To avoid feature creep, I think several levels of dev-board would be a good idea. This page will describe my ideas for a level one board, I will add pages for additional boards as ideas arise.
Level one dev-board:Getting to know the PIC
The concepts conveyed by this board should seem overly simple.
This board could introduce:
Burning a firmware (with ICSP)
Turning a LED on and off
PWM (a LED)
UART
Comparators
Input interrupts
The 16F628(a) would be a great chip for this board. Its the successor to the famous 18f84, for which there are 100s of project examples on the web.
The 16F628a has a lot of great stuff not in the 84: hardware PWM, UART, internal OSC, etc. Its cheaper too!
Circuit wise (my laundry list of stuff):
A max202 and caps, serial connector.
A few resistors and LEDs (on some pins and PWM)
A few screw terminals - I think some pins, like the PWM, should have both a LED and a screw terminal. The LED can be removed if something external is driven.
Decoupling cap, MCLR resistor & ICSP diode.
Programming options:
I'm against putting a programmer on the board. Perhaps a small (socketless) JDM2 ICSP programmer can be designed for the project. These are often unreliable for beginners, but they can work great. I still haul them out when I need to see what went wrong with the ICD2.
Thoughts, suggestions?
The attached files are for a stripped down dev-board I made for a LED PWM chip from TI. This was the first 'real' electronics project I designed myself using datasheets. This is just an example and starting point, obviously its niether finished nor a very advanced use of Eagle...
Remove these ads by
Signing UpStep 1Dev-board level 2
the gold herarcal labels and right clicking to add the pins to the sheet.
It is in the kicad manual in the program under help.
Here is the link to my downloads:
https://sites.google.com/site/openloopproject/
https://sites.google.com/site/neurocyberprosthetics/
Anybody wants to sell this product? pls email at: ameriqbalqureshi@yahoo.com
The place I buy my chips from has the 16F628A for $3.18… and the 16F88 for $4.75
My favorite thing about the 16F88 is the commonly available bootloader. (I like being able to reprogram my chip in about a second.)
I would recommend one of two options for your headers…either run them to an edge (along with power) so that you can use daughter boards (see http://winpicprog.co.uk/pic_tutorial_hardware.htm for a fantastic demonstration)
Alternatively, you could place headers for all of the pins on the underside of the board… so that the entire board can be placed into a breadboard.
