INSANELY HOT DIY Hot Air Soldering iron @ 15 Volts DC and 3.5 amps...PART II
 by OzzyRoo
Featured
359 degrees centigrade and with room for more ;) This is the permanent version to my earlier prototype. I have added adjustable nozzles, used a smaller heater element and of all things, butchered a scooter handle to hold it all together. If you look at this and my other instructable, you are surely able to make your own. Big improvement with this final model is that the heating element is thermally isolated from the main housing...a big change from the standard shop brought soldering irons. This isolation of heat allowed me to reach insane temperatures without cooking my hand. Here is the link click here to the prototype that started this off....
anyways...i have stated my experiences and since making the front page of MAKE, some people have their noses out of joint and have become quiet the TROLL...this is it for me and I merely posted my experience and did not baffle anyone with theoretical tripe...You make your own mind up....I am not into defending myself against TROLLS who think they know better than anyone else...You all have good weekend, and if I create another working project, remind me to proclaim that the world is not flat and give my accusers a bundle of stones
Step 1: To start, you need one of these...
Hot air gun from the dump...or anywhere you can get your hands on one. Does not need to work. The down side is that you need to get one that has cylindrical ceramic tubing in the heater department - see later stuff for more of what I mean. The metal tube housing and all attached bitz such as motor is what you will need if you follow this instructable.
1-40 of 78Next »
JacFlasche says: Nov 27, 2011. 10:34 AM
I guess this would be ok if you have a heat gun with a ceramic encapsulated element that has a broken handle or something, but before you spend any time or effort, realize that you can buy a hot air rework station for about a hundred dollars new. It will have all kinds of safety features that this does not, and temp and air flow controls, digital displays etc. Actually my ten year old Steinel heat gun will do things that this cannot and you can pick up a nice used one for 30 on ebay or even less if you are patient. This is not even close to insanely hot. My old Steinel still goes to 820 C which is fairly standard and not at all insane, and has infinitely adjustable heat and air (within parameters) I got it for about $50 ten years ago. By the way, some of the people you are in some kind of flame thing with are right, you should take the word of professionals with twenty years experience who are trying to clue you. Here is a link to a video of a professional hot air rework station being built. It has both an iron and hot air.
https://www.youtube.com/watch?v=quGs3q9nsA8
hakam66 says: Nov 21, 2011. 4:13 AM
make power supply for Hot Air Gun
The nerdling says: May 26, 2011. 6:38 PM
i know where to get a hot air jet
The Lightning Stalker says: Sep 23, 2007. 6:17 PM
Where did this ceramic tube come from?
beatobe in reply to The Lightning StalkerDec 8, 2010. 11:06 AM
You can use a high watt resistor, some resistor is tube and its ceramic
OzzyRoo (author) in reply to The Lightning StalkerOct 22, 2007. 1:38 AM
innards of a paintsripper heat gun, I understand not all come with the cylinders.
beatobe says: Aug 2, 2010. 5:55 AM
where i can find a ceramic tube like that???
DIY Dave says: Jan 25, 2010. 4:16 PM
Couldn't you just use a heat gun?
karossii says: Nov 1, 2009. 5:24 PM
Just thought I would leave a comment here.. Ozzy, your instructable is a good one, and you've done a wonderful job in making this hot air soldering/de-soldering gun. It is an ingenious project.
However, those whom you are calling Trolls (and who are doing nothing in the realm of trolling) are actually correct. These devices have been around for ages... you have not invented anything new here. I know you don't necessarily claim to have done so...however I have to point out that some of us have had a lot of experience using devices like this, and you are jumping to some wrong conclusions.
This doesn't mean you did a bad job in making your device, or that it is worthless, etc.; it only means that this device has some specific uses in which it excels, and normal everyday soldering is no one of them. Yes it can do that job, but not as good as the traditional metal tipped soldering irons.
A google search can easily reveal the commercially available devices like this, and some online research will equally readily reveal the fact that they are not the best thing for traditional soldering.
That doesn't mean it cannot be used for such, only that it is not as good as a normal soldering iron.
targon in reply to karossiiDec 17, 2009. 7:11 AM
 It used to solder SMD components and BGA chips and not intended for hole through technology.
gargoyle169 says: Apr 7, 2009. 9:31 AM
When combined with a DIY reflow (toaster) oven, this tool can assemble PCB's with a .4 mm pitch, I would not go any smaller do to the constraint of temperature control being rather spotty in a DIY like this. (Somebody who has been working fine pitch since 1980 for gov/mil/ and now private sector.)
emuman4evr says: Aug 20, 2008. 11:28 AM
I dont think 359 degrees is hot enough to melt solder.
ReCreate in reply to emuman4evrDec 23, 2008. 12:41 PM
400 degrees Fahrenheit is enough to melt solder 359 degrees Celsius is 678 degrees Fahrenheit that's about 200 degrees over solder's melting temperature
clark in reply to emuman4evrDec 22, 2008. 6:46 AM
thats 359 degrees Celsius.
lasermaster3531 in reply to clarkFeb 21, 2010. 6:40 PM
 google it.
emergencydpt.com says: Nov 10, 2008. 11:42 PM
Amazing, a troll tracked you down to post a negative comment on your rather excellent instructable. I tell, you a kid can't cut up his scooter and make a heat gun without someone cutting him down. Don't worry about it. I think you did an excellent job. Once you get to the top of a hill, people will always throw rocks at you. That's how you know you are going in the right direction!
rob_fed says: Sep 26, 2008. 9:32 AM
This is great! I changed out my handle bars on a cheap Chinese electric scooter and I have the exact piece you used :) I have been using it as a short cheater or leverage bar on my ratchet driver. Now I have a new inspiration! Thanks!
Plasmana says: Sep 26, 2008. 9:01 AM
I really want to try build one of those...
killerjackalope says: Sep 26, 2008. 8:14 AM
This is a really well made project, it's impressive both in quality and it seems to work...
Sad about the trolls, gotta say they'll take anything you give them, I liked the ones where they angrily pointed out your point then agreed, just to tell you you're still wrong. Some people are smart, some people are dumb, some cockroaches are stupid and then there are trolls...
madison_ultralight says: Apr 20, 2008. 3:33 AM
I have a professionally built one-of-these that uses helium as the mover and it'll reach air temperatures of 2000 degrees. It is the only thing I'll use to solder stainless steel parts. This could have saved me $400.
sedition says: Sep 20, 2007. 5:23 AM
You made Make, congrats!
OzzyRoo (author) in reply to seditionSep 20, 2007. 6:35 PM
thanks mate...this is just an idea that became reality and works for me...despite the opinions of others who have haven't tried it out in the real world ;)
ac-dc in reply to OzzyRooOct 26, 2007. 11:13 AM
Oh but they have tried it in the real world. There are real, professional grade, highly accurate temp and flow volume + shape hot air rework stations. Nobody uses them for the tasks you suggest because they are inferior to any decent soldering iron. Hot air is suitable for reflowing solder paste, one-off soldering down of BGA chips, desoldering of these and multi-pinned through hole parts. It is a terrible choice for general soldering. Professionals know this as does the entire world. As already written, this is a neat project and can be handy for some of the aforementioned things if you get the temp distance and timing right so it doesn't damage anything, but there are real issues using this kind of tool where it is not warranted. In some cases a semi or fully populated board represents a lot of work, time, and cost. Ruining it through an experimental and know improper soldering technique needs no testing today, as soldering is not a new skill to man and industries spend millions if not billions of dollars to find the best methods. My comments may seem negative to you but they can save a few people a lot of problems by recognizing when this is and when this is not a good tool for the job.
airwelldriller says: Sep 24, 2007. 11:23 AM
As a bench jeweler, sometimes I had to weld links on light chains. I used a "Little Torch" oxy/acy rig. It was easy to accidentally melt work. If a light-chain link melted, it appeared the surface tension of the puddled gold could/would/did suck the free end of the chain right into the puddle -- a 12" chain became a 1/8th inch blob in half a heart beat. When soldering on light chains or in tight corners, I was taught to localize the heat by soldering thru the holes in a double-edged razor blade. The blade was clamped in a "third hand". Could electronic components be similarly protected when hot-air soldering?
OzzyRoo (author) in reply to airwelldrillerOct 22, 2007. 4:08 AM
that is my experience, despite trolls floating empty theories to the contrary ;)
dpocius says: Oct 10, 2007. 4:05 PM
Where I used to work (semiconductor R&D fab, long time ago) we had a similar device made of nichrome wire and quartz tubing. The wire was coiled in a 1/8" or so coil, then wound into a helix which was then stuffed into a 1/2" - 3/4" ID quartz tube. The end result looked like an old toaster heater element stuffed into a glass tube (Don't throw away that old toaster!). A handle was attached, and the back end was plumbed to a dry purified nitrogen source through rubber tubing and a needle valve to regulate the flow. The nichrome heating element was connected to a 120VAC variable autotransformer to control power. With a bit of fiddling, the gadget could produce a jet of 1000 C N2, useful for all sorts of things, like removing brazed-on caps on hermetically-sealed ICs. Ours was homemade, but I seem to recall GTE Sylvania made one also.
OzzyRoo (author) in reply to dpociusOct 22, 2007. 1:39 AM
sounds like my beast ;)...maybe mine wasn't a world first after all...;P
The Lightning Stalker says: Sep 23, 2007. 6:04 PM
How would you keep the nuts and bolts from loosening up from the thermal expansion/contraction?
OzzyRoo (author) in reply to The Lightning StalkerOct 22, 2007. 1:37 AM
there is none
meritsetgo says: Oct 3, 2007. 9:57 PM
this fyi for those who wonder why we would need such a thing. It is great for removing paint, caulk, adhesives, etc from surfaces without using chemical strippers. You could also use it to kill weeds (poison ivy anyone?) in your yard (patio, driveway, etc) without using chemicals. If you ever need to strip paint from furniture or any wood surface that you want to restore this is a great alternative. This tool also helps you collect salvageable electronic parts by quickly desoldering them from pcb boards (i know, it is redundant to say "boards").Turn the board upside down and a quick blast of hot air will melt the solder freeing the parts before the solder has a chance to re-harden but before you damage the parts themselves from the high heat. Finally it is a great tool for soldering those pesky plumbing copper fittings in tight areas where using an open flame torch might risk a fire.
OzzyRoo (author) in reply to meritsetgoOct 22, 2007. 1:35 AM
EXACTLY!!!!!!!!!!!!!!!!!!!!!! ...you guessed it, ova my dummy spit from the trolls earlier :) BIG BIG THANKYOU for saying it for wot it is... "Turn the board upside down and a quick blast of hot air will melt the solder freeing the parts before the solder has a chance to re-harden but before you damage the parts themselves from the high heat"
OzzyRoo (author) in reply to OzzyRooOct 22, 2007. 1:37 AM
thinks I betta be polite and read the comments and reply after several months absence
dfowler7437 says: Sep 22, 2007. 12:21 AM
This is a great project, well done.
I bought a heat embossing tool for about $20 that will do a simular job. Here is a link describing a SMT soldering process using one of these heat guns. There is a video of a board being soldered there as well. SMT Tools
DrStoooopid says: Sep 20, 2007. 3:29 PM
What's the application for this? Please excuse my ignorance. What's a hot air soldiering iron for?
OzzyRoo (author) in reply to DrStoooopidSep 20, 2007. 6:33 PM
making coffee
DrStoooopid in reply to OzzyRooSep 20, 2007. 6:59 PM
no I'm serious....what is a hot air soldiering iron used for? I know what a soldiering iron is used for, but what benefit does the air give you? Why would you use it over a regular one?
ac-dc in reply to DrStoooopidSep 20, 2007. 10:44 PM
A hot air gun, without modifications mentioned, is good for heat shrink tubing. A hot air soldering station is used when a part has multiple joints that need melted simultaneously for removal (repair work or prototypes, for example), or when the discrete part has leads/contacts/etc that are not accessible with a soldering iron.
This hot air technique is not a substitute for normal soldering of leaded or surface mount parts. That is true even if it were a controlled temp which this is not. This hot air hack could be a useful addition to your soldering tool set, but never a replacement for a good soldering iron when one could be used instead.
OzzyRoo (author) in reply to ac-dcSep 21, 2007. 1:10 AM
correction....hot air technique by my experience is far better than traditional methods...more precise as outlined in my diy article and others by other geniuses...lmfao...replying to my messages too...quiet the TROLL
The Lightning Stalker in reply to DrStoooopidSep 20, 2007. 8:57 PM
SMT work and heat shrink tubing mostly.
OzzyRoo (author) in reply to The Lightning StalkerSep 21, 2007. 1:12 AM
plus other uses open to your imagination
1-40 of 78Next »
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
