Illuminated Clock Using a Scroll Saw
10,721
41
9
Published
Introduction: Illuminated Clock Using a Scroll Saw
About: Alex Blechta is a young and enthusiastic graphic designer and photographer. Starting from such a young age he wants to learn and strive in his future dream of becoming a well-known graphic designer and or ph...
A very cool light up clock made by using a Scroll Saw.
Step 1: Materials/Tools
1 analog clock
1 large piece of plywood
Spray adhesive glue
Pencil
Scroll Saw or try the Dremel Trio
Styrofoam
Hot glue
Drill
Movable lamp
Step 2: Trace
Trace the outside of the clock on thin plywood.
Step 3: Cut
Cut with a scroll saw the outside of the clock.
Step 4: Glue
Use spray adhesive glue ( do not put too much on because you want to be able to take this off after if you put too much on wait a bit for some of it to dray and attach to the round piece of wood).
Step 5: Drilling and Cutting
Drill a hole at the end of each number. Put the round saw in through each hole and cut it out.
Step 6: Attach to Light
Put it all together with the clock movment the clear plastic piece and the frame.
Step 7: Your Done Have Fun!
    • Make it Move Contest
    • Casting Contest
      Casting Contest
    • Oil Contest
      Oil Contest
    9 Comments
    Im not really sure, sorry but its a round one, im pretty sure any one would do.
    there should be some way to make the hour light up only.
    Yup I have a way and if you want me to make it just ask what I could do is add a flat piece of tin cut a hole in it and have it move with the time movement. so that the hour is the only one moving. Don't forget to vote I put lots of hard work into this.
    I like the idea, but i think there should be light up hands too somehow.
    Yea i am going to paint glow inm the dark pint on them so you can see them.
    That is pretty cool. nice idea. ... do you have to worry about the light behind the clock getting too hot?
    I am also thinking of putting glow in the dark paint on the hands so you can see them too.
    No you could use LED or CFL light bulb
