Ice Drop
Published
Introduction: Ice Drop
About: Check out my website at liamshatzel.com and my YouTube at http://bit.ly/1AbjJkA
In this tutorial I will be showing you how to make this awesome ice drop so check it out and make sure to like subscribe and comment.
#P1XEL00
Step 1: What You Will Need
you will need:
  • A fridge
  • a balloon
  • water
Optional Circuit (Recommended for coolest effect.)
  • RGB LED or any color.
  • switch
  • 9 volt battery
  • resistor
  • 9 volt battery adapter
to assemble the circuit attach the black wire from the adapter to the resistor and then to the shorter leg of the led
then you attach the long led to either port on the switch except the middle one then attach the red wire to the middle and thats it.
Step 2: Fill the Balloon
fill the balloon with water and make sure to get as much air out as you can making sure not to spray water everywhere. now tie the balloon.
Step 3: Put the Balloon in the Freezer
now put the balloon in the freezer and use a butterfly clip to hang it so it is suspended.No wait for it to completely freeze.
Step 4: Unwrap the Balloon
now cut the balloon and it will peel off.
Step 5: Ice Massage
rub the ice so it becomes clear because after you take it out of the freezer it is frosted over.
(the tip broke off of mine but thats ok because it is ice and you can shape it.)
Step 6: Take Awesome Pictures
I used a flashlight to light this up and took close ups of it.
Step 7: Put the Circuit Under
put the circuit under the ice after you make an indent in the bottom with heat or a knife and now you have an awesome night light for your ice hotel or igloo or ice bar.
Step 8: Finish
this is also another picture of the ice drop outside
    • Creative Misuse Contest
    • Oil Contest
      Oil Contest
    • Water Contest
      Water Contest
    3 Discussions
