Picture of IKEA Hack
The nice thing about IKEA furniture is that it is cheap and easy to hack. In other words, lets say that you were to buy two cheap $30 Gorm shelving units and assembled them to discover that one was crooked. Well then, it would be really easy to spend an afternoon converting the crooked one into a solid, stylish and symmetric bookshelf bench.
As you probably just guessed, this Instructable will show you how to convert a Gorm shelving unit into a bookshelf bench. With a few extra peices of hardware and a couple of basic power tools, you could be on your way to relaxation and organization all at the same time.
Step 1: Go get stuff
You will need:
(x1) Gorm shelving unit
(x1) 2x4
(x1) 92.75" x 12" x 3/4" piece of plywood (I inherited an awesome piece of bamboo plywood for this project)
(x16) 3/8" Crossdowels
(x16) Bolts 2-1/2" (to fit crossdowels)
(x8) 2" woodscrews
(x1) 50 feet of rope
(x1) A tape measure and pencil
(x1) Circular saw
(x1) Sanding block and/or sandpaper
(x1) Power drill, 3/32" and 3/8" drill bit
(x1) Assorted hand tools
Fabric, foam and stuff for a cushion - see Step 13
Step 2: Assemble your crooked bookshelf
Assemble your Gorm bookshelf to realize that two out of the 4 posts are crooked. Stare at it in displeasure.
Resolve to take drastic actions.
Step 3: Cut a 2x4 into 4
Picture of Cut a 2x4 into 4
Cut four 12.25" lengths of 2x4.
Step 5: Take apart your bookshelf
Disassemble your horribly crooked bookshelf. Select the two prettiest and straightest beams to cut up for use as the supports for the bench.  You will be able to make six supports with these two beams.
Using the two ugly beams, you should be able to get 1 support from each.
1-40 of 59Next »
walter1999 made it!3 years ago
perfect apt book solution. THANK YOU!!!!
randofo (author)  walter19993 years ago
That's awesome! Glad that worked out for you. It works well with all of those plants.
dollywild made it!4 years ago
 Here's what I did with your idea- Thanks!  We are all hanging out on the porch much more now.
randofo (author)  dollywild4 years ago
Wow. That looks great! Very cool. I like how that turned out very much.
ninjachimp092 months ago
cool looks like I'm going to IKEA
raxas5 months ago
hahaha best assistant ever!
RobertP16 months ago
Nice....
Great job !
tdũng11 year ago
I Made it. Nice solution. Thanks.
msharpe41 year ago
What weight will it support?
mwilson502 years ago
'Looks great!
djabunDANCE2 years ago
I love this! but i need a specific size for my project (70"W x 20"H).
I didn't see the finished size anywhere (maybe i didnt look hard enough ;)
Seems 92.75"W x 18.25"H x 12"D to me...
Could you let me know for certain? Thanks!
Schmidty162 years ago
cool i thought it was a bed with storage first lol
_pstsh2 years ago
Hello guys !
Im from France and I have to convert all those measures to european system.
Anyone knows what size of lumber in centimeters is a "2x4" ?
Is it 1.5 in × 3.5 in so 3,8 cm × 8,9 cm ?
Thanks!
tfm3 years ago
Could someone tell me the size of the heads on the hex bolts? Even Ikea doesn't know...I need to break some down in my storage space and I don't want to lug a full ratchet set.
Thanks!
ljohansson23 years ago
How long is that in cm?
shivika3 years ago
how do you get 4 12.25" pieces from a 48" piece of wood. doesn't that total 49". should it be 12" inches each?
randofo (author)  shivika3 years ago
I never specified the length of the 2x4.
Uh, yes, it's right there on the Step 3 page.
"Cut four 12.25" lengths of 2x4."
Is that correct or should it be 12 inches? Just want to be perfectly correct in this hack.
randofo (author)  yoga_beyotch3 years ago
Yes. The Ikea shelved are 12.25" wide. You can measure them to make certain this is correct.
cracker_jax4 years ago
Just finished and I feel like I wasted $100. Here are some observations:
-The variable spacing of the holes in the ikea planks used makes this unlevel on the floor.
-A "cross dowel" costs, literally, $1 at Home Depot. These 16 parts cost half the shelving unit.
-Without a drill press, you cannot guarantee your holes will go in straight, therefore you either redrill old wood, redrill new wood, or accept that 1/4 of your 2x4 supports are half supported
-The variable spacing of the holes in the ikea planks used makes this the wrong height on the top for a sheet of 3/4" plywood, and only revealed when complete how each is differently too long.
-Cutting plywood to be the legs without a chop-saw is unrealistic. Luckily I had access to one.
-2 1/2" bolts are too short. 3" bolts fit perfectly. Another trip to Home Depot to switch them out. As for those cute flat bolts that use a hex key to screw in, those are also very expensive and hard to find at length. I had to use generics which I fear will tear up the legs of those sitting on the bench.
Suggestions for anyone about to build this:
-Get some good wood screws and predrill your 2x4s for that, not the cross dowel debacle. Muuuuuch cheaper, and flatter. No need for crossing the holes.
-Use a chop saw for the 2x4 cutting and if you can have the store rip your plywood, do it. Hand guiding a circular saw is not easy or accurate.
-If you're some super cool woodworking pro, have at the original instructions.
Thats all. Still a welcome education but there will be a lot of work trying to fix this so nobody gets hurt.
randofo (author)  cracker_jax4 years ago
Did you try lining up all of the holes with the initial section that you cut before you made additional cuts for the remaining sections as directed? I didn't have this problem.
A 3/8" hole is much larger than you actually need for the bolt and drilling a straight hole for the nut halfway down through a 2x4 I didn't find particularly challenging as you are only going down about an inch at most.
