I've always loved close-up photography starting with a book I remember from first grade on spiders. I actually couldn't get past the first few pages of the book without freaking out and slamming the book shut, but I always came back for more.
About a year ago I made a clip-on lens for my iPhone and everyone is always asking me where I got it. It's very easy to make with just a few tools and materials. I'm not the first person to make one of these, but this is my take on it.
Step 1: Gather the Materials and Tools
The first thing you need to do is gather the materials and tools for assembling the lens.
Tools: pliers, small drill bits, X-Acto knife and/or saw, fine metal file and/or sandpaper, hair dryer or heat gun, tweezers, wire cutters
Materials: 4" of .04" music wire, disposable camera, 1/16" heat shrink tubing (4"+, 1 or more colors), super glue or RTV, O-ring assortment
The camera can be one that you have and have used up and removed the film, or you can ask for a used one from a one hour photo lab.
Step 2: Cover and Bend the Wire
Take a length of the music wire and slide a 4" length of the heat shrink tubing over it and heat it up. The tubing will shrink and hold on to the wire.
Snip the wire to length (4"), if you haven't already before covering the wire with the heat shrink.
Using the pliers, shape the wire as shown in the photo. Each of the sides should be about 1/2". You will make a total of six 90 degree bends. Be careful about squeezing the wire too much with the pliers; they will damage the heat shrink around the tubing. Put a couple of layers of tape around the jaws of the pliers, if that helps.
Step 3: Add the Heat Shrink Banding
Cut some 1/8" long pieces of heat shrink in different colors. This will be for the banding on the wire, which will help hold it on the iPhone, keep it from scratching the phone, and make it easier to see when you misplace it. (That will happen A LOT).
Slide the pieces onto the bent wire and use heat to shrink them in place. Don't try to do them all at once, they will slip out of place.
Step 4: Salvage the Lens
Start to crack open the camera. There are two parts you want off of it: the lens and the outside bezel. The bezel will probably be part of the whole front plate. Try to choose a camera with a bezel that is small enough to use. The one I found has a bezel about 3/4" in diameter.
Pry open the clips. There should be two on either end of the camera.
Take out the lens and set it aside.
Cut the bezel off the front plate. The plastic will probably be thin and it should cut easily with a small X-Acto saw blade.
Step 5: Clean up the Bezel
Smooth the back of the bezel with a piece of sandpaper or a file.
Step 6: Glue the Lens and O-ring
Drop the lens into the bezel and make sure there aren't any little tabs or standoffs preventing the lens from seating into it for gluing.
Apply a VERY small amount of glue and place the lens in the bezel with tweezers. Too much glue will create a haze on the lens and get all over the place. If you are at all worried about hazing the lens, use an industrial white glue or RTV. Allow time for it to cure before proceeding.
Find an o-ring that will fit into the back of the bezel and around the lens. This will help hold the lens in place when on the phone.
Glue the o-ring in place. Use super glue or RTV. RTV will take a couple hours to cure, at least.
Step 7: Finish Bending the Wire
Fit the bent wire on the phone and make where the arms pass the lens on the phone. You will want to make 90 degree bends here and then trim the wire.
Bend the wire as shown in the photo and clip. Leave about 1/8" after the bend.
Trim off a bit of the heat shrink and shrink a little band around the cut end.
Step 8: Prepare the Lens for Mounting on the Clip
Drill two holes into the edge of the bezel 180 degrees opposite each other. The hole should be a snug fit for the wire. You can use a short piece of the wire for a drill. The clipped end of the wire should be sharp enough from the wire cutter. Or you can heat the wire and plunge it into the bezel and melt the holes.
Attach the bent wire clip to the bezel. That's basically it! Mount the lens to the phone for a final fit check.
Step 9: Use It!
Go take pictures! The great thing about the lens on the iPhone is that it will allow you to take ground level shots, which is perfect for macro photography.
You can see more on my blog, Sir Richard's Tool Kit.
satiutni says: Jul 17, 2012. 9:38 PM
Hi this looks great!
What focal distance does it achieve - I'm looking for something that would scan micro QR codes at very short distances on things like brochures.
appsman says: Nov 8, 2011. 11:20 PM
I played around with paper clips and similar hacks. This one is pretty cute, but if you want something a bit more robust and cleaner looking, take a look at this 3D printable iPhone 4 macro lens holder you can get from Shapeways:
http://www.instructables.com/id/Make-an-iPhone-4-or-4S-slide-on-macro-lens/
iectyx3c says: Jul 27, 2010. 5:25 PM
There are so many good things about this i'ble. Well-written, clear, good photos, and many tips about building which any hobbyist can use. Thanks for all the work you did in creating this and posting it.
