3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Identity Preserving Balaclava (all the warmth with none of the anonymity!)
Step 5Sewing the pattern together
I made my own pattern for this project, and even though it seems to have worked pretty well, it can only be used as an approximation of what it should look like because everyone's head is different. So you will probably need to adjust this pattern to fit your own head, but here is what I did and here is what it looks like.
Starting with the straight-on image of the face cut out the eye hole and the mouth hole and make sure they line up with your eyes and mouth. To do this cut a cross-shape and sew down the flaps.
Then line up the profile images with the straight-on image of the face. To make sure you get it right, first line up the jaw lines on either side, then use the straight pins to pin them together at the seams.
Stand in front of the mirror and try wrapping the pinned together pieces of fabric to make sure they accurately line up with the features of your face and head.
This process will probably take a lot of trial and error.
Try and line up the images of the face straight-on, the left profile, the right profile, and the back of the head, so that they make a straight line that can been eventually sewn into a tube.
Once those images are lined up and sewn together, cut the fabric with the image of the top of the head into thirds the long way. Then cut the middle third in half, like a hamburger. Line up the four pieces with the strip of images you have already sewn together so that the image of the top of the head is the same length as the rest of the strip. Make sure to line up the image of the hair from the top of the head with the hair from the other angles of the head (see picture).
Finally cut up and sew the image of the neck and shoulders onto the bottom of the images that you have already sewn together. This part will take a little more judgment calls than the rest because the main purpose of this is just to add enough fabric to the bottom of the strip of images so that later you will be able to make an even hem at the bottom of the balaclava.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
Author:snag hazzard
