3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Ignition Coil High Voltage Display
A common automotive ignition coil can generate an output voltage on the order of 30,000 volts. This is a sufficient voltage to produce arcs which jump an air gap of an inch or more.  Driven properly they can also be used to create a Jacobs Ladder display
Ignition coils are inexpensive and readily available, and constructing a circuit to drive the coil is straightforward.
This article provides an overview of ignition coil operation, as well as a drive circuit design and system capable of driving the coil to produce arcs for your entertainment and experimentation.
Of couse, as with any high voltage project, safety warnings are in order.  Excecise caution and good sense when working with high voltage.  Remove power from the system before making adjustements.
Don't touch the arcs.  Be mindful that the potentials generated can jump a significant gap, and that insulation on tools like regular pliers may be inadequate to prevent you from getting a shock.
Keep in mind that some parts of the system can get hot.  The arcs can be hot enough to to ignite paper and plastic, so operate it in a safe location.
High voltage discharges generate Ozone gas, which can cause irritation if breathed in.  High voltage discharges also generate some ultraviolet radiation, so limit your exposure and don't stare directly at the arcs.
First, enjoy some video!
Step 1Details
Details
An ignition coil produces a high voltage output on its secondary when the current flowing in the primary winding is interrupted. The first step in generating a high voltage from an ignition coil is to store energy in the inductance of the primary winding. That energy is then released, generating the high voltage output.
Energy is stored in the primary of the coil when current is flowing through it. This energy is provided by a DC power supply, usually the 12 volt battery of a vehicle’s electrical system.
The primary circuit is driven by closing a switch to ground, which allows current to flow from the power supply through the primary. When the switch is initially closed, the current in the coil remains zero, as the inductance of the primary does not allow the current to change instantaneously. The current in the primary then increases exponentially until it reaches its steady state value.
The steady state current is the maximum value the current will have. It is determined by the voltage of the power supply and the total series resistance of the primary circuit.
The steady state current in the primary is determined by:
I_steady_state = V_source/R_primary
Rprimary consists of the total resistance of the wire in the primary coil, as well as the resistance of the wires and other connections in the primary circuit.
The length of time needed for the current in the primary to reach its steady state value is determined by the time constant. The time constant is a parameter which is equal to the primary inductance (in Henries) divided by the primary resistance (in ohms), and so it has the units of seconds. In equations it is commonly represented with the Greek letter tau. A smaller time constant means that the current will increase more quickly.
The equation for the current in the inductor is:
i(t)=I_steady_state*(1-e^(-t/time_constant)
The graph shows how the current in the coil increases after the switch is closed. The graph expresses the current as the percentage of steady state value. Note that after 4 time constants have passed, the current is at about 98% of its steady state value, and the after 5 time constants, the current is at more than 99% of its steady state value.
The relevant equations for the primary circuit are summarized in a chart below.
Energy in the Primary Winding
The energy stored in an inductor is a function of its inductance and the current flowing through it. The equation for the energy stored in an inductor is:
Energy= ½ * L * I^2.
Refer again to the graph that shows the current and energy in the primary coil versus the time elapsed. Note that the longer the switch is closed, the less additional energy is stored in the primary inductance. After the first time constant, the energy stored is 38% of the maximum. After two time constants have elapsed, the total energy stored is 73%. After three time constants, the total energy stored is 90%. After four time constants, the total energy is 96%, and so on. After five time constants, the energy stored is essentially at 100% of the maximum possible value for the power supply voltage and primary resistance in the circuit.
Once the primary current has reached its steady state value, no additional energy can be stored in the primary of the coil. If the switch remains closed after this point, the energy from the source will simply be dissipated as heat in the resistance of the primary circuit. It therefore makes no sense to keep the switch closed longer than 4 or 5 time constants, as past that point the energy will simply be wasted.
26 comments
Mar 13, 2012. 12:14 AMmaixy says:
i wonder how much the value of the coil is ?
Nov 16, 2011. 8:46 AMhighvoltageguy says:
cool idea
Aug 28, 2011. 1:22 AMinfinity11 says:
How would I make this in a negative voltage
Jun 30, 2011. 7:40 PMVadimS says:
Well designed circuit. I've seen a few designs that are best describes as shabby.
Jul 3, 2011. 8:41 AMNoitoen says:
Back in the 1980, we use to build cdi ignitions for cars with points. They had a pot core harting oscillator transformer to charge the 2 0,47uF capacitors to around 400v and a thyristor to discharge it through the coil. The circuit was designed so that it kept the original coil, points and capacitor so that in the event of cdi ignition failure, you would just switch a couple of connector to return to normal. The original coil on a VW combi ran cooler and the points only needed ajustment due to mechanical wear and the ignition never failed.
Jul 9, 2011. 10:55 AMVadimS says:
I've built something similar for a tractor a few years ago. Made a vary noticeable difference in the idle and starting.
Jul 3, 2011. 11:54 AMskowerr says:
What would happen if I would connect a power audio amplifier (12V max) instead of the pulse generator... would I get a singing arch??
