Well, as often happens in my brain, complexity increased at a geometric rate and I came up with this mother-of-all-poster frames. It is illuminated using 28 super-bright white LEDs, mounted along both lengths of the frame. It is activated using a capacitive touch sensor. It uses surface mount technology. And best of all, you can activate a subliminal message from the Serenity movie that *could* cause you to flip out and beat everyone in the room to a pulp.
Interested? It's your lucky day! I will teach you how to make one. You can use any poster you like, but this Instructable is based heavily on the "Miranda" poster from the set.
EDIT: Please vote for me in the Epilog Contest! Why? Because if I win, I will be donating the laser cutter to the fledgling Maker group starting up in my city. It would go a long way towards our goal of a Maker/Hacker space in Waterloo!
Remove these ads by
Signing UpStep 1Materials and Tools
MATERIALS
From the Hardware Store:
- Three sheets of acrylic, Lexan or polycarbonate sheet, at least 2.5mm thick. Two should be the same dimensions as the poster, and one should be 2 inches larger in each dimension.
- aluminum duct tape (the stuff that is actually made of aluminum) - make sure it's shiny on the adhesive side, too!
- regular grey duct tape
- electrician's tape (any colour - I used yellow to match the yellow of the poster)
- masking tape
- four machine screws with matching washers and nuts
- epoxy or other glue that adheres to plastic and dries optically transparent
From Digikey or eBay:
- 34 3mm or 5mm bright white LEDs
- 14 3mm or 5mm bright red LEDs
From Digikey:
- 2 QT100A touch sensor ICs (427-1135-1-ND)
- 1 D-type flip flop IC (296-9851-1-ND)
- 1 5V regulator IC (497-1171-1-ND)
- 2 N-channel logic-level MOSFETs (ZXMN6A07ZCT-ND)
- 1 inverting buffer (296-8483-1-ND)
- 8 68 ohm resistors (regular 1/4W through-hole type)
- 3 150 ohm resistors (regular 1/4W through-hole type)
- 4 51 ohm resistors (regular 1/4W through-hole type)
- 2 100k surface mount resistors (RHM100KECT-ND)
- 1 1k surface mount resistor (RHM1KECT-ND)
- 4 10 ohm surface mount resistors (RHM10ECT-ND)
- 2 10nF surface mount capacitors (311-1173-1-ND) ******** depends on sensor!
- 2 100nF surface mount capacitors (311-1179-1-ND)
- 2 10uF tantalum surface mount capacitors (718-1044-1-ND)
From Mouser:
- 1 "SchmartBoard" Discrete #2 protoboard (872-202-0035-01) (or you can make your own PCB)
From... Somewhere...
- 1 12V AC/DC adapter
- 1 socket to match the plug on the adapter
- assorted wire (I suggest 26 AWG stranded wire with Teflon insulation)
- solder
- solder flux
- Kapton tape (or masking tape in a pinch)
TOOLS
- A table saw or band saw (for cutting plastic panels)
- A drill press
- An oscillating palm sander
- A belt sander
- A Dremel tool with engraving bit, or an engraver (or better still, a laser engraver!)
- a metric ruler
- a nice precision soldering iron
- other assorted hand tools, as needed
Oh, also, would having a little extra thickness on the sheets help, I just want to make sure the led's stay flush in their slots, and also, I think I might get slightly better refraction for the backlight with a thicker sheet, so I might go up a size for the back-most pane.
Thanks so much for your help jell...I mean jeff-o ;)
http://www.atmel.com/dyn/resources/prod_documents/doc10620.pdf
But, I would suggest the following numbers. Get both and see what works. Each has a minimum quantity of 10, that'll be plenty!
399-1237-1-ND (10nF X7R, 1206 size ceramic)
478-3790-1-ND (33nF X7R, 1206 size ceramic)
P4923-ND CAP CERAMIC MONO .1UF 50V 10% (this is the one that make's it very sensitive..not sure what .1UF means)
445-2883-ND CAP CER 47UF 6.3V Y5V RAD (this one didn't seem to do much)
Seems like the CAP's with legs would work better for my demo board because of the solder points on the board.
Here's the Eval Board I got:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=2622557&k=E100S
Any input appreciated!
thanks
