Introduction: IPhone Cable Repair(or Any Other Cable)
Picture of IPhone Cable Repair(or Any Other Cable)
Hello! This is my first instructable. I'd like to share my process of repair broken cable's insulation.
You know how apple's cable can be corrupted easy, so if can't use them carefully, you shoul do this first.
Step 1: Heat Shrink Stretch
Picture of Heat Shrink Stretch
I took white heat shrink pipe 5 mm diametr. This color looks better, right? =)
You ask me - how it is possible, 5mm does not fit! Here is a little trick. We need stretch it.
And because it so small, after heat up it will fit very tight.
Cut about 2 cm. Put on scissors and pull in different directions very carefully. Pipe can break.
You need repeat it twice for both ends with rotation on 90 degrees after first stretch.
Step 2: Put It on and Heat Up
Picture of Put It on and Heat Up
The easiest part. Just don't overheat all.
Step 3: Done!
Picture of Done!
You can repeat this many times and use different sizes of heat shrink if you want reinforce it better.
GeorgeD67 (author)2016-06-23
Really good tip about shrink cable stretching ! I bought a lot of this and it is all too small, so now I can use it. Thank you !
DIY Hacks and How Tos (author)2016-06-20
That is a good trick to know. Iphone cables are notorious for breaking.
Right... Apple make them so. But this is the best and cheapest way to fix it. I hope everyone will like it. It is even possible use stamping on hot heat shrink for more personalization.
About This Instructable
1,020views
16favorites
License:
More by KotPomojnyj:IPhone cable repair(or any other cable)
Add instructable to:
