IR Remote Controlled Robot
Introduction: IR Remote Controlled Robot
hello guys..
this is our new project thats called ir remote controlled robot using arduino.
thats controlled by any remote...we have used as ir remote...
so lets start.
Step 1: Components
1:-arduino uno(Arduino UNO R3)
2:-ir remote
3:-l293d ic(Embeddinator's L293D Motor Driving Module)
4:-infrared receiver(TSOP1138)
5:-mini breadboard(170 Points Mini Breadboard for (For Arduino) Proto Shield (Works with Official (For Arduino) Boards))
6:-jumper wires(Robo India JW-C3 Jumper Wire - 10 Male to Male + 10 Female to Female + 10 Male to Female)
7:-two dc motors(REES52 BOSET BO Motor 100 RPM 2 Pieces + BO Wheel 2 Pieces + BO Motor Clamp with Screws 2 Pieces)
8:-one chassis(Super Jumbo Chasis (Color May Vary))
9:-two wheels with caster wheel
10:-9v battery or power bank
*********(if you want to buy this product with low price from amazon,plz click on this components)
Step 2: Infrared Connection
we have used as infrared receiver TSOP1138
one pin is connect to gnd....
and vspin is connect to +5v
and out pin connect to arduino...
so lets connection with arduino and ir receiver..
Step 3: Ir Receiver to Arduino
here see this pic..
ir receiver is connected..
two pins are connected to +5v and gnd..
another third pin is connect to arduino 6pin....
thats easy connection,you can try on breadboard..
Step 4: L293d Ic Connection
if you use l293d ic instead of l293d motor driver..
even its will be easy for connection....
l293d ic have 16pin...
1,8,9 and 16 pin connect to +5v.
and 4,5,12,13 pin connect to gnd...
input 1,2,3 and 4pin is connect to arduino pin..
output is connect to left motor and right motor..
input 1 and 2 is connect for left motor..
and input 3 and 4 is connect for right motor..
Step 5: Integrating Everything
infrared receiver output pin is connect to arduino 6pin..
pin 2 of l293d is connect to 8pin of arduino
pin 7 of l293d is connect to 9pin of arduino
pin 10 of l293d connect to 10 pin of arduino
pin 15 pin of l293d connect to 11 pin of arduino..
thats easy connection you can do..
Step 6: Ir Recdemo Library Uploading
click this link..and download ir remoter master zip file...
add this file to arduino uno..
at 1st ir recv demo code to arduino and compile..
then connect to your battery...
1:-Upload the given code into the Arduino
2:-Open the serial monitor.
3:-Press different remote keys and obtain their hexadecimal values.(Note that the values will not be obtained with 0x which represents hexadecimal also some values are obtained in middle like FFFFFFFF, ignore them).
Here I have obtained
the values of the front,back,left,right and middle keys which are
These values of these buttons are mapped to move front,move back,move left,move right and stop respectively.
Step 7: Uploading Main Code
now..copy the code below..
and paste to arduino...1st compile then upload
int lm=9;//pin 9 of arduino to pin 7 of l293d int lmr=8;//pin 8 of arduino to pin 2 of l293d int rm=10;//pin 10 of arduino to pin 10 of l293d int rmr=11;//pin 11 of arduino to pin 15 of l293d
int RECV_PIN = 6;//pin 6 of arduino to data pin of ir receiver IRrecv irrecv(RECV_PIN); decode_results results;
void setup() { pinMode(lm,OUTPUT); pinMode(lmr,OUTPUT); pinMode(rm,OUTPUT); pinMode(rmr,OUTPUT); Serial.begin(9600); irrecv.enableIRIn(); // Start the receiver }
void loop() { if (irrecv.decode(&results)) { Serial.println(results.value, HEX); irrecv.resume(); // Receive the next value } //bot moves front if(results.value==0x807F20DF) { digitalWrite(lm,LOW); digitalWrite(lmr,HIGH); digitalWrite(rm,HIGH); digitalWrite(rmr,LOW); } //bot moves back if(results.value==0x807FA05F) { digitalWrite(lm,HIGH); digitalWrite(lmr,LOW); digitalWrite(rm,LOW); digitalWrite(rmr,HIGH); } //bot moves left if(results.value==0x807F609F) { digitalWrite(lm,LOW); digitalWrite(lmr,HIGH); digitalWrite(rm,HIGH); digitalWrite(rmr,HIGH); } //bot moves right if(results.value==0x807FE01F) { digitalWrite(lm,HIGH); digitalWrite(lmr,HIGH); digitalWrite(rm,HIGH); digitalWrite(rmr,LOW); } //bot stops if(results.value==0x807F10EF) { digitalWrite(lm,HIGH); digitalWrite(lmr,HIGH); digitalWrite(rm,HIGH); digitalWrite(rmr,HIGH); } }
soo....we are making this video by connecting arduino cable..for serial monitor show..
also you see this pic of serial monitor....
Step 8: Result
here this video link help you to make this project easily.....
also you can follow s_r tronics on you tube ...
sooo...follow this link..and subscribe our channel..
and do likes and comments alsoo..
next project coming soon......
    • Science of Cooking
      Science of Cooking
    • Trash to Treasure
      Trash to Treasure
    • Paper Contest 2018
      Paper Contest 2018
