Introduction: INSANELY HOT DIY Hot Air Soldering Iron @ 15 Volts DC and 3.5 Amps...PART II
Picture of INSANELY HOT DIY Hot Air Soldering Iron @ 15 Volts DC and 3.5 Amps...PART II
359 degrees centigrade and with room for more ;) This is the permanent version to my earlier prototype. I have added adjustable nozzles, used a smaller heater element and of all things, butchered a scooter handle to hold it all together. If you look at this and my other instructable, you are surely able to make your own. Big improvement with this final model is that the heating element is thermally isolated from the main housing...a big change from the standard shop brought soldering irons. This isolation of heat allowed me to reach insane temperatures without cooking my hand. Here is the link click here to the prototype that started this off....
anyways...i have stated my experiences and since making the front page of MAKE, some people have their noses out of joint and have become quiet the TROLL...this is it for me and I merely posted my experience and did not baffle anyone with theoretical tripe...You make your own mind up....I am not into defending myself against TROLLS who think they know better than anyone else...You all have good weekend, and if I create another working project, remind me to proclaim that the world is not flat and give my accusers a bundle of stones
Step 1: To Start, You Need One of These...
Picture of To Start, You Need One of These...
Hot air gun from the dump...or anywhere you can get your hands on one. Does not need to work. The down side is that you need to get one that has cylindrical ceramic tubing in the heater department - see later stuff for more of what I mean. The metal tube housing and all attached bitz such as motor is what you will need if you follow this instructable.
Step 2: The Fan Is Important
Picture of The Fan Is Important
This style of fan compresses and forces the air out of the blower unit into and through a smaller opening such as the nozzle end of my DIY soldering iron. I had earlier made a fan that I thought would be good, but it dd not emit much air out of the narrow opening...I am thinking an air pump from an aquarium that has several internal diaphragms may be of use here...A simple 12 volt car air compressor would be great too, but they are too noisy, but worth a look at later.
Step 3: Choosing a Motor to Pump Your Air.
Picture of Choosing a Motor to Pump Your Air.
I had several motors I looked at and in the end, decided on using the assembly I had created from earlier instructable prototype, using the original motor and fan assembly from the heat gun I butchered. Of interest to me is the induction motors I have...brushless and will go on forever..and much quieter than the standard brush...in my own time I will figure out how these are wired, as I haven't a clue.
Step 4: Scooter Handle Was Just Ideal to Hold Everything.
Picture of Scooter Handle Was Just Ideal to Hold Everything.
I wanted a larger housing to hold the element in place with the idea of isolating the heating element from the metal main casing. It was not to be too large and not too small. I butchered this scooter handle from my parts shed and began to start work.
Step 5: Find the Ideal Length of Heating Element
Picture of Find the Ideal Length of Heating Element
This picture shows a way too long heating element to run from 12 volts DC. Using a small 12 volt battery, I downsized the heating element until it started to glow red...this was to be my starting point and choice of length. This heating element was taken from the heat gun I butchered...I had some other elements, but in bending the wires, they snapped...no good, so I threw those ones out. This element had good ductile deformation properties...must have been a new hot air gun before it croaked it.
Step 6: Reshape Your Heating Element
Picture of Reshape Your Heating Element
Once you have the desired length of element, it may need some reshaping to remove any kinks etc, I used this dremmel bit to hold the element while I reshaped it.
Step 7: Ultimate Insulator...
Picture of Ultimate Insulator...
This mica roll I removed from the inside barrel of the hot air gun...just perfect, to roll up into a smaller size and insert into my scooter handle...be careful in rolling it as this stuff is brittle. This would help shield the main metal barrel from the radiating heat emitted from ceramic tube shown later.
Step 8: Make Your Own Insulation Washers.
Picture of Make Your Own Insulation Washers.
Needed to make heaps of washers as I did not have any insulated solid tubing to get the result I wanted. Fiberglass sheets were good...be careful with this stuff as when you grind it with a dremmel, you are actually creating microscopic glass shards/powder. Wear a mask and gloves as this stuff makes you itch. These washers will help isolate the heating element from the main barrel. Here, I used a five cent piece as a template. The coin actually just fit inside the barrel of the scooter handle, so is the ideal size.
Step 9: After an Hour, I Made Heaps of These...
Picture of After an Hour, I Made Heaps of These...
What you can create with a dremmel...what I did not have, I made...it just took longer to get the job done!
Step 10: Tricky Bit...how to Seperate the Heating Element From the Main Barrel.
Picture of Tricky Bit...how to Seperate the Heating Element From the Main Barrel.
