Install IJDMTOY Jeep Wrangler Front Grill LED Light Bar
464
Posted
Introduction: Install IJDMTOY Jeep Wrangler Front Grill LED Light Bar
The Jeep Wrangler is known for its versatility, as it is very common to see a Wrangler go off the beaten terrain and still be fully functional while cruising the city streets. For people who use their Wrangler for an assortment of driving scenarios, additional upgrades are beneficial to help the Wrangler achieve its full potential. A good upgrade is the iJDMTOY Jeep Wrangler LED light bar, which is a 20" lighting assembly that is mounted in front of the grille to give extra lighting output when driving. Installing a LED light bar on the Wrangler is fairly straightforward without any modification required, so you will be able to have extra powerful lighting in no time.
Step 1:
First, you will need to decide if you want to mount your Jeep Wrangler LED light bar at the top or bottom portion of the grille.
Lower mount: brackets point downwards
Upper mount: brackets point upwards
Step 2:
Reach inside of the side bar opening so you can mount the brackets.
Removing the front grille is optional, but it will make the installation process easier.
Remove the plastic fasteners inside of the grille on both sides.
Step 3:
Time to mount the brackets.
Pull out the slat where you will be mounting the brackets. There's enough hand space behind the grille to stick your hand inside and give you room to secure the brackets.
Secure the brackets in place through the larger holes and then bolt the bracket to the frame where the plastic piece used to be.
The bracket must be bent inwards, towards the center of the vehicle.
Step 4:
Put the plastic cover fasteners back in place to the original location.
Clip it into the smaller holes on the bracket on both sides.
Step 5:
Carefully install the LED light bar in between the brackets.
Bolt everything together.
Step 6:
Connect the wires to power up the Jeep Wrangler LED light bar.
Step 7:
You can see that the whole installation process is actually very easy to follow and does not require any excessive work. Installing off-road LED lighting has never been easier and with the vast options available, you can easily pick which upgrade is perfect for your Jeep Wrangler to fit your specific needs. You will be amazed at the extra lighting capabilities of your Jeep Wrangler and be ready to take your ride off the road.
  • Paper Contest 2018
    Paper Contest 2018
  • Epilog Challenge 9
    Epilog Challenge 9
  • Gluten Free Challenge
