Ice Candles
Introduction: Ice Candles
I never actually set out to make a ice candle. This project was created during one of my science projects for school. What we had to do was create an insulator for an ice cube, so innitally my idea was to make an ice pocket to put my ice cube in. Later I found that wouldn't work because it had to set out all day, but in the process I made a "cup" of ice so I thought it would be cool to put a candle inside.
All you need is a disposeable cup with a waxy covering, a larger plastic container, a candle, something to weigh down the cup, and some water.
you find this ineresting please vote for it in the "Lamps & Lighting Contest."
Also, here is a general warning when it comes to fire...
Never laeve a fire (or candle for that matter) unattended...
Even if it is surrounded by ice.
Step 1: Forming the Base
First put a little bit of water into the bottom of the plastic container. Leave it in a freezer unill it freezes
Step 2: Forming the Walls
Now put your weights into the cup, and take out your container with ice. Put your weighted cup in the center of your larger container. Fill around the cup with cold water (now you are dealing with ice that you don't want to melt) and put it back into the freezer
Step 3: Finishing the Candle
Take out your cup, it should slide out since the outside is waxy. Seperate your ice and your container. Place a candle into your cavity and light
NOTE: They do make eletric candles that imitate real candles, Do Not Use Those they will malfunction with the puddle of water forming in the bottom.
    • Pocket-Sized Contest
    • Paper Contest 2018
      Paper Contest 2018
    • Pro Tips Challenge
      Pro Tips Challenge
