3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Illuminated Keyboard Hack
Turn your ordinary keyboard into an illuminated one for under $5. This is an easy keyboard mod that takes about 1/2 hour to do. Watch the video to see the test results and then follow the Instructable for more details. Enjoy!
Step 1What You Need...
What You Need...
1. A Keyboard. Any keyboard will work.
2. 2 LED's. I used 5mm High-Brightness White LED (2-Pack) $1.99
Radio Shack # 276-017
3. Telephone wire. This needs to be solid core wire.
4. Heatshrink tubing. I had some in my parts bin.
5. Soldering iron and solder.
6. Wire strippers and snips.
7. Drill and small drill bit.
88 comments
1-40 of 88next »
May 31, 2008. 5:39 PMworleyll says:
Instead of putting the lights on top, drill the holes in the back an during the day, fold them down
Feb 29, 2012. 12:06 PManghellix says:
I like your idea. I was thinking more on the sides like wi-fi router antennae.
Thanks Kipkay, for contributing this simple and effective instructable.
Nov 28, 2011. 7:55 PMMaxaxle says:
Cool idea, though I seriously doubt I'll ever need to use my computer in the dark.
May 30, 2008. 12:50 PMBartboy says:
cool! one problem, if u have the light on and dont want scroll lock on.
Feb 12, 2011. 12:09 PMxc1024 says:
I use scroll lock a lot, every day. I've assigned it to show and hide a scroll-down terminal (Linux).
Aug 8, 2008. 1:55 PMcormac3050 says:
ummm...... what does scroll lock do????
Aug 10, 2008. 9:43 PMREA says:
Wiki entry: "Scroll lock is a key (often with an associated status light) on most modern computer keyboards. The behavior of the key depends on the particular software in use. The scroll lock key is a remnant from the original IBM PC keyboard. In the original design, scroll lock was intended to modify the behavior of the arrow keys. When the scroll lock mode was on, the arrow keys would scroll the contents of a text window instead of moving the cursor. In this usage, scroll lock is a modifier key like Alt and Shift (which modify the function of other keys) and, more specifically, a toggling lock key like Num Lock or Caps Lock, which have a state that persists after the key is released. Today, this particular use of scroll lock is rare. Only a few modern programs still honor this behavior, such as Microsoft Excel (in the behavior of arrows — when scroll lock is on, the selection does not move), Lotus Notes and Forté Agent. In modern GUI environments, scrolling is usually accomplished using means such as scrollbars or scroll wheels. Therefore scroll lock can be regarded as a defunct feature in almost all modern programs and operating systems; some keyboards lack scroll lock altogether. Scroll lock has fallen into such extremely infrequent use that some of the lighter-weight Linux desktop environments don't even support it at all, such as Xfce."
May 31, 2008. 1:01 PMXial says:
It's used in FL Studio, actually, to control scrolling of a play area. Because of that, I would have to use my NumLock light instead of the Scroll Lock, since I always have NumLock on at night. :)
May 31, 2008. 11:52 AMYerboogieman says:
Whats does scroll lock do? Also, what voltage are the LED's?
Aug 10, 2008. 9:49 PMREA says:
scroll lock alows you to scroll through a long page using the arrow keys. it was a handy tool during the DOS era.
May 31, 2008. 7:06 PMAT says:
Not much! But it is used in a few applications. If you go way back, it was common to use it in a spreadsheet program (Lotus 123 or Excel) to move the spreadsheet around without moving out of the cell with focus. Try it next time you are in Excel. Turn on Scroll Lock and use the arrow keys and the whole spreadsheet will move but the cell with focus will keep focus.
May 30, 2008. 3:28 PMBartboy says:
Yeah, you're right, but surely it does something? Maybe?
May 30, 2008. 8:22 PMCameronSS says:
Nov 13, 2010. 12:47 PMJames Longpaw says:
I would use my scroll lock but I figured out that my mouse changes profiles every time that I press it. so I think I'll just use the useless f-lock key.
Aug 15, 2010. 7:08 PMthe_burrito_master says:
Nice work,I love that keyboard all these newage ones stink. I'm going to do this to my netbook (when I get it after thanksgiving) but with blue :D
Oct 1, 2009. 2:11 AMeyerobot says:
Iv'e been trying to think of a better way to illuminate my keyboard, Than by using a scanner bulb, And this is exactly what I needed. Thank you.
