Ice Cream Cone Planter
Published
Introduction: Ice Cream Cone Planter
About: Making for the Sake of Making
The Ice Cream Cone Planter is a simple project and I'm clearly no artist but I'm sure you get the point.
Step 1: Materials + Tools
Materials:
  • terracotta pot from Michael's
  • cactus from Lowe's
  • acrylic paints from Aaron Brothers
Tools:
  • paint brush (I used a sponge tip)
  • large sheet of paper
  • pencil
  • glove (if your plant is a cactus)
  • mixing bowl
Step 2: Paint the Tray
The large sheet of paper is just so you don't get paint and dirt all over the place. I started by painting the tray white so it looks more like chinaware. Set it aside and let it dry.
Step 3: Make the Waffle Pattern
Use the pencil to sketch a waffle pattern on the pot. Don't worry if your waffle sketch doesn't line up perfectly. Just like a real waffle folded over on itself, it's not supposed to! Mix brown and white paint to get a lighter brown. My brown turned out more of a grey. Don't be me. Paint over your waffle sketch and let it dry.
Step 4: Add Fudge and Sprinkles
Use brown paint to add some fudge on top. Let it dry for a little bit before adding the sprinkles. Yes, blue and yellow do mix to form green.
Step 5: Put a Plant in It
Use a glove if you're transplanting a cactus. Carefully remove dirt from the base to achieve the proper fit.
Step 6: Enjoy But Don't Lick
    • Backpack Challenge
      Backpack Challenge
    • Creative Misuse Contest
    • Water Contest
      Water Contest
