3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
IR Detector
Step 5Put it all togother
Put it all togother
  • last photo ←
First take the Fototransistor,bend it (picture 1) and solder it. (picture 2)
Now take the LED and solder ti. (picture 3)
Take the resistor and connect the negative(shorter) pin of the fototransistor and the positive(longer) pin of the LED whit the 330 Ohm resistor,(picture 4) and cut the pins.(picture 5)
Solder the switch in between, a little bit down.
Now take the 9V battery clip and cut it about the lenght so that you can connect it to the switch and the fototransistor. Save the black wire from the battery clip because you are going to need it.(picture 6)
Connect the black wire from the clip to the switch, and the black wire that you saved, from the switch to the negative(shorter) side of the LED.(picture 7)
Connect the red wire to the remaining pin,the positive(longer) side of the fototransistor.(picture 8)
9 comments
Aug 21, 2010. 7:53 AMaviksaras says:
is it necessary to use only that fototransistor? i have used a cheaper one it is a sensor the shopkeeper told it little bit works like IR sensor
Apr 2, 2010. 11:52 AMjules15 says:
i did this, it didn't work..
Jan 2, 2010. 11:38 AMnorthconnor says:
I thought that was pretty good for someone who doesn't speak English...
Jul 5, 2008. 10:57 PMneardood says:
Just a bit of advice, use the spell check option, cause reading that many unintentional mistakes on one page gets annoying
Dec 2, 2008. 4:08 PMDYLEGO says:
al i c is 3 speling mestakes adn teh fototransistor mestakes sorry i had to so that!
Dec 2, 2008. 4:14 PMDYLEGO says:
had to DO that
Dec 2, 2008. 8:55 PMmunchman says:
Yeah, you kind of went back on yourself with that one.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:comodore
stanislav.drca@yahoo.co.uk stanislav.drca@gmail.com ______________________ One of my favorite inventors, and one of the most brilinat minds that ever walked the Earth is Nikola Tesla. Here are some T...
more »
