3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
IKEA Tool Box Hack
IKEA Tool Box Hack
How to hack an IKEA FIRA mini chest into a nice looking tool box for the office.
Step 1What you Need
What you Need
All you need is one of the IKEA FIRA mini chest, a pack of KOSING handles (6 pieces for $1.99), and some #8 metal washers from the hardware store. I went with the cheapest handles, but you can go for nicer ones.
There are several configurations for the FIRA mini chest. Pick one that you like.
10 comments
Mar 29, 2012. 2:01 PMvincent7520 says:
Does IKEA sell these small chests in the US ?
In France they're sold in many local Home Depot equivalent stores but I never saw them at IKEA.
Simple and good job really.
Mar 30, 2012. 4:26 AMvincent7520 says:
thank you !…
Apr 25, 2011. 12:05 PMquequeg1 says:
instead of washers you might put a backing plate from front to back screw, it would lessen the chance of a heavy chest ripping the screws out through the top as well as work as the spacer you need.
also a good way to cut machine screws and save your threads is screw the correct sized nut onto the screw past the point where you want to make your cut. make your cut (with hacksaw or dremel) then back the nut off of the screw, it will straighten any threads you crunched on its way off.
Nov 17, 2010. 6:08 AMKittyF says:
I like your idea but I'd like to suggest if your tools are heavy you'd be better off installing your handles on the side, since you're likely to pull the top off with top handles.
I'm thinking tools here since you called it a tool box, although i can see it as a spice drawer set up, or office tools, etc. anyway, I do like it.
Aug 14, 2010. 8:07 PMWizardofwesley says:
If you have a wire stripper/crimper.. that has the built in screw cutter you can cut the screws without killing the thread.. then you can mount the handles anyway you like... so they would be in line with the box... Having a handle is not a bad thing when you have to move the box around on your bench...
Jun 27, 2010. 10:17 AM666chickenhead says:
I don't get the need for the handles either...
Feb 16, 2010. 9:06 PMrobj98168 says:
This is so cool- THese would be perfect for work- Were good wooden toolboxes cost $100+ or more
Oct 4, 2009. 4:23 PMlibbygrace says:
i'm curious why it needs the handles in the first place?
Sep 23, 2009. 6:25 AMagis68 says:
I hve the same and these handles are neat.....good
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
5
Author:pkshiu
