The revisions that I have made:
- Increased the height to approximately 20" from the top of the mattress to the floor
- Upholstered the headboard
- Painted the unfinished frame
- Added a custom made removable bed skirt
Level of Difficulty
I found this project to be very rewarding as it involves a few skills; Woodworking and sewing mainly. I have never really upholstered anything before, so it was very fun to work with new materials and experience new challenges. If i had to give this a rating, I would give it a 7 out of 10. That might drop a bit if you sew frequently and have a similar level of woodworking knowledge.
Cost
The total cost of the project is approximately $200 (not including the mattress)
Recommendation
I strongly recommend that you take on this project if you already have a RYKENE bed and you want to make it look a little more grown-up.
Warnings:
Please read and understand the owner's/safety manual of all your tools before using them. Some guards and safety devices were removed for the making of this instructable, I DO NOT recommend you remove any safety devices or guides from your tools. Safety comes first. Never put yourself in danger.
Note: I believe that this bed was previously named DALSELV
Remove these ads by
Signing UpStep 1: Materials
- 2"x4"x8' pine - [1 piece] $10 approx.
- 2.5" #8 screws - [12 pieces] $0.50
- Utility Shelf Brackets (3"x5" approx) [4 pieces] $2/each approx.
- Black Paint and Primer in One [less than 1 quart]
- Fabric for the skirt - $6 [3 meters]
- Fabric for the headboard - $8 [1.5 meters]
- 1/2" velcro, black - $15 [5 meters]
- Foam mattress pad, full/double size -$15 [1 piece] *thanks to jessandstavro for this tip
- Flat Bed Sheet - [1 piece] $8 I used this to cover the back of the headboard,
- Thread
- Chalk (Fabric Chalk is best, but I didn't have any and was able to do with regular chalk)
Visit Our Store »
Go Pro Today »
On the topic of painted wood, the paint didn't cover the wood grain because if you put paint straight onto wood, it tends to soak in, giving an effect more like dying than painting. If you want to avoid this you should use a primer, which gives an impermeable surface to the wood that your finish paint can sit on top of and not soak into the grain.
Thanks for sharing your primer tip!
