.
Step 3:
Tighten the rear bolts using an Allen Wrench and a Wrench.
Step 4:
Put the light in the bumper and place it in the bracket.
Step 5:
Set the angle of the light that you want and tighten the bolts. This Ford F-250 F-350 LED Light Bar Assembly is perfect for those wanting a lowkey approach to the LED light bar or have additional light bars. As you can see this was a very straight forward install and this will go great on your Ford F-250 F-350 Super Duty.
    • Creative Misuse Contest
    • Water Contest
      Water Contest
    • Oil Contest
      Oil Contest
