IR Wireless Temperature Sensor With ATtiny85
Introduction: IR Wireless Temperature Sensor With ATtiny85
Arduino is simple and very powerfull open source/hardware platform where only your imagination can stop you.A few days ago I read an instructable that inspire me to do my own.The instructable is about how you can send strings of data from one arduino to another.Everything is ok but I wanted to make it with Attiny85 .but unfortunately libraries are not supported with this microcontroller.So, I need to find a way how to generate 38khz and send modulated data and how to translate those data.I'm not enough pro :) to know how attiny85 to generate 38khz itself so I used old good one 555 timer.Everything is good but now I must to send data somehow.There are 3 possibilities:
1-By controling reset pin of the 555 timer
2-switching on/off power supply of 555 timer
3-switching on/off LEDs(timer is always on)
I used 3th variant.
Let's start!
Step 1: Parts List
Microcontrollers and timers:
1x555 timer
1xATtiny85(you can use any microntroller from Attiny family)
Resistors and trimers/pots:
1x10k trimer/pot
Any pnp/npn transistors.In this project I used 1xBC547(npn) and 1xBC327(pnp)
LM35DZ couse it's easy to use
LEDs and transmitters:
Any IR leds.
You can use any ir receiver.Why??Because you can tune to the right frequence 555 timer with 10k trim/pot.
*To be exactly 38khz you must to tune trimer/pot around 7.979k or just mesure frequency with multimeter
*Supply voltage can be everything between 6.8v-30v
*Attiny85 is running at 16mhz internal oscillator
Step 2: Shematic and Pinouts
Step 3: Transmitter Code
After you finished with circuit you must to upload some code..right? :D
In my project I used morse alphabet to send data.
There are two files, first one is little modified Morse library and the second file is main program.
I uploaded the code trought Arduino with tiny cores.
You can find it here:
Step 4: Receiver Code
It can be done a lot of optimizations.Because now you can only send numbers(in my case temperature).
Step 5: Update
Couple pictures how I integrated this circuit.
Step 6: Final Product
Basic characteristics:
Next goals:
Single chip solution, less power consuption
Please comment and share your ideas for improving this device.
Thanks for reading!
btw: English is not my native language so sorry for mistakes and etc.
    • Pocket-Sized Contest
    • Pro Tips Challenge
      Pro Tips Challenge
    • Paper Contest 2018
      Paper Contest 2018
    dude, in order to send 38khz with attiny85, you have to use an 8mhz crystal and you can control the IR leds using the PWM pins... there is some kind of math involved to divide the clock impulses but you're gonna make something nice.
    What is the function of the attiny in this circuit?
    Attiny read the temperature from lm35dz ,convert it to morse code and then send it to IR LEDs.
    Why not just send the data directly over IR?
    Because you need to generate 38khz and I don't know how to do it only with attiny85 without additional ICs.So to do the task I'm using 555 timer.