Pfarmkid in reply to iectyx3cOct 10, 2011. 6:33 PM
ditto
TabbyDeAnne says: Jun 16, 2011. 8:15 AM
FANTASTIC!! I am getting to this one right now! Very well done! I have several different lens ideas to try today. I will post my finished project! Thanks!
dickens.joey8 says: Jul 28, 2010. 11:42 AM
respected sir hw can u take a photo with out any rills otherwise ur invention is very gud
IamTheMomo in reply to dickens.joey8Jun 10, 2011. 9:47 AM
No one knows what you mean by "rill". What is a rill? I think you're using the wrong word. Speak English, not text-speak. If you can't, then get an adult to spell it properly for you.
wagthedog44 in reply to dickens.joey8Jul 29, 2010. 9:02 AM
joey, please, for everyones reading pleasure, try to use spellcheck and grammar. It's sad to see people comment in "text speak"
dickens.joey8 says: Jul 28, 2010. 11:39 AM
mr rvogel i did not understand that in your experiment(invention) how cum u can take a photo with out any rill
XOIIO in reply to dickens.joey8May 16, 2011. 9:32 AM
bit of advice, use the proper spelling of come, the other one could get you in trouble sometimes.
shrimp15 in reply to dickens.joey8Jul 30, 2010. 2:13 PM
what is a rill?
WingDings in reply to shrimp15Aug 4, 2010. 9:19 AM
Wikipedia told me that "In fluvial geomorphology, a rill is a narrow and shallow incision into soil resulting from erosion by overland flow or surface runoff that has been focused into a 'thin thread' by the soil surface texture of roughness." Not that that helps very much. :P
DirtMcGurt says: Jul 27, 2010. 8:06 PM
This is an awesome idea and I will def try it, but it would probably be a good idea to add a warning about opening up disposable cameras. The capacitors used for the flash are pretty dangerous.
cole810 in reply to DirtMcGurtFeb 28, 2011. 6:46 PM
Well, idk man, I took one apart right after I used the flash and I had white dots in my eyes, biggest shock of my life haha
trebory6 in reply to DirtMcGurtJul 29, 2010. 12:54 PM
Dangerous? Not really. Hurt like heck? Yeah. I mean sure, it would be dangerous for children and maybe people with pacemakers, but the volts and amps are much lower than a taser or stun gun last time I checked.
daiatlus79 in reply to trebory6Feb 2, 2011. 7:30 AM
yeah i gave my self a lil owwie when i disassembled one for an atomic joy buzzer hahaha
dot communist says: Sep 12, 2010. 8:27 PM
This is amazing, I am VERY impressed!
Pictures i took:
http://www.facebook.com/album.php?aid=2053888&id=1285468375&l=9b4b934d43
prodo123 says: Jul 26, 2010. 4:07 PM
Looks like you can do this with a heat shrink-covered paper clip. Freakin awesome.
RVogel (author) in reply to prodo123Jul 26, 2010. 4:16 PM
That could work. Music wire is a bit more resilient in the long run and getting bumped around in your pocket. A paperclip is an excellent option, especially when salvaged from the junk drawer. Thanks!
joelparks in reply to RVogelJul 30, 2010. 6:10 PM
I would use a recycled bicycle spoke, since I have some. Nice and stiff, and recycled!
Coliopteran says: Jul 29, 2010. 11:08 PM
Great idea! I'm going to try this!
technodude92 says: Jul 29, 2010. 7:39 PM
Very good instructable! this would be great for creating insctructables too. i've seen way too many insctructables with bad close-up shots resulting from a lack of proper camera. this is a great little mod. I must ask, did you use this lense to take pictures for this instructable?
spiderham says: Jul 27, 2010. 6:31 PM
Great ible, this is one I'll be trying out soon! Could you please post a pic of the lens placement on the phone?
castothomas says: Jul 26, 2010. 11:49 PM
coolness, what type of camera did you get the parts from?
RVogel (author) in reply to castothomasJul 27, 2010. 7:59 AM
It's just a disposable Fuji camera.
omnibot in reply to castothomasJul 27, 2010. 12:24 AM
Looks like a generic disposable camera. I've done similar things with ducttape and lenses from those, this one is much cooler though.
nickodemus says: Jul 26, 2010. 2:52 PM
Such a great idea, and simply executed, nice work.
GianniMora says: Jul 26, 2010. 2:14 PM
really rad concept! -M
GianniMora says: Jul 26, 2010. 2:11 PM
ironic, u use a camera to take a picture of a camera... -M
Kiteman says: Jul 26, 2010. 1:47 PM
This is cool (even though I don't have an iPhone).
The project itself is well-executed and illustrated. Well done, that ibler!
RVogel (author) in reply to KitemanJul 26, 2010. 2:05 PM
Thanks! This can be made to work on any cell phone. If the lens is too far from the edge to use a clip, then you can just use removable double-stick tape. I use it a lot when i can't find the clip-on lens.
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