Making two washers with the same outside diameter but different inside diameters, I was able to use some non conductive metal cement and glue the two washers together. Then Repeated the same procedure for the other end. This will actually separate the heating element from the main body. To see if my idea worked, I place a lighter on one end of a washer and held the other side of the washer with my hand while a lighter flame heated the washer up...heat did not travel (conduct) to my fingers. Ideal stuff!!!
Step 11: The Heating Element Complete
Picture of The Heating Element Complete
This is the idea I wanted to get. Do this and you are off to a great start. My earlier prototype had the ceramic tube flush against the main barrel. While still cooler than a standard soldering iron, I wanted better efficiency and more heat out of the nozzle end, so I created the washers to help reduce heat conduction.
Step 12: Cose Up View of Output End
Picture of Cose Up View of Output End
As the washers are going to be stacked and glued to create the tubing I wanted, I had to make sure the heating element wire was recessed into the washer . This just makes less obstructions, turbulence inside the barrel from the passing through air and also help to isolate the hot air from comming into contact with the main outer housing scooter handle.
Step 13: More Electrical Isolation and Heat Protection.
Picture of More Electrical Isolation and Heat Protection.
Close up view of the element and some sheathing I added to the wire running up outside the ceramic barrel. You can see some of the interchangeable nozzles here that I use later to control air dispersion at the output end.
Step 14: More Washers
Picture of More Washers
These washers were made to allow room for the wire to exit the heating element to the power supply connector bit. As the washers are going to sit flush together and stacked to form tubes of different lengths, this is essential step.
Step 15: How to Connect Element to Power Supply.
Picture of How to Connect Element to Power Supply.
I recycled some connections from the heat gun and used those to create the essential connection between the element and power wires. I later discarded this rivet idea, as I wanted something later that would allow easy removal and replacement of a stuffed element. I opted to use super thin bolts and nuts and small spring washers to join the two ends together. There is nothing preventing this idea of the rivets holding the wires together if you can not find nuts and bolts small enough to do the job. Remember that they must be small enough to clear the outer metal casing...you don't want an electrical contact here...lol
Step 16: Close Up of the Rivet Joining
Picture of Close Up of the Rivet Joining
This is a close up of the rivet idea...As i said, i ended up using thin bolts and nuts attchacing the wires here.
Step 17: The Nozzle End
Picture of The Nozzle End
One end of the scooter handle I created a flange to mechanically seat the nozzle. I first dremelled the edge to a 45 degree angle and the bashed the end with a hammer, turning the tube with each hit to create the inverted flange that will prevent the nozzle from falling out here...I worried about the other end later...lol
Step 18: The Nozzle
This is the important end. You can see the thermal isolation created by the washers I made. The main nozzle is a brass tube from a weed sprayer. I cleaned it up of course before using it here. This weed sprayer was from the local dump and I ended up getting some extra nozzles that will come handy.
Step 19: Heat Sheild
Picture of Heat Sheild
This mica sheeted roll was ideal for isolating the ceramic barrel housing the element from the scooter handle and the effects of radiant heat. Without it, I noted the heat of the barrel was similar to that of a typical soldering iron...not the effect I wanted...So I added this shield, butchered from the heat gun
Step 20: Fitting the Power Connection
Picture of Fitting the Power Connection
This is the rivet idea still and how it all fits into place...the idea I used was much cleaner than this, where I discarded the rivet method and used nuts and bolts instead.
Step 21: How It Was All Going to Be Joined Together...
Picture of How It Was All Going to Be Joined Together...
This is the idea I came up with to house the unit together. The washer to the far right was going to be held in place by three metal screws drilled into the scooter handle...I liked using the thin bolts idea as it discarded the need for all of this seen here.
Step 22: How It Would Have Looked
Picture of How It Would Have Looked
Using rivets instead of nuts and bolts...this is the effect you should aim for!
Step 23: Electrical Insulation
Picture of Electrical Insulation
This is how i solved the housing problem inside the unit...the spring pushes everything up nicely against the nozzle. The flexible insulation tubing seen here adds further protection of the power leads from the main spring. The perfect wire I found was butchered from an old metal halogen light fitting. It was thick and insulated and heat resistant. I held a lighter to the wire I salvaged and it did not burn, melt or smoke...excellent. It even had the ring connection on one end that is exactly the same size as the ones shown previously at the ends of the white and blue wires. Because the wire is so thick, it actually was used to push everything flush against the nozzle, kewlies
Step 24: I Got Just Over 360 Degrees Celcuis, But Missed the Capture...damned Slow Camera
Picture of I Got Just Over 360 Degrees Celcuis, But Missed the Capture...damned Slow Camera
Wickedly hot air ...and concentrated ....and controlled.... everything I had ever wanted during this past week of making this beast. Changing nozzles changes the width of the heated air being forced out...changing the voltage in conjunction with the air flow changes the temperature. That is, increasing the airflow allows me to reach even more insane hotness by increasing the voltage. The element was glowing red at this point and I still could place my fingers onto the barrel without hurting them...If I laid my fingers there for too long it got a bit hot though.
