Introduction: IR Home Automation Using Arduino
Follow This Steps And Convert Your Home To Smart Home
Step 1: Use 12 V 1 or 1.5 Amp Power Supply
Picture of Use 12 V 1 or 1.5 Amp Power Supply
Step 2: Make 12 V to 5 V Converter Circuit Component List
Picture of Make 12 V to 5 V Converter Circuit Component List
component list
1 multipurpose circuit bord
2 capacitor 470uf ,1uf
3 diode in4007
4 ic LM7805
5 transistor bc547
6 relay 5v
7 arduino uno
8 any remort
9 tsop 1738
10 arduino ide software for mac/windows
Step 3: Connect of TSOP 1738 to Arduino
Picture of Connect of TSOP 1738 to Arduino
Step 4: Downlod IR Decord.ino File From Here
Picture of Downlod IR Decord.ino File From Here
IR DECORD.INO
Use arduino ide softwere open ir decorc.ino and upload to bord
if you have any error like (C:\Program Files (x86)\Arduino\libraries\RobotIRremote\src\IRremoteTools.cpp:5: error: 'TKD2' was not declared in this scope) so downlod ir Library from here http://sh.st/J8DWM and extrect and past to C:\Program Files\Arduino\libraries
after problem not solve downlod this libraries http://sh.st/J8Gf5 and past on same path
Step 5: Open Seriel Moniter(ctrl+shift+M)
Picture of Open Seriel Moniter(ctrl+shift+M)
press button from remort and note down received code
like 16220287
16187647
16244767
16195807
16228447
Note down same code recived from pressing one button
Step 6: Download Final Home Automation.ino
Picture of Download Final Home Automation.ino
home automation.ino
Downlod code and upload to bord change define code to your remort code
Step 7: Joint This Circuit for Use Reley (make Your Own Relay Bord for On/off Home Application)
Picture of Joint This Circuit for Use Reley (make Your Own Relay Bord for On/off Home Application)
Step 8:
About This Instructable
467views
13favorites
License:
More by jaypatel05:IR Home Automation Using ArduinoArduino Mini Stable Power Supply IR Based Home Automation Using Arduino
Add instructable to:
