The-IKEA-charging-box---no-more-cable-mess!
I definitely needed something similar, so I went and bought one of those boxes at IKEA, but it stood in my office for a couple of weeks. Last weekend I finally decided to have a go at it. One major difference I wanted for my charging station: the ability to turn off each power supply individually instead of having all on while charging a single device. That meant going to the electronic store and buy 4 switches (there were nicer models, but they didn't have 4 identical ones, so I just got these).
Total cost for the project: 11,24 Euros
Ikea box: 1,99 Euros
Ikea box lid: 1,25 Euros
4 switches: 4 x 1,00 Euros
4 plugs: 4 x 1,00 Euros
I believe I could have gotten the switches and plugs slightly cheaper if I had looked around.
The rest of the parts I had them at home. Should be fairly cheap ones anyway.
It's not absolutely finished. I still want to get a protective plastic part for the inside, just to prevent any accidental contact with the exposed connectors. Another possibility is to just use heat-shrink tubing, although it might be difficult to completely cover the connectors next to the wall.
For now I just know that I shall only remove the lid "locks" after disconnecting the power plug.
In the end, still a fairly easy and cheap project.
Step 1: The Parts
- 4 power plugs
- 4 electrical switches
- electrical wiring
- connectors and "joiners" (if someone can give me the correct names I'll edit this. My mother tongue is not English... You can see some pictures of these in the next steps)
Step 2: Installing the switches
Using a cutter, I made the holes. Even if not perfectly cut, once inserted, the switch covers the sides and looks quite nice.
Here's how it looked:
Step 3: The electrical wiring
Pretty much it's just the 4 plugs connected in parallel, each having it's own switch.
Step 4: Connecting the Power supplies
As you can see, the switch connectors are exposed. I still want to get a protective cover for all those parts, if not, just use heat-shrinking tubing. For now I just have to remember to disconnect the main power supply before opening the box.
Step 5: Drilling the lid
I could have just drilled a circle in the middle of the lid, but thought it would occupy to much space.
Therefore I decided to cut some holes on the edge. Now this was probably the most difficult part of the project. Not only it is in rather difficult place to cut properly (at least with the tools I had available), but it would also be showing.
After a first attempt just with the cutter, I ended up using my dremel to make it a bit better looking.
I'll have to take another picture from the opposite side in order to get a better view.
Step 6: The final result
As I've mentioned before, I still want to get a protective cover or use heat-shrinking tubing for the inside electrical parts, and I'm still checking if it will require any ventilation holes. So far it never got warm at all, but haven't had all the power supplies on for several hours for a proper test.
Visit Our Store »
Go Pro Today »
The box is at this link:
http://www.ikea.com/us/en/catalog/products/66696910
and the lid:
http://www.ikea.com/us/en/catalog/products/26697110
they are made for line voltage and they would mount in the box nicely.
just connect one wire to neutral and the other to the hot line that goes to the outlet.
phone chargers
i also highly recommend his online book:
Sustainable Energy - Without the Hot Air
for any one who is interested in learning facts about energy consumption and generation without the politics. written in the style and clarity than only a professor of physics can muster. some real gems too, like how many kwh per day your cat consumes.
I'm all about making stuff myself, but this might even be cheaper - it might be cheaply made too.
