Ice Cream Glider
24,050
137
16
Published
Introduction: Ice Cream Glider
About: I am a happy go lucky person whose interests vary from aeromodelling, painting to micro-controllers and scrap building. I am a certified mechanical engineer and work in a Indian based IT firm. I also love bu...
Hi everyone
Was just trying to enter into micro/mini rc. So i decided to make a prototype model from stuff lying around. Will add radio control later. Right now its a simple glider what i intend to make.
Here is what you will require :
Ice-cream Sticks ... 0.06$ for 12
Cyano-acrylate glue ... 0.1$
A marker pen
Tracing paper
Cutter
Depron/ Biofoam plates
Step 1: Making Airfoil Ribs
Make airfoil shapes on the depron plates. I made a general shape as it is just a prototype. You can choose clarky-y profile. For beginners it is not much important to get the shape correct. Just make sure al the ribs when cut should be sanded to match each other perfectly.
Cut all the shapes carefully with a cutter..i made 8 four on each wing. After cutting all the airfoils..you can sand them to match each other...but i was lazy enough to do that. Once you are done with the airfoils,leave them aside for the time being..we will now create the fuse and wing structure with ice cream sticks.
Step 2: Making Wing Structure
Please be very carefull while cutting ice cream sticks...the proper way to cut them is similar to how we cut a glass. Just use many cutting strokes with small feed depths and then pop them into two.
Cut two ice cream sticks length wise at the middle. I used the max length i could get from one stick. So i now have 4 long half sticks. Take another full stick and cut it into two at the middle but not along the length...alongh the breadth...and then cut these 2 half sticks along the length....so now you have 4 small half sticks.
See the pics for reference.
Step 3: Adding Dihedral
Cut a slight bevel on the small half stick and join it with the full length one. see pics for clarifications. I used a standard 0.2$ cutter do do all the bevelling ans no sanding was done ever.
Repeat for all 4 sticks.
Step 4: Completing the Wing Structure
Now determine the chord of your wing and cut six pieces of the same length from the ice cream sticks. Join them to the main wing sticks as shown in figure. You need minimum 4 sticks or the structure will not be stable. The pic doesnt show the third and fourth stick but you can join it near the start of the dihedral and somewhere in the middle of the wing.
Step 5: Adding Airfoil Ribs to Wing
Now after your wing frame is ready...glue the airfoils..i used Cyano-acrylate glue for that. Refer the pic. Repeat these steps for the other wing. Make sure to make the join between the two wing halfs strong.
Step 6: Rudder and Stabilizer
Complete the horizontal and vertical stab on similar lines...refer the pic.
Step 7: Covering the Wing and Empennage
Use a standard tracing paper to cover the wings, rudder and the stabilizer. After covering each component glue the rudder to the stabilizer as shown in pic.
Step 8: Adding Dowels to Wing for Mounting
Just glue two stick at the underside of the wing. This will be used for mounting on the fuselage. Refer the pics for clarification.
Step 9: Fuselage
Take two ice cream sticks and glue them together to make a stick type fuselage. The glue the wing and the stabilizer/rudder assembly to the stick fuselage.
Add clay nose-weight to the fuse to adjust CG at around 30% of the chord to get optimal flight characteristics. You Ice cream glider is now ready to fly.
If you like my work do visit my website www.allthatido.com and help support me.
    • Clocks Contest
      Clocks Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    16 Discussions
    Faizi
    2 years ago
    laley flight video nahi hai koi ??
    Nice instructable, I'll surely try to make one. Wondering if
    instead of wood in the wing to use a thicker depron to make it lighter.
    Thank you so much for sharing!
    can u give the measurements for the width of the wing .Answer quickly please thanks :)
    Yes you could use a cling wrap used to cover food dishes..or use a heat activated covering like oracover, suncote, monokote etc
    1. Nice design!
    2. You would down the front edge of wings. Otherwise the glider tends to loop, that is not good for its reach.
    3. You would advantageously replace that heavy paper with food film.
    Hey rimar2000
    Thanks for the comment. The camera angle creates a slight illusion. The wing incidence is not as much as it seems to be in the pic. You can test with different wing incidence angled to get best result.
    And yes i plan to use cling wrap next time.
    Regards
    Ankur
    From the pictures of the completed airplane, it looks as though the wing's angle of incidence and that of the horizontal stabilizers are unequal. If that is the case, then the glider may be creating excessive drag and reducing its range as a result.
    Is the wing mounted as it seems? Or is it just an illusion?
    Hi OrigamiAirEnforcer
    The angle of incidence of the horizontal stabilizer is near to zero degrees but for the wing , there is some angle of incidence. The pic is partly confusing because of the camera angle.
    Regards
    Ankur