Even if the hole that you drill in to meet the nut isn't perfectly straight, assuming that you pay attention to what you are doing to begin with, sink the nut in straight, and the bolt ultimately meets the nut, the angle at which the channel is drilled is irrelevant. The bolt is only going to screw into the nut at a right angle (give or take a tiny bit).
And then, assuming that even a bolt or two is sunk in crooked and two adjacent bolts are at mildly different right angles, when fastened to the leg, considering the softness of the wood and the tension created by fastening the bolt tightly, this will only be a problem insofar as your bench will not look pretty as some screw head will appear to be sunk in mildly crooked. I don't see how you figure them to be half supported.
I didn't buy cross dowels at Home Depot as they are too expensive. Home Depot deals mainly in moving mass quantities of generic goods and not specialty items such as cross dowels.
If I remember correctly, I spent about $15, give or take, on the hardware and bought full boxes of both the screws and the nuts, which was way more than I needed. If you are interested in saving money you can shop at your local independent hardware store, like I did, or order online from McMaster-Carr.
You can also use wood screws and washers as you suggested, but, in my opinion, it slightly changes the aesthetic and I felt it would be stronger if I used cross dowels.
If you don't have a chop saw, you can use a circular saw or jig saw. If you are not confident enough to measure and cut the semblance of a straight line on your own, you can use C-clamps and a piece of scrap wood to create a guide for the saw. Claiming it is unrealistic to use anything but a chop saw is silly because I did just that and it turned out fine.
I don't have a giant shop at my disposal with drill presses and chop saws, but a modicum of power tools. It was not my goal here to teach anyone basic woodworking skills, but to show how I went about making this bench
You are right about the strength using wood screws. Wood screws do not hold as well when screwed into end-grain. However, cross dowels are expensive and not easily found. They are available from most woodworking stores and online.
Drilling a straight hole can be difficult, but you can buy inexpensive alignment jigs that will attach to a power hand drill and will let you drill straight holes at any desired angle for under $30 US.
My cordless drill has a bubble level built on to the back so that it's easy to keep those vertical holes vertical. I'd imagine you could buy a bubble level and hot glue/super glue it to your drill.
Ditto on the cross-dowels vs. wood screws. Especially if this becomes a bench with folks sitting on it. It's like using mini bed hanger bolts.
Nice Instructable, randofo. I'm having a bit of circ saw envy, though. ;)
My drill has the bubble too, but if you are trying to drill a hole to a certain depth, it is difficult to watch the level and the drill bit at the same time. The jigs come with depth stops and once you set the angle, you don't have to worry about it anymore.
Also, instead of using cross dowels, you can use a wood dowel and a wood screw. (I recommend Kreg screws.) Just drill a hole the diameter of the dowel through the narrow width of the board and glue in a length of dowel to fill the hole. Make sure you are only about an inch or so from the end of the board so that your screws are long enough to go through the dowel. The dowel is stronger than the end grain and will give you good holding strength. If you use kreg screws make sure you only drill a small pilot hole to guide the screw. Don't drill a hole the same diameter of the screw or it won't have any wood for the threads to grip.
Simplest trick ever for drilling to a certain depth while watching the level: strip of duct tape on the drill bit. The sound changes when you reach your target depth.
nice tricks! Thanks guys. I love to woodwork but never had in instruction from anyone. Ppl dont expect a woman to be doing these kinds of things, but I enjoy it.
Thanks again.
mneedler,
Check out lumberjocks.com and popularwoodworking.com. Lots of good info from men and women.
Yes, that is a useful trick and one I use often. But it does not guarantee a straight hole. If you are too cheap or too poor to buy the drill guide I mentioned, you can use a straight block of wood with 90 degree edges to guide your drill bit. Just lay the bit up against the side of the block and drill. If you cut the block to the proper height, you can use it as a depth stop too.
i guess i'm a little late to the party, but... to straight cut plywood using a circular saw use another 4x8 sheet of plywood clamped on top of the one being cut - leaving enough width for the flat plate of the saw to slide on the plywood being cut. that is, the top, clamped plywood acts as a fence or guide. in my opinion the most frustrating part about sawing plywood is not the straight line - instead it's the large amount of space needed to work.
wilwrk4tls poza3 years ago
Here is a link to my Instructable for a circular saw fence to help deal with plywood and such.
http://www.instructables.com/id/Ultra-Precise-Circular-Saw-Router-Guide/
I threaded the string across the back, diagonally to form a (tight) cross, making the whole structure more rigid.
You could also just buy wth wire braces that Ikea sell for these units.
Заходите!!!!!!!!!! Обо всём в сети
http://blog-all.ru/
gamini3 years ago
wooooooow good ,,, I love the looks of this
darkclaw423 years ago
Cool project!
I've got to ask about those speakers though!
randofo (author)  darkclaw423 years ago
They are Pioneer CS-510 speakers. Some guy in my neighborhood was moving one day and was giving away most of his stuff and I picked up those speakers (amongst other things). I have been quite pleased with how they sound.
Smithcraft3 years ago
A screwdriver is not a punch or a drift!
Otherwise, very nice work. However I usually just take warped Ikea bits back, and get straight pieces. I have seen them go through every box looking for good parts. I'm not sure what they did with the sets of warped wood...
dollywild-Love what you did! Would have been perfect when my children were young!
Very coooooooooool!! Thanks for your excellent Instructable.:0)
Nice idea. I'll probably skip the step of hacking Ikea furniture and just make a shelf the size I need. Because that's how I roll. Besides, I got an existing futon cushion I want to make a non-futon frame for, and I like practical furniture.
1-40 of 59Next »
