When your TV stops responding to the remote it is hard to tell if the TV is broken or the remote doesn't work. With this little pocket-sized gadget you will know.
Spying has become more and more accessible to the average man. Whit this gadget you can check if someone has installed a night-vision camera in you room or office.
First I am going to show you how to build it and then how to use it.
If you are just interested how IR remote control works got to step 7.
Remove these ads by
Signing UpStep 1Electronic Components
1. Fototransistor (IR_Transistor);( in this chase I used RadioShack 276-0145);(picture 2)
2.LED
3.Micro switch.
4.330 Ohm resistor (picture 3)
5.An electronic solder board (holes)
6. 9V battery snap
7. 9V battery
8. Rubber band
(all of the electronic components can be bought at your local RadioShack)
http://electric-kids.blogspot.com/
Say if 1 is on and 0 is off If the code was 1 1 0 0 1 0 1 Would the Led go on on off off and so on
But You do not need to built this!
Reason:
- You have a mobile phone with camera (any format)
- Turn Your camera on mobile phone ON
- Point camera at front of remote (20-30cm)
- press button on remote
- if button send IR command You will SEE white beam from the IR LED!
- Repeat press all buttons on remote and check IR LED response !
MOBBILE PHONE CAMERA SEE IR LIGHT !
(replace 330 ohm resistor with lower value for voltages <4.5V)
