IR Remote Control For12 Home Appliances
21,072
36
Posted
Introduction: IR Remote Control For12 Home Appliances
IR Remote Control for 12 home appliancescan be easilly made using a TSOP 1738 IR receiver, some 5V relay and a Arduino Board.
By using this circuit you can easily control your home applinces using your TV, DVD Player remote control.
Step 1: To Get Remote Control Switches Codes
Just make the connection as it is shown in above pictures. and upload the arduino code. and when you press any button then in serial monitor window you can see the HAX value and a number value. you can either choose HAX value for you next procedure or the number value.
Step 2: Code to Get HAX/number Value
#include<IRremote.h>
int RECV_PIN = 11;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
Serial.begin(9600);
irrecv.enableIRIn(); // Start the receiver
void loop() {
if (irrecv.decode(&results))
unsigned int value = results.value;
Serial.println(value);
Serial.println(results.value, HEX);
delay(250);
irrecv.resume(); // Receive the next value
Step 3: Try With Some LED's First
Now you are ready with your codes/values. now select your those key/ switches in remote which is not currently in use. Take the values of those keys and according to your preference put it in next coming code at the place of mine. and upload the code to arduino.
First you try with 3 LED's and check is it working properly
or not. If it is working then go with the next pictures.
Step 4: Code for LED's
#include
int RECV_PIN = 11; // the pin where you connect the output pin of TSOP4838
int led1 = 2;
int led2 = 5;
int led3 = 8;
int itsONled[] = {0,0,0,0};
/* the initial state of LEDs is OFF (zero)
the first zero must remain zero but you can
change the others to 1's if you want a certain
led to light when the board is powered */
#define code1 32895 // code received from button A
#define code2 16575 // code received from button B
void setup()
Serial.begin(9600); // you can comment this line
pinMode(led1, OUTPUT);
pinMode(led2, OUTPUT);
pinMode(led3, OUTPUT);
void loop() {
if (irrecv.decode(&results)) {
switch(value) {
case code1:
if(itsONled[1] == 1) { // if first led is on then
digitalWrite(led1, LOW); // turn it off when button is pressed
itsONled[1] = 0; // and set its state as off
} else { // else if first led is off
digitalWrite(led1, HIGH); // turn it on when the button is pressed
itsONled[1] = 1; // and set its state as on
break;
case code2:
if(itsONled[2] == 1) {
digitalWrite(led2, LOW);
itsONled[2] = 0;
} else {
digitalWrite(led2, HIGH);
itsONled[2] = 1;
break;
default :
if(itsONled[3] == 1) {
digitalWrite(led3, LOW);
itsONled[3] = 0;
} else {
digitalWrite(led3, HIGH);
itsONled[3] = 1;
break;
Serial.println(value); // you can comment this line
delay(250);
Step 5: LAST PART
If you are successful in LED's part then you are ready for applying on your home appliances.
Here i have selected only two home appliances and a LED for ERROR showing.
we don't need to change the code for the relay part
THINGS NEEDED TO MAKE THIS PROJECT:-
1. Arduino board
2. 5V Relays as much you need
3. IN4007 Diode in number of Relays
4. TSOP 1738 IR Receiver
5. 1 LED or 1 Buzzer with 100Ohm resistor
I will upload my working project in some days as I'm working on PCB Layout. I made this project but it is too messy.
  • Remote Control Contest 2017
  • Arduino Contest 2017
  • LED Contest 2017
    LED Contest 2017
Questions & Answers
3 Comments
This is a very cheap Project. You can make it.
thanks buddy.. hope you made it..
