3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
IR Remote Control Jammer
Get your own IR Jammer Kit here.
Look at the IR Jammer project page here.
The IR Jammer is a fun project that provides a bit of safe, non-destructive fun. The Infrared Remote Control Jammer allows you to render all IR remote controls inoperative! The microcontroller in this design allows for all 6 of the main IR frequencies to be targeted making this unit universal. It works by corrupting the data that is being sent by your normal remote controls.
A single press of the button sends out stream of IR pulses from the two narrow beam and two wide beam IR LEDs for 30 seconds. Each press of the button will add 30 seconds to the running timer. For remote operation you can simply connect a button to the On Sw. pads, shorting this input will turn on the IR output until the contact is opened. This would allow the device to be mounted into an old remote, brim of a hat, etc.
The compact design is the size of a 9 volt battery allowing it to be strapped directly to its power source if desired.
Step 1IR Jammer Overview
IR Jammer Overview
The heart of the IR Jammer is a PIC 12F675 microcontroller. This microcontroller has been programmed to reproduce the 6 popular IR frequencies, 30kHz, 33kHz, 36kHz, 38kHz, 40kHz and 56kHz. When the button is pressed two transistors are used to pump infrared data out of the 4 IR LEDs. Using two wide beam and two narrow beam IR LEDs allows good distance and a ease of use. The Green LED is used to indicate power up by blinking 3 times and also to indicate when the jammer is running by a quick flash ever few seconds. When building the kit you can select the power selection resistors to adjust the balance between range and power consumption.
16 comments
Nov 1, 2011. 1:13 PMashannon1 says:
could i build this on a bread-board?
Nov 2, 2010. 11:24 PMhipydude2001 says:
well it was issued to me in millitary for if we got lost but that was back in 03-04 so i dont think it will be bad to show this but its not working. I think it got fried some how or i left it on to long, eithor way it doesnt work any more ..heres a pic , and its also encoded in some kind of plastic and its called a PHOENIX TRANSMITTER-VISIBLE says for like tapping to vehichles and such or getting rescues attention but it does have differnt patterns. 9v like the above model.So what do you think by the pictures? ow and first pics ive now added to i'bles!
Nov 28, 2010. 4:38 PMthebig1 says:
Thats an IR "illuminator" by the description so that SAR can "see you" from the air without alerting any unfriendly forces who dont have the right equipment. With an IR camera. the illuminator would look light a bright flashing beacon and very easy to spot but remain invisible to the naked eye
Apr 23, 2011. 3:23 AMWally_Z says:
I'm pretty sure most if not all cameras can pick up IR light.
Jun 22, 2011. 4:45 PMraykholo says:
True. That's a great way to test if tv remotes are working, by the way. Apparently, from what I've heard, some new high quality cameras come with infrared filters, but I've never come across any such cameras.
Nov 2, 2010. 4:00 PMhipydude2001 says:
so thats what in the world that thing is , i got one of those years ago but never really knew what it was for. heh so how can i test myne out to see if its the same thing? looks like it with the leds and to turn myne on you touch metal to meatl and differnt touches couses different patterns.
Nov 3, 2010. 3:57 PMhipydude2001 says:
good news....the batteries i were using were dead,stuck em to my tounge and noothin,so found a good on and 3 9vs battt. later got it to work, and the programing is with short or long for up 20 secs, and if you short it for longer than 20 secs it displays a constant red light.. Now i tested to see if there were any anonamalys with a am radio but couldnt pick any thing up until it seemed only when the red light was on the antenna? YOU would be my hero if you could explain some simple and crude uses for this purticicular devise and even if it is any thing near what yours is? thank you.
Dec 11, 2010. 4:49 PMfreezier says:
use a cheap webcam or digital camera to look at it while it is on. if it is working, there will be a redish or purpleish light coming out of it. it may even flood the ccd with so much infrared that the entire screen turns white. note- some cameras have an ir filter that will filter out most if not all of the light, so if it doesn't work, test the camera on a known working ir source- like a remote.
Dec 11, 2010. 5:00 PMfreezier says:
i believe you have one of these
http://www.nitevis.com/IR14_PhoenixJr_Beacon_detail.htm
Dec 14, 2010. 3:32 PMhipydude2001 says:
yea i got one of those ir remote helecopters for indore use only and i think the signals being jammed..last night it was fine but now i cant get it to work for nothing..and thats pretty impressive you found the nsn number.. whish i could get my old tool box. ):
Nov 2, 2010. 4:09 PMhipydude2001 says:
yea you can use this to put it on a car or somem like dat
Nov 2, 2010. 11:30 PMhipydude2001 says:
jees i should read this more carefully says its a beacon and can penatrate duct tape and many layers of close.. wish it still worked, Wonder why it doesnt any more.And this design is completly water proof.
Nov 2, 2010. 11:27 PMhipydude2001 says:
the descriptions is more for tracking a vehicle rather than cancelling out irs so i think that this myte be the venome to your antidote
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
46
Author:abbtech(Hacked Gadgets)
You can see my blog here: http://hackedgadgets.com and my personal site here: http://alan-parekh.com