Step 25: Power Consumtion
Picture of Power Consumtion
Basically nearly at full steam....15 volts DC and 3.4 amps. Use a voltage regulator if you can or tinker with an old computer power supply abd adjust the length of your heating element to your desired voltage input
Step 26: The Old Blower Unit From My Instructable Prototype.
Picture of The Old Blower Unit From My Instructable Prototype.
It was a bummer that I could not use the motor I wanted to as the fan was not compressing the air enough into a smaller hose...so I used the blower assembly I butchered from the heat gun and created this masterpiece.
Step 27: This Is It !!!
Picture of This Is It !!!
The final unit with power and air nozzles exiting from the handle...thank you old scooter, you served me well ;)
GO chispa GO (author)2016-10-11
Today in 2016, there are options more easy & cheap:
https://www.instructables.com/id/Estación-De-Soldadura-Por-Aire-Caliente-15/
ortegacomputacion (author)2014-10-17
to all those people commenting about the current availability and low price for a tool of this kind, beware, as is it not the same in other countries, you all are blessed to be in a first world country, for those of us living in the outside,aka third world, this is an excellent post for something with such a prohibitive price. thanks for posting this instructable.
JacFlasche (author)2011-11-27
I guess this would be ok if you have a heat gun with a ceramic encapsulated element that has a broken handle or something, but before you spend any time or effort, realize that you can buy a hot air rework station for about a hundred dollars new. It will have all kinds of safety features that this does not, and temp and air flow controls, digital displays etc. Actually my ten year old Steinel heat gun will do things that this cannot and you can pick up a nice used one for 30 on ebay or even less if you are patient. This is not even close to insanely hot. My old Steinel still goes to 820 C which is fairly standard and not at all insane, and has infinitely adjustable heat and air (within parameters) I got it for about $50 ten years ago. By the way, some of the people you are in some kind of flame thing with are right, you should take the word of professionals with twenty years experience who are trying to clue you. Here is a link to a video of a professional hot air rework station being built. It has both an iron and hot air.
https://www.youtube.com/watch?v=quGs3q9nsA8
gojason (author)JacFlasche2014-03-13
Thanks for the link. Very high efficient production. I can see the whole hot air rework station to be assembled within 9 minutes. To find out more about this topic, you can check out the hot air rework station reviews here. BTW, a professional hot air station costs around $50. For safety concern, most of us should consider buying one other than making it by yourself.
hakam66 (author)2011-11-21
make power supply for Hot Air Gun
The nerdling (author)2011-05-26
i know where to get a hot air jet
The Lightning Stalker (author)2007-09-23
Where did this ceramic tube come from?
You can use a high watt resistor, some resistor is tube and its ceramic
innards of a paintsripper heat gun, I understand not all come with the cylinders.
beatobe (author)2010-08-02
where i can find a ceramic tube like that???
emuman4evr (author)2008-08-20
I dont think 359 degrees is hot enough to melt solder.
clark (author)emuman4evr2008-12-22
thats 359 degrees Celsius.
lasermaster3531 (author)clark2010-02-21
 google it.
ReCreate (author)emuman4evr2008-12-23
400 degrees Fahrenheit is enough to melt solder 359 degrees Celsius is 678 degrees Fahrenheit that's about 200 degrees over solder's melting temperature
DIY Dave (author)2010-01-25
Couldn't you just use a heat gun?
karossii (author)2009-11-01
Just thought I would leave a comment here.. Ozzy, your instructable is a good one, and you've done a wonderful job in making this hot air soldering/de-soldering gun. It is an ingenious project.
However, those whom you are calling Trolls (and who are doing nothing in the realm of trolling) are actually correct. These devices have been around for ages... you have not invented anything new here. I know you don't necessarily claim to have done so...however I have to point out that some of us have had a lot of experience using devices like this, and you are jumping to some wrong conclusions.
This doesn't mean you did a bad job in making your device, or that it is worthless, etc.; it only means that this device has some specific uses in which it excels, and normal everyday soldering is no one of them. Yes it can do that job, but not as good as the traditional metal tipped soldering irons.
A google search can easily reveal the commercially available devices like this, and some online research will equally readily reveal the fact that they are not the best thing for traditional soldering.
