IPhone 6 Lightning Port Replacement
88,397
15
4
Posted in TechnologyApple
Introduction: IPhone 6 Lightning Port Replacement
The purpose of this guide is to walk you through the removal and replacement process of the front display Panel for an iPhone 6.
Required Tools:
Required Parts & Materials:
iPhone 6 Charging Port- Space Gray
or
iPhone 6 Charging Port- White
Step 1: Removing the Front Display Panel
Start by powering off your iPhone. Working on your iPhone while it's powered on can cause an electrical discharge and damage components of the phone.
  • Start off by using your Pentalobe screwdriver to remove the two screws on the bottom of the phone next to the Lightning connector.
Step 2:
  • Use the suction cup to lift the screen.
  • Firmly secure the suction cup to the screen, while holding the iPhone down with one hand, use your other hand to pull up on the suction cup with firm and constant force until the screen opens.
    • You can also use the suction cup to create enough space in-between the screen and the bezel so that you can insert your plastic spudger and gently pry up on the screen to fully open the phone.
Step 3:
  • Use one hand to hold the iPhone screen open.
  • Remove the five #00 Phillips screws that secure the display cable connector shield and set them aside:
    • Three 1.2 mm screws
    • One 1.7 mm screw
    • One 3.1 mm screw
  • Do not mix these screws up. They are different sizes and may not fit properly if you misplace them in the screw hole during reassembly. I find that placing the screws on your workstation in the orientation they were removed next to the component they secured helps with reassembly.
Step 4:
In the next few steps, be careful while removing the cables to only pry up on the cable connectors, and not the sockets on the logic board.
  • Use the flat end of your spduger to disconnect the home button cable connector by gently prying it up.
Step 5:
  • Use the flat end of your spudger to gently pry loose the front facing camera connector.
Step 6:
  • Use the flat end of your spudger to gently pry the LCD display data cable loose.
Step 7:
  • Use the flat end of your spudger to gently disconnect the digitizer cable connector.
  • Remove the screen assembly from the rear case.
Step 8: Removing the Lightning Connector Port
  • Remove the two Phillips screws from the battery connector bracket:
    • One 2.2 mm screw
    • One 3.2 mm screw
  • Remove the battery connector bracket and set it aside.
Step 9:
  • Use the flat end of your spudger to disconnect the lighting connector cable and fold it out of the way.
  • Use your spudger to gently pry loose the battery connector. Be careful to only pry up on the connector and not the socket.
Step 10:
  • Remove the four screws securing the loudspeaker to the back case:
    • Two 2.9 mm screws
    • Two 2.3 mm screws
Step 11:
  • Use the point of your spudger to disconnect the antenna cable from the logic board.
  • Pull the loudspeaker out of the phone, the antenna cable will slide free of its slot in the speaker.
Step 12:
  • Remove the two 1.6 mm screws that secure the vibrator. Set them aside.
  • Remove the vibrator and set it aside.
Step 13:
  • Remove the two 3.1 mm screws securing the lighting port retaining bracket.
  • Remove the retaining bracket and set it aside.
Step 14:
  • Remove the two 1.7 mm screws securing the lighting port, right below the screws for the retaining bracket.
Step 15:
  • Remove the two 1.5 mm screws securing the lightning port, located right below the screws you removed in the last step.
Step 16:
  • Remove the single 3.6 mm screw securing the microphone brace.
  • Remove the black microphone bracket and set it aside.
Step 17:
  • Remove the two 3.1 mm screws securing the headphone jack.
Step 18:
  • Use the flat end of your spudger to pry loose the microphone from the back case. The microphone is held down by adhesive.
Step 19:
  • Start to loosen the lighting connector cable by pulling up on the connector slightly and sliding your spudger beneath it. Slowly work your way around underneath the cable, prying up slightly to release the adhesive.
  • Remove the lightning connector from the iPhone back case.
Step 20: Reassembly
  • Remove any plastic film covering on your new lightning connector. Place it inside the back case and align it according to the screw holes.
Step 21:
  • Replace the two screws that secure the headphone jack.
Step 22:
  • Set the microphone brace in place.
  • Replace the 3.6 mm screw securing the brace.
Step 23:
  • Replace the two screws near the bottom of the lightning connector.
Step 24:
  • Replace the two screws right above the ones in the last step.
Step 25:
  • Place the lightning cable connector bracket in its place.
  • Replace the two screws that secure the bracket.
Step 26:
  • Place the vibrator in place inside the back case.
  • Replace the two screws to secure the vibrator.
Step 27:
  • Place the loudspeaker in place ontop of the lightning cable.
  • Thread the antenna cable through its recess in the loudspeaker. Connect the antenna cable to its connector, make sure the cable is lined up with the connector before pressing on it.
Step 28:
  • Connect the lightning cable connector to its socket, using your finger to gently press it in.
  • Connect battery connector cable by using your finger to press it into socket.
Step 29:
  • Place the battery connector bracket in place and replace the two screws that you removed earlier.
Step 30:
  • One by one, connect all four cables to their socket. Use your finger to gently push the connectors into place.
Step 31:
  • Set the connector shield in place and replace the five screws that held it in place.
Step 32:
  • Begin closing the iPhone by first fitting the lip of the top of the front panel display into the grove in the rear case.
Step 33:
  • Start to close the front display, press firmly on both sides of the display along the edges so that it goes in.
  • The display should go in fairly easily. If it doesn't, remove the display and attempt to realign it making sure that the lip on the top of the display fits in the groove on the back case.
Step 34:
  • Replace the two Pentalobe screws on the bottom of the iPhone next to the lightning port.
Step 35:
  • Turn the iPhone on and test that it functions properly. If the iPhone doesn't initially turn on, try hard reseting the phone by holding the power button and home button until you see the Apple logo.
  • Make it Move Contest
  • Microcontroller Contest
  • Woodworking Contest
    Woodworking Contest
4 Comments
Excellent instructions. I would just make one suggestion. It is wise to disconnect the battery before disconnecting the LCD and to leave it so until everything is reconnected. A dropped screw or static can cause a short if the iphone is accidentally switched on. I have repaired over 100 iphones and will always do this to be safe.
Great instructions. I like the fact that you put it back together instead of saying "just do things in reverse".
But, I've been trying for over an hour to get the antenna connector back without success. Have the speaker out and may try it with the speaker in... very frustrating.
Interesting conclusion. After getting ready to give up making the antenna connection, I tried the old antenna connection and it popped onto place on the first try. Then tried the new connection and it popped into place on first try. Maybe something misaligned, old connector maybe helped realign so new connector now worked. Everything back together and working perfectly.
Thank you so much for this! I ordered a replacement battery and charge port for an iPhone 6 and followed your instructions. You have put a lot of work into such detailed instructions, that it makes it very easy for an amateur geek like me to help others. I am hoping this poor phone works after this. If not, I will have to use my "Expert Google" skills again!
