IR Detector
IR Detector
In this Instructable I will show you how to make a simple infra red (IR) detector.
When your TV stops responding to the remote it is hard to tell if the TV is broken or the remote doesn't work. With this little pocket-sized gadget you will know.
Spying has become more and more accessible to the average man. Whit this gadget you can check if someone has installed a night-vision camera in you room or office.
First I am going to show you how to build it and then how to use it.
If you are just interested how IR remote control works got to step 7.
Step 1Electronic Components
For this project you will need a couple of electronic components,all in total 3$.
1. Fototransistor (IR_Transistor);( in this chase I used RadioShack 276-0145);(picture 2)
2.LED
3.Micro switch.
4.330 Ohm resistor (picture 3)
5.An electronic solder board (holes)
6. 9V battery snap
7. 9V battery
8. Rubber band
(all of the electronic components can be bought at your local RadioShack)
443 comments
1-40 of 443next »
Feb 7, 2012. 7:10 AMondrikczech says:
can i use led from tv remote as ir transistor?
Jan 17, 2010. 2:36 PMstephenniall says:
WIll the red Led Flash to the binary code preset into the remote ?
Say if 1 is on and 0 is off If the code was 1 1 0 0 1 0 1 Would the Led go on on off off and so on
May 3, 2011. 12:27 PM372jpeg says:
if you replace the led with a buzzer it would be pretty cool it be like beep, beep, off, off, beep, off, beep
May 4, 2011. 5:05 PMGoodhart says:
With a buzzer, depending on what kind you refer to, it may need it's signal amplified or converted from a pulsed DC to a waveform (if the buzzer or beeper runs on low voltage DC, then you can ignore everything I just wrote :-)
May 6, 2011. 2:21 PM372jpeg says:
i was thinking a low voltage one but thanks for the tip :)
May 6, 2011. 4:42 PMGoodhart says:
Well, by low, I meant "very" low :-) There will be less then 3 v running through the LED, so it'd have to operate in that kind of environment
Mar 12, 2011. 3:00 PMelectric_piano_5k says:
I once took an old remote from a broken DVD player and took out the IR LED and soldered in a green LED. Then I could see the remote flash as I pushed the buttons. And if you wave the remote around, you can see the 1100101 patterns and you can see that they are different when you push different buttons. Of course only do this with a remote that you no longer need, not a good idea to do this just to find out if the remote is working!
Jan 17, 2010. 3:30 PMstephenniall says:
Ahh thank you . Will be going to maplins tomorrow to buy the components for this
Jan 17, 2010. 4:23 PMstephenniall says:
will post a picture tomorrow if i finish it !
Apr 28, 2011. 5:48 PMChowmix12 says:
is it tomorrow yet?
Sep 17, 2010. 2:20 AMvectrasj says:
All respects!
But You do not need to built this!
Reason:
- You have a mobile phone with camera (any format)
- Turn Your camera on mobile phone ON
- Point camera at front of remote (20-30cm)
- press button on remote
- if button send IR command You will SEE white beam from the IR LED!
- Repeat press all buttons on remote and check IR LED response !
MOBBILE PHONE CAMERA SEE IR LIGHT !
May 4, 2011. 5:31 PMGoodhart says:
One reason TO make this is to have a seperate circuit to work with for other projects: sound sources, turning on or off other switches, etc with IR, ...there are a host of reasons TO build this; even if only to learn how it works.
Nov 7, 2010. 1:04 PMaccount3r2 says:
some people dont have a camera and i think this is a neat project
Oct 29, 2010. 10:24 PMdawsonj says:
most cameras see infrared light
Jan 16, 2009. 11:27 AMHycro says:
I once had a stereo that if I were to hold the switch on my halogen bed lamp close enough to the on position that it would make the light flash, I could make my stereo open/close the CD drawer, or even change the volume, depending on how close or far the contacts of the switch were apart.
May 4, 2011. 5:23 PMGoodhart says:
I wonder if one of the LED's isn't "detecting" the signal? That can happen, but normally only if there is a voltage already applied to the circuit.
Jul 30, 2010. 12:50 PMArduino Guy says:
possibly the halogen lamp emits a flickering ir signal (all heat consists of ir rays)from the mains 60Hz/50Hz and then the device gets "confused"?
Jul 30, 2010. 7:26 PMHycro says:
Sounds very likely...I didn't know then what I know now about that kind of stuff, though it's marginally more now...XD
Jan 16, 2009. 3:54 PMHycro says:
Oh likely, but it was still neat to do. I think the stereo that did it was the one I also blew the amp in...
Jan 17, 2009. 6:15 AMHycro says:
I had so many speakers connected in parallel that the resistance went below the amp's tolerance, and since it was under warranty, I didn't take it apart to see exactly what happened, but it likely overheated, and probably didn't have an automatic thermal shut-down, I tried it the next day, and still didn't work. It was designed to use a 6 ohm speaker per channel, and I had 6 or 7 8 ohm speakers connected in parallel, thereby reducing the resistance, essentially shorting the amp, or even overheating it. That's another reason why I like the amplifier ICs for car stereos, they have internal short and thermal overload protection, and operate at anywhere from 11VDC to 18VDC without damage, though the manufacturer states the optimum performance is usually at ~13.4VDC to ~15VDC. (Manufacturer states that is the standard charging voltage for a lead-acid battery being charged by the alternator in the car.)
Jan 17, 2009. 12:00 PMHycro says:
Yea, most car stereo amplifier chips that I've researched have that capability.
Dec 27, 2010. 1:40 PMjack002 says:
I use my camera in my phone. You dont even have to take a pic, just look at the screen while holding the remote towards it.
May 4, 2011. 5:17 PMGoodhart says:
This works with most digital cameras
Dec 30, 2010. 11:46 AMThe Incredible IT Maker says:
so............ does this mean in theory you could build an ir aray on any digital camera and have a night vision camera?
May 4, 2011. 5:16 PMGoodhart says:
Yes.
Mar 31, 2011. 6:00 AMphevtron says:
ok but whats the range? can be used to switch lights etc?
May 4, 2011. 5:15 PMGoodhart says:
If you used a relay it might be possible.
Apr 15, 2011. 12:25 PMtechno guy says:
Isn't 9 volts a little too much for LEDs even if you have a 330 ohm resistor? Unless the ir transistor provides a lot of resistance.
May 4, 2011. 5:12 PMGoodhart says:
It depends on the amperage rating of the source, the voltage drop across the LED, and the amperage rating of the LED.
Apr 15, 2011. 12:32 PMtechno guy says:
If it measures heat, then can you replace the red LED with an analog meter and measure heat?
Mar 30, 2011. 12:28 AMcrtn2 says:
you can use 3V button cell battery to make this thing smaller.
(replace 330 ohm resistor with lower value for voltages <4.5V)
Nov 7, 2010. 1:11 PMaccount3r2 says:
please respond quick, what voltage do the leds need to be?
Dec 30, 2010. 11:34 AMThe Incredible IT Maker says:
usualy around 3 volts at the most
Nov 27, 2010. 9:11 AMMadScientist101 says:
wat stops it from sensing other light sources, why deos it only detect IR
1-40 of 443next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
55
Author:comodore
stanislav.drca@yahoo.co.uk stanislav.drca@gmail.com ______________________ One of my favorite inventors, and one of the most brilinat minds that ever walked the Earth is Nikola Tesla. Here are some T...
more »
