Introduction: ILLUMINATED BY THE SUN...FLOWERS
Picture of ILLUMINATED BY THE SUN...FLOWERS
I had some garden solar lights that didn't work at all,their electronics plaques were completly oxidized that made them useless. But then I found that the solar charger plaque was still working giving 2.5 volts directly exposed to the sun.
Then I image that with some aluminum ,soda or beer can ,and the garden solar plaque, could make sunflowers charging a old phone battery in order to illuminate a stone owl that I had already on the backyard
It is wireless,compleatly independent light, so it can be moved around to light any place you like to stand out
Step 1: Making the Flower
Picture of Making the Flower
Cut the can by the middle,then cut six "petals" obtaining the shape with a scissors,it's some easy to do because the aluminum can is very thin and malleable
Paint then with a gold or yellow colour paint
Take the downer lid of the solar garden light,make a 8mm drill on the center, do the same on the flower
Thread the tube in the stem,put the lid and the two parts of the flower and tighten the nut
Step 2: The Stem
Picture of The Stem
The stem came from an old tv antenna,1/2" aluminum tubes
Cut the tubes in different sizes
Take a bolt ,make some conic head on it
Expand them with a bolt,insert the nut and then made lips around it in order to hold the nut.
Thighten the previously armed flower,to the stem
Step 3: The Base
Picture of The Base
The base is a piece of log rescued from a bbq fire,made four 12mm holes for the stem,communicated in betwen.
Also was made a pocket to insert a phone battery,connected to the four holes
Step 4: Solar Charging
Picture of Solar Charging
Dismantle the garden solar light,take out the battery and the electronic plaque
Cut the cilyndrical wall of the light get the circle with two wires,the solar charger,identify the anode and cathode solder a wire longer than the "stem"
Pass all the wires throw the holes an the pocket,connect in serie two of thesolar charger,connacting in serie is one + to the - wire ,then you get more than 5volts on each couple of solar chargers
Do the same with the other couple of solar charger
Solder a diode to the + wire of both of them
Now we can connect them to the battery
Step 5: Lightning
Picture of Lightning
The lightning is made with a multicolor fading led,it has only two legs and the change of color is made by a chip that fades the light in different colours
On the pictures the led is tested with a 3v button cell
Rise the battery wires throw the pocket (battery case) and one stem
Take out the wires throw the hole and the support made on it.
Place among the battery and the led a little switch and a 150 ohms resistor
Step 6: Testing on the Backyard
Picture of Testing on the Backyard
We can see the different faces of the multicolor led fading over the stone owl
The fade is made at a slow pace,the led has a chip that changes automaticatly into green , blue and red
This kind of leds are very brilliant ,thanks to that is a nice option to stand out some specific place
Hope you like the instructable and inspire you to make it,if you do please vote the contest
About This Instructable
659views
8favorites
License:
Bio: Broken devices always have several useful parts,recovering them , we reduce trash ,then we are taking care of the planet
More by Ugofirst:S.W.A.K.   MAIL  BOXMULTIMEDIA ENTERTAINMENT BOXFRIGHTENING STONE OWL
Add instructable to:
