loading
Step 3: Pull the fuse and prepare the cable
CAUTION:
Before pulling the fuse and starting to work on the car’s electric components, be sure to turn the ignition fully off. It’s maybe best to just remove the key.
I didn’t have an 18AWG cable available, so I just used a speaker box twin cable.
  • Pull the fuse for the electric windows (fuse #3, verify fuse # in your car's manual)
  • Strip off the cable insulation for the spade connector
    (Drill the ends of the twin cable together if you use the wrong cables like I did)
  • Apply the spade connector
    (check that it's properly connected by lightly pulling at the cable)
  • For the following step, don’t connect the spade connector yet. It’s hard to remove once inserted:
    To get the proper length of the cable, hold the spade connector close to the lower pin in the fuse box for the electric windows and route the cable to one of the spare fuse spots to the left of the fuse box. Consider the extra length that is needed to connect the cable to the “foot” of the fuse.
    Cut off any excess cable.
  • Strip off the cable insulation for the spade terminal
  • Apply the spade terminal to the cable
  • Apply heat shrinking tube to both connectors to ensure electrical safety. You don’t want the bare metal to touch other metal parts or connectors once the cable is installed
    (This wouldn’t have been necessary for my spade connector due to it coming with insulation, but I wanted to make sure. The spade terminal will be located outside the fuse box once it’s installed, so ensure that the whole connector is isolated by the heat shrinking tube).
<p>Today I installed much like in this tutorial. About two hours work (I tried to be accurate). Well, I saved 25 Euro. Cool !</p>
I LIKE this! I was thinking of a more complicated method involving some kind of rewiring job, but this is elegant. Any issues so far with the mod?
I encountered once that I couldn't pull up the window while driving once, because I haven't fixed the cable to the fuse box with tape. <br>I think it may be ok, too, if I just use a terminal that's a little thicker (or may be to just bend it a little) to give it a tighter fit. <br>I just pulled to the side and wiggled on the cable. Ever since, all is well.
About This Instructable
11,333views
23favorites
License:
Bio: I rather like "to make" than "to consume". I've been programming for iOs for a while just to see if I can. I love ... More »
More by Mike73:Fake Halloween Tombstones Kids room remodel My first own iOS app - Gas By Numbers - a gas mileage calculator
Add instructable to:
