3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
INSANELY HOT DIY Hot Air Soldering iron @ 15 Volts DC and 3.5 amps...PART II
Step 27This is it !!!
This is it !!!
The final unit with power and air nozzles exiting from the handle...thank you old scooter, you served me well ;)
2 comments
Apr 7, 2009. 9:31 AMgargoyle169 says:
When combined with a DIY reflow (toaster) oven, this tool can assemble PCB's with a .4 mm pitch, I would not go any smaller do to the constraint of temperature control being rather spotty in a DIY like this. (Somebody who has been working fine pitch since 1980 for gov/mil/ and now private sector.)
Sep 20, 2007. 3:29 PMDrStoooopid says:
What's the application for this? Please excuse my ignorance. What's a hot air soldiering iron for?
Sep 20, 2007. 6:59 PMDrStoooopid says:
no I'm serious....what is a hot air soldiering iron used for? I know what a soldiering iron is used for, but what benefit does the air give you? Why would you use it over a regular one?
Sep 20, 2007. 10:44 PMac-dc says:
A hot air gun, without modifications mentioned, is good for heat shrink tubing. A hot air soldering station is used when a part has multiple joints that need melted simultaneously for removal (repair work or prototypes, for example), or when the discrete part has leads/contacts/etc that are not accessible with a soldering iron.
This hot air technique is not a substitute for normal soldering of leaded or surface mount parts. That is true even if it were a controlled temp which this is not. This hot air hack could be a useful addition to your soldering tool set, but never a replacement for a good soldering iron when one could be used instead.
Sep 20, 2007. 8:57 PMThe Lightning Stalker says:
SMT work and heat shrink tubing mostly.
Jun 19, 2008. 1:37 PMDerin says:
coffee
Feb 3, 2009. 11:47 PMthe_mad_man says:
hair-drying. sorry i mean scalp burning
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
12
Author:OzzyRoo
Geologist buff with a flair for photography and mad creations
