Control Toy Car Using Ir Technology
Published
Introduction: Control Toy Car Using Ir Technology
About: As an eee engineering inquisitive about science and technology. And for me everything is some how related to science. So you need to know everything.....something! ?
Inspired from my last project Segway, this instructables is all about a toy robot car controlled using T.V ir remote. I would use it to controlling segway with this stuff in the next one . Ok its all done with the help of arduino and ir sensors. The toy car can also vary its speeds using 4 speed levels you can find it in the VIDEO.
Step 1: You Need This!
All you need for this project is
Arduino,
TV remote (ir)
L293D driver shield
2 BO motors and wheels
,2 9V battery,
IR sensor TSOP SM0038
Wires etc.
Driver shield using motor driver L293D can be made easily using circuits from net I have ready made.
Step 2: Just Build It..
Prepare robot base using cardboard; set motors and wheels as adjustable. I have not used balance wheel as it wont required.
You need to add IR remote library for programming
Find codes of your IR remote using examples of IR remote library.
#include
int RECV_PIN = 12;
IRrecv irrecv(RECV_PIN);
decode_results results;
void setup()
{ Serial.begin(9600);
irrecv.enableIRIn();
void loop() {
if (irrecv.decode(&results))
{ remote = results.value;
Serial.println(remote);
irrecv.resume();
Step 3: Program It
Forgot about connections! is very simple connect as below
//motorn pins
PWM 5-- left motor input 1
PWM 6-- left motor input 2
PWM 9-- right motor input 1
PWM 10-- right motor motor input 2
//IR receiver
Arduino pin 12--output of IR
+3vcc--- Vcc of ir
GND-- gnd of ir
I have attached the codes you can directly upload it
#include
int RECV_PIN = 12;
int remote = 0;
int spd = 0;
int s1 = 100;
int s2 = 150;
int s3 = 200;
int s4 = 250;
void setup()
pinMode(5, OUTPUT);
pinMode(6, OUTPUT);
pinMode(9, OUTPUT);
pinMode(10, OUTPUT);
Serial.begin(9600);
irrecv.enableIRIn(); }
void loop() {
irrecv.resume();
if (remote == 10965)
spd = s1; }
else if (remote == 26775)
{ spd = s2; }
else if
(remote == -22441)
{ spd = s3; } else if
(remote == 2805)
{ spd = s4; }
if (remote == 22695)
{ analogWrite(5, spd); digitalWrite(6, LOW); digitalWrite(9, LOW); analogWrite(10, spd);
} else if (remote == -7651)
{ digitalWrite(5, LOW); digitalWrite(6, LOW); digitalWrite(9, LOW); analogWrite(10, spd); }
else if (remote == -8161)
{ analogWrite(5, spd); digitalWrite(6, LOW); digitalWrite(9, LOW); digitalWrite(10, LOW); }
else if (remote == 4845 ) { digitalWrite(5, LOW); analogWrite(6, spd); analogWrite(9, spd); digitalWrite(10, LOW); }
else if (remote == -16321 ) { digitalWrite(5, LOW); digitalWrite(6, LOW); digitalWrite(9, LOW); digitalWrite(10, LOW); }
Step 4: Play Time
Turn power on and first select the speed level 1,2,3or 4 otherwise it won't work simple pressing forward reverse button.
Please comment if you liked it.....
    • Oil Contest
      Oil Contest
    • Make it Move Contest
    • Woodworking Contest
      Woodworking Contest