Jul 5, 2011. 10:45 PMskowerr says:
Thank you for your comprehensive answer :)
I asked because it is easier for me to get for free a ignition coil than a flyback.
One more question. What type of material should be used for the electrodes, so they would not melt after a couple of minutes of arc production?
Jul 3, 2011. 5:35 PMRickO5 says:
Fun idea, I may have to try that.
Jul 4, 2011. 11:44 AMtrewq7 says:
coll
Jul 4, 2011. 7:03 AMHoldOnTight says:
You have taken a complex subject and you have described all the information needed to produce one of the best Instructibles I've ever read. Great job and thanks for sharing!
Jul 3, 2011. 11:05 PMstackerjack says:
I was always of the opinion that the main reason for the capacitor across the contact points was to allow the current in the coil to collapse rapidly, thereby inducing a very high voltage for the spark.
Jul 3, 2011. 6:49 PMstatic says:
Well done. I have been threatening to use a GM HEI coil, with 555 to do something similar, for quite some time. I have an old function generator I could use for a signal. but I'd rather keep from HV.. The old tool ain't worth much, but it works. I ruin a 555, and associate components I'm not out of much
Jul 1, 2011. 12:03 AMEurober says:
A good explanation, but you have omitted to describe the purpose of the capacitor connected in parallel with the "points" in the typical automotive application.
The method I have used in the pasts is to drive che primary by discharging a 1 /uFcapacitor charged at 400V with a thyristor. With hi-voltage coils one can reach 60,000-70,000V without any damage to the coil.
Jul 1, 2011. 12:46 PMEurober says:
Yes, you are right on the capacitor, but it serves also an other purpose. The 1 μF capacitor, combined with the inductance of the system, creates a resonant circuit with a decaying AC voltage with a frequency in the region of 50KHz, if I remember correctly; facilitating in this way the transfer of energy to the sparkplugs. As a matter of fact, I would avoid using the over voltage clamping of the IGBT. The reason is that any current that is shunted to ground represents wasted energy. I would use a suitable capacitor instead. Because it is a reactive component, no energy will be wasted. I bet that at the secondary one would get a more "robust" spark. Please note that obviously the voltage at the IGBT will go negative also during the inductive kickback.
To achieve the 400V in the capacitive discharge method, I used the common voltage multiplicator circuit (Villard circuit and similar) to go from the typical household AC voltage line to the desired voltage, making the circuit quite simple..
Jul 2, 2011. 4:38 PMEurober says:
Funny, I posted an other answer and it has misteriously vanished.
For a confirmation of the purpose of the capacitor please read the following explanation from:
http://en.wikipedia.org/wiki/Ignition_system
(quote):....
At the same time, current exits the coil's primary winding and begins to charge up the capacitor ("condenser") that lies across the now-open breaker points. This capacitor and the coil’s primary windings form an oscillating LC circuit. This LC circuit produces a damped, oscillating current which bounces energy between the capacitor’s electric field and the ignition coil’s magnetic field. The oscillating current in the coil’s primary, which produces an oscillating magnetic field in the coil, extends the high voltage pulse at the output of the secondary windings. This high voltage thus continues beyond the time of the initial field collapse pulse. The oscillation continues until the circuit’s energy is consumed.
(end)
I personally designed, build and sold SCR ignition units in the early seventies.
One of the various occupations that help me to pay for my MSc EE.
The standard coil had no problem holding the voltage, because the spark at the sparkplugs acts as a voltage limiter. On the other hand, if one bench drives a standard coil with a large airgap, it is 100% certain that the standard coil will be damaged. As I said with a hi-voltage coil and a SCR unit, it is easy to achieve 60,000-70,000Volts
Jul 2, 2011. 12:10 AMEurober says:
For the sake of completeness I have to correct you. The capacitor is a fundamental part of the ignition system and without a car will not start.
I am afraid there are no misconceptions. In any case job well done.
(Quote)
(End of quote)
Jul 1, 2011. 5:27 AMtunes says:
I have built one of these using the 555 timer and I now see that a PIC based design allows a greater degree of fine tuning to get to the resonant frequency of the coil. This seems important as different ingnition coils have slightly different capabilities in their output with the same circuit and voltage parameters. Some have used two coils in parallel/antiparallel to achieve even higher output voltages and longer arcs.
I would love to try your PC based circuit but I currently have no way of programming a PIC and have only Macintosh laptops at my disposal. I suppose I could invest in a PIC programmer and borrow a PC to just load the files on to the PIC. There are other projects such as the Aurora 9x18 RGB LED art (PIC24F08KA101) that also use a PIC from Microchip. Could I just buy the Microchip's PICkit 3 In-Circuit Debugger/Programmer? Would this work with the files you provide here?? Or could you sell me a few programmed PICs? I could also buy a few PICs and fedex to you for programming, if you would be willing to help me.
Also, could you send me a BOM for the parts list?
OK to email direct: kuriloff@nyhni.org
Jul 1, 2011. 11:08 AMtunes says:
Thanks so much for your comments and the files.
Dan
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
29
Author:LargeMouthBass
No Homework? Then you will have to fight the bear!
