IR-Modification of the Nikon 4300
 by andyk75
Featured
This is the description of how to turn a normal working Nikon 4300 into a IR-Camera for fantastic new insights.
The Nikon 4300 is now roundabout eight years old and you can get the used camera rather cheap. I hope the prices will not rise too much because of this instructable. The quality of this camera is really good and so you can expect to have another few years of fun with your new IR-Camera.
Only disadvantage: It uses Compact flash for storage.
Advantage: The age. The older the camera is the simpler is it built. In 2002 there were a lot of parts much bigger than today, maybe except the display. That means it is much easier to dis- and reassemble this camera than an up-to-date model. If you need more Megapixel try to modify an Nikon P6000 and write an instructable. ;-)
Second advantage: The filter-adapter. For many modern cameras you won't find a good solution to attach a filter to the camera, and for IR photography you need a real good connection without light leaks.
Ah, before I forget it: NO, this is not thermography! It uses only light up to 900nm, much to short for thermography. They use 1400nm and more...
benkwright says: Jul 6, 2011. 4:57 PM
Thank you for this DIY modification. Instead of using regular glass I purchased some 590nm Filter glass from Edmond Optics. I cut the glass then used a sander to make the size fit just right. This is similar to the Life Pixel Super Color IR Filter. Did a custom white balance, and they are turning out just like on Life Pixel. No additional filter need on the end of the lens. Awesome.
SirStokes says: Feb 14, 2011. 6:47 PM
These are awesome! I did this with a 1.3mp camera so I don't get the best results.
Trenatos says: Aug 8, 2010. 7:13 PM
Has anyone tried the http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1918 filter? Wouldn't that work to take IR-only photos?
andyk75 (author) in reply to TrenatosAug 9, 2010. 4:19 AM
These filters should already give you a significant IR-effect, I just checked out the transmission curves and they look suitable. Transmission starts at about 700nm, which includes a bit of a dark red. IR starts around 780nm.
For a stronger effect I would suggest these: http://www.edmundoptics.com/onlinecatalog/displayproduct.cfm?productID=1493
They start at 750nm and 800nm respectively and so they appear nearly black, not dark red as the other ones. But their price is also a bit higher.
It should be possible to get a 52mm IR-filter from ebay for less than 40$.
urbangenie says: Aug 5, 2010. 8:34 AM
Are you able to post a photograph showing where the capacitor is? Or is it really obvious?
FLIGHT505 says: Aug 3, 2010. 7:26 PM
Do you know if this works with other cameras?... Actually I tried it with an old easyshare cx7430, I found the same IR filter (or so I thought) removed it and put it back together... camera still take normal pics, not the IR pics you listed. I guess its a long shot but do you have any idea y it would do this? Did I take out the wrong filter or are there multiple filters in some cameras?
andyk75 (author) in reply to FLIGHT505Aug 3, 2010. 10:49 PM
Well it should work will all CCD-sensor cameras in the same way. And normally there is only one filter right before the chip, but I wouldn't bet my life for it. CMOS-Sensors are not so sensitive to IR as CCDs, the effect is much weaker. But your camera has a CCD-sensor, so it should work.
For to take those IR-pictures like in step 10 you need an IR-transmission filter. For a first test you could try to use the overexposed rest of a normal film when you get it back from processing. Or combine a red and blue color filter. That should bring you further to the desired result.
FLIGHT505 in reply to andyk75Aug 4, 2010. 3:31 PM
Thanks for your help man.. But yeah i think I'm just going with buying an IR filter for my other camera. Good instructable though!
Pro
Get More Out of Instructables
Already have an Account?
close
PDF Downloads
Upgrade to Pro today!
