iImage Information
first order of buisness lets get all the materials you can use anythign for the body i simply used old vex parts that came with the plastic black holders and the hex nuts and bolts, i am salvaging the switch and batterie holder the wires and connectors already came with it, the other nut and bolt i believe to be 3/8 in but its universal for all cameras so you should be able to find one that fits yours, and some zip ties
Step 1Addding the LEDS to the lego pieces
iImage Information
first order of buisness lets solder the LEDs together lets get all the positive sides on one side and the negative the positive side will be the wider part with the small cone shape on top. well on the other i added solder to a pice of wire and then soldered the wire on the the LED i did so for both sides and with all the way across on all 6 LEDs. Simply repeat this step to get your second strip. the LEDs shouldnt come out but for that simply add hot glue on the the back and they should stay in place the white conector was already one the white batterrie holder so i juset used it but if yours doesnt have any simply do it directly to the batterie holder (wires go from the LEDs to the batterie holder and switch)
