3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
IR Detector
Step 8Test your creation
Test your creation
You are all done!!! Test you creation!
Take any remote. Put you fototransistor close to the IR LED of the remote. Push the switch,hold it, and push any button on the TV remote,hold it. The LED on the detector should start blinking.
IR light is not visible by a naked eye but you can see it whit a camera also! (picture 3)
39 comments
Mar 15, 2012. 2:32 PMNorikaeru says:
I got a detector out of a a vcr that was being thrown away and when the switch is pressed the led lights up and stays that way with or without any tv remote, could the ir transistor be broken to just let current flow?
Jan 16, 2009. 11:27 AMHycro says:
I once had a stereo that if I were to hold the switch on my halogen bed lamp close enough to the on position that it would make the light flash, I could make my stereo open/close the CD drawer, or even change the volume, depending on how close or far the contacts of the switch were apart.
May 4, 2011. 5:23 PMGoodhart says:
I wonder if one of the LED's isn't "detecting" the signal? That can happen, but normally only if there is a voltage already applied to the circuit.
Jul 30, 2010. 12:50 PMArduino Guy says:
possibly the halogen lamp emits a flickering ir signal (all heat consists of ir rays)from the mains 60Hz/50Hz and then the device gets "confused"?
Jul 30, 2010. 7:26 PMHycro says:
Sounds very likely...I didn't know then what I know now about that kind of stuff, though it's marginally more now...XD
Jan 16, 2009. 3:54 PMHycro says:
Oh likely, but it was still neat to do. I think the stereo that did it was the one I also blew the amp in...
Jan 17, 2009. 6:15 AMHycro says:
I had so many speakers connected in parallel that the resistance went below the amp's tolerance, and since it was under warranty, I didn't take it apart to see exactly what happened, but it likely overheated, and probably didn't have an automatic thermal shut-down, I tried it the next day, and still didn't work. It was designed to use a 6 ohm speaker per channel, and I had 6 or 7 8 ohm speakers connected in parallel, thereby reducing the resistance, essentially shorting the amp, or even overheating it. That's another reason why I like the amplifier ICs for car stereos, they have internal short and thermal overload protection, and operate at anywhere from 11VDC to 18VDC without damage, though the manufacturer states the optimum performance is usually at ~13.4VDC to ~15VDC. (Manufacturer states that is the standard charging voltage for a lead-acid battery being charged by the alternator in the car.)
Jan 17, 2009. 12:00 PMHycro says:
Yea, most car stereo amplifier chips that I've researched have that capability.
Mar 31, 2011. 6:00 AMphevtron says:
ok but whats the range? can be used to switch lights etc?
May 4, 2011. 5:15 PMGoodhart says:
If you used a relay it might be possible.
Jul 14, 2010. 2:15 AMbestboy5408 says:
Ÿý= =
Jan 16, 2010. 4:24 AManil yadav says:
actually i made one ir detector by reading your instruction but it is not working so pl ans my few question?
is the blinking of led can be seen by naked eyes ?
actually i tried to test but the led doesnt blink so is there is any other way to test the ir detector?
Mar 3, 2010. 8:57 AMizidor7 says:
I actually can see a red like light... but, it is visable only in a darker place... toher technik..
Take your cell phone and watch through the camera... you'll see the lila light on the screen!!!!!
Feb 4, 2010. 9:47 PMamitdas says:
your led must be damaged..coz i tried n its working perfectly...
Jul 5, 2009. 1:26 PMw477s says:
Hi, can i use reversed IR led diode instead of IR phototransistor?
Jul 10, 2009. 6:50 AMSmokedasphalt says:
yeah, you can...!
Oct 10, 2009. 1:37 PMryguy425425 says:
so is that just an IR diode wired backwards? Instead of waiting for a response I think ill just go ahead and try it...
Oct 11, 2009. 6:58 AMSmokedasphalt says:
Oh, I thought he meant an IR photodiode. An IR led wired backwards won't work.
Nov 23, 2009. 5:03 AMw477s says:
ir photodiode != ir led diode? holly crap -.-
Oct 12, 2009. 2:17 PMryguy425425 says:
Too late! good think I have 20.
o_Ops! xD i have about 40 of them :S
May 27, 2010. 11:49 AMbigstiffy says:
A IR led wired backwards will actually work, at least it did for my circuit (although I used a different schematic). Here's the schematic I used if you're interested: carlitoscontraptions.com/2007/09/ir-detector/
Sep 7, 2008. 8:34 AMgeeklord says:
so if you took out the IR LED in a remote, hooked it up in a circiut with a 3V source, and a switch, and pressed the switch on and off in binary code, you could potentially control any IR device as long as you knew what the code was?????I am so smart......:D
Oct 25, 2009. 6:54 AMuberdum05 says:
In theory, you could. But in reality, your finger would have to touch the button 38,000 times per bit ! Or, just set up a 555 timer to do the 38Khz part
Sep 12, 2008. 4:11 PMkadris3 says:
at 3 vdc you might want less resistance. try 47 ohms(40 calculated). IR leds have a much lower forward voltage than all other LEDs. one batt(1.5vdc)might work if only left on for a short while. usually IR has a 1.2 vdc forward voltage or about that. also a phototransistor has 3 leads. there is no connection to the base. u can do the same w a photodiode which only has 2 leads.
Sep 7, 2008. 7:10 PMS1L3N7 SWAT says:
No, unless you can tap out binary code ridiculously fast. Your remote sends out the pulses rather quickly, so you probably wouldn't be able to do it your self, it needs a microcontroller and what not to work.
Sep 8, 2008. 5:48 PMgeeklord says:
But in theory, you could if you or something else could tap it out
Aug 22, 2010. 11:01 AMnatman3400 says:
In theory yes, yes you could tap it out.
Jul 30, 2010. 12:41 PMArduino Guy says:
you can use an arduino or pic microcontroller of something similar(eg; seeduino, lilypad, freeduino...) and program it to send codes, this instructable,http://www.instructables.com/id/Fart-Operated-Random-Channel-TV-Remote/, helps a bit (Whithout the fart sensor) or http://www.arcfn.com/search/label/arduino also's ok. but, for this you need intermediate programming knowlege and one of the devices listed above. anything else is probably futile.
Apr 18, 2009. 7:29 AMfarhan77 says:
that was a neat instructable! what i was wondering, was that what is the range of this phototransistor? what i had in mind was to hook up a small low voltage relay instead of using an LED. With this simple circuit i can use relay where i want a PUSH Switch kinda functionality. But that depends on the range of the circuit! any idea how long with this fototransistor will detect a general remote control beam(signals, pulses) :)
Jul 5, 2008. 11:02 PMneardood says:
that poor indicator LED looks a bit strained, maby you should add a more powerful resistor??? If not, the LED will eventualy die, as it is when u leave it on it'l get hot.
Sep 12, 2008. 4:24 PMkadris3 says:
if the battery were new and the forward voltage of the IR LED is 1.2vdc then 390 ohms is needed. with the battery @ about 7.2vdc the 300 ohms is the correct figure. simple circuit that works: good instructable
Aug 20, 2008. 1:56 PMRGM La Paz says:
so this can control your tv sorry its that im a curious year old and i just started learning this cool stuff
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
56
Author:comodore
stanislav.drca@yahoo.co.uk stanislav.drca@gmail.com ______________________ One of my favorite inventors, and one of the most brilinat minds that ever walked the Earth is Nikola Tesla. Here are some T...
more »