Sep 21, 2009. 12:36 AMDrCoolSanta says:
Awesome hack, I loved this. Gonna do this soon
Mar 17, 2009. 11:07 AMMr. Squishy says:
Newer Mac laptops coome with illuminated keyboards. But how do you do this with laptops with non-illuminated keyboards?
Jun 24, 2009. 7:00 AMsoldier_fever says:
You could connect 2 LED's with a USB but you'll need a USB port aviable. If you won't some extra information just send me a message :)
May 23, 2009. 5:47 AMdowd95 says:
Great instructable...about to go make mine
Dec 18, 2008. 12:26 PMsteimel386 says:
I'm going to give this a try but instead of on top of the keyboard I'll see if there is enough room under/around the keys to give it a more stock look. ... I wonder if I could use spacers or something to produce more room under the keys
Nov 29, 2008. 1:09 PMMillawi Legend says:
cool what lse u can do is take the front of a key board a its like touch screen
Nov 25, 2008. 12:25 PMagis68 says:
Excellent instructable, Nice Job and CLEVER!!! 5/5
Nov 25, 2008. 11:35 AMBerkin says:
Can anybody tell me what the backwards "R" and the "U"connected together mean? I see that symbol on almost all circuit boards and electronics I have.
Nov 19, 2008. 1:10 PMstringstretcher says:
Mine works! Took 15 minutes, super big, blue LEDs and they look GREAT. Thanks for sharing!
Oct 28, 2008. 5:28 PMj2020j0908 says:
Sorry for posting an irrelevant comment but I think you'll find my question interesting none the less... Doesn't he sound just like Christian Bale from the movie American Psycho? LOL
Oct 26, 2008. 4:41 PMIW5 Industries says:
awsome
Oct 13, 2008. 12:59 PMctoon6 says:
i bet you could try just putting the LEDs in the keyboard instead of looping up like that
Oct 12, 2008. 10:41 PMnitrox027 says:
I used blue leds because when playing games there less distracting and i used paperclips instead of the wires because they are nice and clean and kind of modern looking
Aug 31, 2008. 3:46 AMDerin says:
Interesting idea,detailed instructable.Good job Kipkay!
Aug 14, 2008. 2:30 AMfriedfish1982 says:
I guess i would try it if i didn't already own a Logitech g15 gaming keyboard. But i bet you spent allot less money then i did.
Aug 14, 2008. 2:03 AMRikasu says:
You're my hero. You're the reason I joined this site (and all the cool stuff.)Only one word can describe you: Brilliant. One day I hope to be as creative as you.
Jun 1, 2008. 10:39 PMcool! says:
Great idea. Another cool thing would be to iluminate a clear keyboard from the inside.
Jun 9, 2008. 8:31 AMdashman94 says:
It would be great if someone could find a way to wire each (or just maybe a few) specific key to where whenever you pressthat individual key it lights up, how all the wiring would still fit inside the clear keyboard, I have no idea.
Jul 16, 2008. 7:38 AMRedgerr says:
lol that would be sick, but i doubt we have the technology to do that, unless the keaboard was like 2ft deep lol
Aug 8, 2008. 12:31 PMJoe Martin says:
Thats very easy to do the only problem would be getting the legs of the led to stick the the silly "ciruct board printed on cling film" thing they use in keyboards. Thinking about this in my head it would be very easy as theres plenty of room inside each keycap for an led, I'll just have to look out for a clear keyboard at a boot sale soon. P.S Sorry would upload the pictures of my lit keyboard but my card reader is playing up!
Aug 12, 2008. 4:58 PMRedgerr says:
lol ya, i have a keabord that lights up from underneath.. i was just talking about when you press it it lights up :O now that i think about it it could aswell :O welp, lol thanks :)
1-40 of 88next »
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
2397
Author:Kipkay(Kipkay Videos)
Tinkerer, hackster and prankster. Hit me up on Facebook: http://www.facebook.com/kipkayvideos/ Thanks for checking out my Instructables!