That doesn't mean it cannot be used for such, only that it is not as good as a normal soldering iron.
targon (author)karossii2009-12-17
 It used to solder SMD components and BGA chips and not intended for hole through technology.
lemonie (author)2007-09-18
That's comprehensive. How does hot air compare to hot metal, with regard to frying components on the board? I guess you'd be mainly using the underside? L
OzzyRoo (author)lemonie2007-09-19
Transfer of heat to desired object is obviously much quicker with air from what I have experienced using this tool.
lemonie (author)OzzyRoo2007-09-19
What about heat transfer to other objects? Again, I guess you're using this on the underside?
L
OzzyRoo (author)lemonie2007-09-20
Mate, I just tell it for what it is....thermodynamic heat transfer is obviously much quicker with air ... why do you think people have fan forced ovens or fans in their freezers etc?
OzzyRoo (author)OzzyRoo2007-09-20
Putting it another way...the hot air passing over a soldered joint or a joint to be soldered does a far more quick and efficient job at heating the desired area only...using primitive conductive methods with hot metal tip against cold metal joint takes some time for temperature to equilibrate to a desired melting point. In waiting for this point to be reached by traditional methods, it is my view that there is sufficient time for the component sensitive to heat to be cooked. It is this time difference that prevents components being fried in the conventional sense as the job is allready done before damaging heat reaches the further away components.
ac-dc (author)OzzyRoo2007-09-20
The heat transfer is much worse with air than with a soldering iron. Why people have fan forced ovens is because they are contrasting that with only air, not with direct heated metal contact. Hot metal is substantially faster, your science is wrong and everyone who has ever used a hot air soldering station knows it takes longer per joint. The reason to use hot air is one of two things: 1) The solder joint is in accessible with a soldering iron, like under a BGA chip, and requires either an oven or at least the hot air station. 2) Desoldering parts, when all leads have to be molten simultaneously for the part to come off without damage. Beyond these two, it is inferior to just blast hot air all over a region when only one solder joint at a time needs to be made. The reason is that you cannot control this primative hot air gun as accurately as a soldering iron with integral temp sensor and regulation, nor as well as a manufacturer with a precision oven or solder bath. Since the hot air gun heats a larger area to an uncontrolled max temp, it is more likely to damage parts until there is trial and error in it's use and even then, acceptible use for parts not very heat sensitive will not qualify that technique for more sensitive parts. A hot air station does have good uses for the aforementioned #1 & 2, but believe me there is no question at all, the entire world known it is not as good nor as fast as the soldering irons used for these joints when it is not an automated process in the oven or bath line.
klee27x (author)ac-dc2009-09-26
Well, heat capacity of metal vs air isn't the entire picture. A standard soldering iron will only effectively conduct at the point where it contacts. Hot air will flow all the way around the joint - front, sides, and back - as well as heating the immediate surrounding areas, reducing loss to heatsinking. So maybe you guys are too busy being right to realize that you are arguing the wrong point?
ac-dc (author)klee27x2009-09-26
You only want the heat conducted at the point where it contacts, unless you have a multi-lead component requiring all of the solder joints to be melted simultaneously to pluck a part off a PCB it was already soldered onto. The last thing you want is to have the hot air flowing around the rest of the part and surrounding areas, only to be on the solder joint itself is the ideal. The heat is supposed to be applied at the end of the lead so that the solder to component body heat ratio is as high as possible to reduce the possibility of heat damaging the part. Believe it, I use both tools regularly. When you need a hot air wand there is no substitute, but when you don't need one, when a soldering iron can do the job, it always works better.
OzzyRoo (author)ac-dc2007-09-20
I have seen some bullsh#t before but had to come back and say mate, your the best ;)
Vermin (author)OzzyRoo2007-09-20
Nice work but ac-dc is correct.
OzzyRoo (author)Vermin2007-09-21
lol...enter the TROLLS....LMFAO....DON'T KNOW WHAT INDUSTRY standard you referring to...please quote reference before citing
Vermin (author)OzzyRoo2007-09-21
I am not a troll, I am an electronics technician with 15+ years designing, repairing and installing electronic equipment. If you would like to read some industry standard documentation on rework and repair I can suggest IPC-7711 and IPC-7721, but it's basic thermodynamics, and until you are old enough to understand this I suggest you listen to people trying to help you rather than flaming them.
the_mad_man (author)Vermin2009-02-03
IPC-7711/21 i think is interesting
OzzyRoo (author)Vermin2007-10-22
old enuff...if only YOU knew...and if only you knew my quals...lol
DC IS ACTUALLY MORE CORRECT MATEY....i have this running on twelve volt dc lead acid battery...lol....would never have believed the trolls would strike once i make front page on MAKE...rofl
I was referring to the person's nick name above not your project's power supply.
