loading
I take lots of notes and I had the need to scan them quickly so you can consult online. Any scanner was too slow to digitize many hundreds of pages of my moleskine. Taking a good photo was a good solution. I thought I'd use my iPhone for this purpose. They needed a support that does not give problems of shadows and it was simple and stable.
This is the final result.
To create this scanner for iPhone I used:
1 sheet of 10mm FOREX feather or similar material on the size 60x40cm
1 cutter
1 iPhone cover
hot glue
Step 1: Bridge
The FOREX feather is a light material consists of a sandwich of PVC with polyurethane inside.
I cut the pieces as the attached pdf.
Dashed lines were cut with angles from 45 ° so as to leave a layer of PVC does not cut that will support the next bend.
Step 2:
Even in the large rectangle cuts have left a layer of PVC cut to fit at best the bridge.
Step 3: Stand
The cover of the iPhone has been glued with hot glue in the bridge and the bridge was glued to the base.
And here is the scanner iPhone in all its glory to transform in digital any sheet, book or note.
After we take photos. What's the free program to covert the photos to small pdf file with one page only.
<p>it is awesome but i was completely lost you when you said &quot;Dashed lines were cut with angles from 45 &deg; so as to leave a layer of PVC does not cut that will support the next bend&quot;</p><p>so pls help me out !!! :)</p>
<p>This is a awesome Scanning technique by iPhone </p>
<p>nice </p>
<p>I can figure it out myself but it would be alot more convenient if there were measurements. strawberry66 above referenced 60x60 and 60x40 but where did those measurements even come from?</p>
You know there is a note book called the leuchtturm1917 whitelines link. It has paper designed to interact with an iphone/android app which can basically scan your page really quickly and then save it as a PDF. See this link http://www.thepaperie.co.uk/brands/leuchtturm1917/whitelines-link
<p>I think you have made a mistake on the raw sheet size?</p><p>Is it 60x60 not 60x40</p><p>I bought 60x40 and cannot see how to get the peices on it?</p><p>Thanks</p><p>Nick</p>
there is no pdf attached here.. plz upload it..
Been designing one of these myself, yours is simpler and better looking, good job.<br> As an alternative to FOREX there is another sign board that has corrugated PVC in the middle layer that would work with this design too.<br> Two of my favorite aps &quot;Genius Scan&quot; and &quot;Image to Text&quot; would work well with this. I guess that &quot;Camera+&quot; would be handy too because it has a timer function =&gt; no camera movement from touching the camera while taking the shot.<br> Just wondering how big the field of view is at the height you have the iPhone?
there is a program for the android its called &quot;camscanner&quot;. i use it on my phone works great. you can convert pics to pdf.
very nice instructables!
You do realize that this can be used for other smart phones such as the Galaxy note 1 which I have and created something almost exactly like what you did.
*e-high five* I made one for my galaxy note too!!
I second 'dobbler's suggestion of camscanner. I have the pro version and it can take multiple shots in a row, and convert to pdf nicely. I then share to Evernote which OCRs the text making it searchable. I love the simplicity of your stand, also that it packs flat. Good for travel and storage as needed
Tiny scan app too
This is very nice contraption, but I`m just bit worried that without hight adjustment for phone it will be calibrated only for one size of documents or (if you use zoom) it will lack on quality. <br>
Great idea! Now take it a step further by inventing a folding version which can be easily transported or stored in a bookshelf.
Nicely done, thanks for sharing.
simple yet creative, well done !
Such a clean design. Very Apple
It will be when he charges $80 for it. <br> <br>lol
... and when it starts blocking the cell phone's antena.
Nicely done. Very simple and straight forward!
Hey what a great idea. I built a microscope adapter for use with my Iphone and works great so I know this also must give you nice shots.
Nice job! I made one out of cardboard from this: <a href="http://www.ponoko.com/design-your-own/products/iphone-document-scanner-eps-file-1835" rel="nofollow">http://www.ponoko.com/design-your-own/products/iphone-document-scanner-eps-file-1835</a><br> <br> Have you tried <a href="https://itunes.apple.com/app/camscanner-pro/id395904807?mt=8" rel="nofollow">CamScanner</a>?- Probably the best app for scanning &amp; managing docs.. There's also a <a href="https://itunes.apple.com/app/camscanner-free/id388627783?mt=8" rel="nofollow">free version</a>
Tank dobbler, i use Evernote with the function adjust the border of the page
if you want to take the drag out of clicking, get the imotion HD app. it does timelapse with intervals anywhere between 0.5 seconds and 1 day. that way you only have to flip the pages and not press the photo button. <br> <br>good idea by the way. i take a lot of pics this way too from my sketchbook. hadnt really thought of this!
I like it... but I need to rethink it for portability... taking it to the library or class!
If you need to hold the book flat for the picture, a small but heavy sheet of glass can help. But then you have to be careful about how it is lit because of glare.
THANK EVERYONE! I send soon the PDF with the meausure. . 28x7 + 4x7 + 28x7 slant 5 cm.
Neat idea! Would be nicer to have had the measurements (even in cm's) of the base and the stand, or is that included in the &quot;paid-for&quot; version?? <br>Bruce
Very clean, indeed. Great work!<br/>And hooray for the Maker Notebook =D
Yes, this is good idea, and I must try it.
Great idea and well done!
This may be a good solution for my art classroom. I am implementing online portfolios and will be scanning lots of artwork.
About This Instructable
57,777views
939favorites
License:
Bio: In addition to performing full-time job of "shaman" of the Italian community of Technological Craftman, engaged in research, training and dissemination of culture in Visual ... More »
More by giovannire:shining names with rhinestones IPhone Scanner Bas-relief mirror
Add instructable to:
