Original:
2 Meter: 144.0-148.0 MHz
70 Centimeter: 420.0-450.0 MHz.
Modified:
2 Meter: 118.0 - 174.0 MHz
70 Centimeter: 400.0 - 470.0 MHz.
Hopefully this will be the first of many ham radio related Instructables I will post.
Side note:
This modification should only be made in preparation for emergency situations where communications out of regular ham bands are necessary, at no other time should an amateur radio operator transmit on frequencies outside of ham bands.
Remove these ads by
Signing UpStep 1Step 1, Disassembly
Four above the battery compartment
Two at the top of the battery compartment
And two at the bottom of the battery compartment
Remove these screws and set them aside carefully so they don't get lost or knocked around and then proceed to step two.
To find the mod info for your radios visit
http://www.mods.dk
Not true.
If there is legitimate emergency that threatens life, a Ham can use any means available to summon help. If that means calling for help on the fire/rescue repeater input frequency, that's just fine w/ Uncle Charles.
This may not stop the local po-po from confiscating your HT, mind you, but what's more important than saving a life?
There use to be a question on this very topic for the Novice Amateur Radio exam.