Why are you trolling about industry-wide established fact? It is indisputible that the thermal conduction of air is lower than that of an iron tip, and further, the ideal goal of soldering is to heat only the specific area upon which the molten solder needs to flow, and that at a controlled temp. I'm not knocking the idea for a cheap hot air station, it certainly has some useful applications, but that does not make it universally superior in many situations, actually in no situations except the two I already enumerated previously and only then, after testing to determine the resultant heat level per duration and distance.
lol....now I have seen it all....I just posted my results...many theories I don't care about...I ma happy and that is all that matters...if others want to try out and recreate..all good...you wanna knock something without trying it out..go for it...you two guyz are not British?
lemonie (author)OzzyRoo2007-09-20
I meant do you inadvertantly heat other components which would otherwise remain cool (with a metal-tip iron)? L
No I dont...The heat transfer is too quik to leave the solder tip hanging there and also the nozzle tips are interchangaeable...as I mentioned in my instructable...a a certain point the surfacing legendary knockers are sure to ignore..lol
_soapy_ (author)OzzyRoo2007-09-22
Eh? That's wrong. Air has a far, far lower thermal mass than the tip of a soldering iron, which is made of copper (the second or third most heat conductive metal, with a high specific heat capacity) Yes, you can pump a load of hot air through very fast, but it isn't going to beat a well fluxed metal soldering iron. Where this wins out is that you can melt the solder without having to get the tip to touch anything, and you can melt a wider area. You can also vary the heat flow rate more rapidly, by changing the current to the coil and the rate of air flow, if you want, unlike a standard soldering iron (but, of course, there are temperature controlled soldering irons, but they are more expensive) I tend to use a butane powered gas soldering iron, since it needs no mains lead, and so doesn't get in the way, plus, if you crank it up to full, it gets insanely hot and melts even large blobs of solder in a few moments. However, I'll be building one of these for re-work, since you otherwise can't hold the solder sucker, the iron, the board and the component all at the same time! With this being non-contact, a simple clamp will hold it in the right area, and the rest of things can be arranged to suit.
OzzyRoo (author)_soapy_2007-10-22
no where did i state that air has MORE thermal mass than a solid
_soapy_ (author)OzzyRoo2007-10-29
No, but you are saying that, if you argue that
because you are trying to say (or so it seems) that the air has more heat. And that would be wrong.
Tinker83 (author)lemonie2007-09-20
it has nothing to do with wether or not it is safer for the components, it is for rework, and disassembly, or for SMD paste soldering. either you use a hot air gun on your board to paste solder, or you put it in Wifey's oven and she beats your head in with your own project after the paste resin contaminates the cooking area.
gargoyle169 (author)2009-04-07
When combined with a DIY reflow (toaster) oven, this tool can assemble PCB's with a .4 mm pitch, I would not go any smaller do to the constraint of temperature control being rather spotty in a DIY like this. (Somebody who has been working fine pitch since 1980 for gov/mil/ and now private sector.)
DrStoooopid (author)2007-09-20
What's the application for this? Please excuse my ignorance. What's a hot air soldiering iron for?
OzzyRoo (author)DrStoooopid2007-09-20
making coffee
DrStoooopid (author)OzzyRoo2007-09-20
no I'm serious....what is a hot air soldiering iron used for? I know what a soldiering iron is used for, but what benefit does the air give you? Why would you use it over a regular one?
SMT work and heat shrink tubing mostly.
plus other uses open to your imagination
Derin (author)OzzyRoo2008-06-19
coffee
the_mad_man (author)Derin2009-02-03
hair-drying. sorry i mean scalp burning
ac-dc (author)DrStoooopid2007-09-20
A hot air gun, without modifications mentioned, is good for heat shrink tubing. A hot air soldering station is used when a part has multiple joints that need melted simultaneously for removal (repair work or prototypes, for example), or when the discrete part has leads/contacts/etc that are not accessible with a soldering iron.
This hot air technique is not a substitute for normal soldering of leaded or surface mount parts. That is true even if it were a controlled temp which this is not. This hot air hack could be a useful addition to your soldering tool set, but never a replacement for a good soldering iron when one could be used instead.
About This Instructable
204,015views
152favorites
License:
Bio: Geologist buff with a flair for photography and mad creations
More by OzzyRoo:INSANELY HOT DIY Hot Air Soldering iron @ 15 Volts DC and 3.5 amps...PART IIDIY Hot Air Soldering Iron using 12-18volts DC at 2-3 amps
Add instructable to:
