Introduction: Ichigo's Fractured Hollow Mask
I have been using Instructables for ideas on how to start projects I've had in mind for a number of years and I thought I would finally submit one. Considering I am currently helping my children with cosplay costumes for an up and coming anime convention, I thought I would submit an instructable on a mask I made for my son last year. I wish I took pictures while I was crafting the project but the images I've included should get the idea across
Step 1: Materials & Euipment
You will need :
1) a mime mask (Like the one worn by Jaberwakeez on American Best Dance Crew)
2) a pair of yellow tinted sunglasses (I used a broken pair I had on hand)
3) Bondo Automotive body filler
4) Scissors
5) Exacto (craft) knife
6) Red, white, & black acrylic paint
7) Sand paper
8) Dremel (this is optional)
9) JB Weld
Step 2:
Start with your mime mask. Draw the pattern of the fractured mask unto the mask with a sharpie or other flet tip marker. It doesn't have to be exact, remember this is a "fractured mask" and nothing ever fractures the same twice. Also draw an outline of the eye to match the shape of the picture.
Step 3:
Cut the pattern out with the scissors as well as the reshaped eye hole.
Step 4:
Next you will be using the Bondo. Mix small amounts at a time as this hardens pretty fast if you are not used to using this material. Spread it over your mask to about a thickness of 1/8 inch. Don't worry if its rough you will be smoothing it out with the sand paper later. Make the thickness at the lower edge about 1/4 inch with a width of 1-1 1/2 inch. Let mask harden.
Step 5:
Once the mask is hardened, sketch the outline of the teeth at the lower edge of the mask. Divide the space so that you have about 6 teeth drawn. You can use the craft knife or the Dremel with a pointed bit to shape the teeth (they should be rounded like vimpire fangs). Then sand the rest of the mask to smoothen. Dust of the mask to remove any debris from the shaping and sanding.
Step 6:
Now take the sun glasses and cut out the right lens. Position the mask over the glasses so the remaining lens sits in the eye hole ( You can use the craft knife to shape the eye hole to fit the lens better) and glue in place with JB Weld. Be carefull not to get glue on the lens.
Step 7:
Now paint the mask white. Use at least 3 coats,be careful not to get paint on the lens. and let dry. Carefully draw the striped patern on the mask and paint with red paint, again use 3 coats and avoid the lens, and let dry. Carefully paint a black border around the lens. one coat should do and let dry. I'v included a picture of my son using the mask at San Japan in San Antonio, TX.
