3 Simple Ways to
Share What You Make
PhotosPhotos
Step by StepStep-By-Step
VideoVideo
Illuminated Touchscreen Poster Frame with Subliminal Message!
  • last photo ←
Ever since Think Geek first posted a set of five Serenity/Firefly-inspired "travel" posters, I knew I had to have a set of my own. A few weeks ago I finally got them, but was faced with a dilemma: how to mount them on my wall? How to do them justice?
Well, as often happens in my brain, complexity increased at a geometric rate and I came up with this mother-of-all-poster frames. It is illuminated using 28 super-bright white LEDs, mounted along both lengths of the frame. It is activated using a capacitive touch sensor. It uses surface mount technology. And best of all, you can activate a subliminal message from the Serenity movie that *could* cause you to flip out and beat everyone in the room to a pulp.
Interested? It's your lucky day! I will teach you how to make one. You can use any poster you like, but this Instructable is based heavily on the "Miranda" poster from the set.
EDIT: Please vote for me in the Epilog Contest! Why? Because if I win, I will be donating the laser cutter to the fledgling Maker group starting up in my city. It would go a long way towards our goal of a Maker/Hacker space in Waterloo!
Step 1Materials and Tools
Materials and Tools
I tried to keep this project as Green as possible. First off, by illuminating the poster using LEDs instead of fluorescent light, I'm avoiding the use of all the toxic chemicals that go into making fluorescent tubes and ballasts. LEDs also consume less power. All of the components purchased at Digikey and Mouser are ROHS-compliant. I used lead-free solder. Lastly, the polycarbonate plastic sheets I used were scraps purchased from a second hand store - much cheaper!
MATERIALS
From the Hardware Store:
- Three sheets of acrylic, Lexan or polycarbonate sheet, at least 2.5mm thick. Two should be the same dimensions as the poster, and one should be 2 inches larger in each dimension.
- aluminum duct tape (the stuff that is actually made of aluminum) - make sure it's shiny on the adhesive side, too!
- regular grey duct tape
- electrician's tape (any colour - I used yellow to match the yellow of the poster)
- masking tape
- four machine screws with matching washers and nuts
- epoxy or other glue that adheres to plastic and dries optically transparent
From Digikey or eBay:
- 34 3mm or 5mm bright white LEDs
- 14 3mm or 5mm bright red LEDs
From Digikey:
- 2 QT100A touch sensor ICs (427-1135-1-ND)
- 1 D-type flip flop IC (296-9851-1-ND)
- 1 5V regulator IC (497-1171-1-ND)
- 2 N-channel logic-level MOSFETs (ZXMN6A07ZCT-ND)
- 1 inverting buffer (296-8483-1-ND)
- 8 68 ohm resistors (regular 1/4W through-hole type)
- 3 150 ohm resistors (regular 1/4W through-hole type)
- 4 51 ohm resistors (regular 1/4W through-hole type)
- 2 100k surface mount resistors (RHM100KECT-ND)
- 1 1k surface mount resistor (RHM1KECT-ND)
- 4 10 ohm surface mount resistors (RHM10ECT-ND)
- 2 10nF surface mount capacitors (311-1173-1-ND) ******** depends on sensor!
- 2 100nF surface mount capacitors (311-1179-1-ND)
- 2 10uF tantalum surface mount capacitors (718-1044-1-ND)
From Mouser:
- 1 "SchmartBoard" Discrete #2 protoboard (872-202-0035-01) (or you can make your own PCB)
From... Somewhere...
- 1 12V AC/DC adapter
- 1 socket to match the plug on the adapter
- assorted wire (I suggest 26 AWG stranded wire with Teflon insulation)
- solder
- solder flux
- Kapton tape (or masking tape in a pinch)
TOOLS
- A table saw or band saw (for cutting plastic panels)
- A drill press
- An oscillating palm sander
- A belt sander
- A Dremel tool with engraving bit, or an engraver (or better still, a laser engraver!)
- a metric ruler
- a nice precision soldering iron
- other assorted hand tools, as needed
40 comments
Aug 4, 2010. 12:11 AMBATMANG says:
This is fantastic! From one Firefly/Serenity fan to another: great job! I am definitely going to try this once I round up some funds. (I might end up just using the same poster and image as you, just because I like it so darn much!) Where do you think I could get the polycarbonate sheets? I looked and the most readily available ones are from Lowes or Home Depot, but they are sold in weird sizes and undesirable thicknesses. Also, how long did it take you to make this?
Jan 11, 2010. 9:16 AMmneufeld623 says:
 Do you mind if I ask your approximate cost of materials?
Jan 11, 2010. 1:26 PMmneufeld623 says:
 Thanks, I found some online sellers that had the polycarb at about 15 bucks a sheet, but i'm going to look around and find some scrap/surplus since i don't mind cutting it all myself.
Oh, also, would having a little extra thickness on the sheets help, I just want to make sure the led's stay flush in their slots, and also, I think I might get slightly better refraction for the backlight with a thicker sheet, so I might go up a size for the back-most pane.
Sep 1, 2009. 2:42 AMsuperjames says:
Cool! I'm doing something very similar but using the QPROX 100a demo board from digi key (uses the same touch sensor as your project). I'm having some problems with getting the electrode to obey the touch. Sometimes it doesn't sense my touch, and sometimes it fires off without even touching the sensor!? I am completely new to this so I have no idea what the problem is. I am using a 100uf capacitor...and it makes the touch very sensitive. I can't figure out what's making it misfire. Any help apprecaited. Thanks!
Sep 1, 2009. 3:54 PMsuperjames says:
You know it may not be 100...it's been a while since i was playing with it. But it's going through 1/4" glass, so it needs some sensitivity ;) The electrode is taped to the glass...is it possible that the glass has some grounding?? Also, i don't the the wire is shielded, could this be the issue? thanks alot for your help!
Sep 2, 2009. 12:08 AMsuperjames says:
okay thanks alot. your wire is way longer than an inch though isn't it? i need 8" of wire between the board and the electrode (a 3" diameter) because the board can't be mounted to the glass. any ideas? thanks again.
Sep 2, 2009. 12:23 PMsuperjames says:
thanks! gonna see what I can do :) Gotta order a couple new caps...which one's should I order to try out?
Thanks so much for your help jell...I mean jeff-o ;)
Sep 2, 2009. 5:04 PMsuperjames says:
Huh, those are way different than what I got...those look like blocks compared to my ones with legs. Here's the one's I got, perhps this will give you an idea of what's possibly wrong with my setup:
P4923-ND CAP CERAMIC MONO .1UF 50V 10% (this is the one that make's it very sensitive..not sure what .1UF means)
445-2883-ND CAP CER 47UF 6.3V Y5V RAD (this one didn't seem to do much)
Seems like the CAP's with legs would work better for my demo board because of the solder points on the board.
Here's the Eval Board I got:
http://search.digikey.com/scripts/DkSearch/dksus.dll?Cat=2622557&k=E100S
Any input appreciated!
thanks
Sep 2, 2009. 11:46 PMsuperjames says:
can those 399-1237-1-ND fit onto those pads from the demo board? maybe the ones with legs are not correct. so do i just have to solder it to a single pad? cuz i have the each leg stretching across the pads. as you know, i have no idea what I'm doing! haha
Sep 3, 2009. 12:52 PMsuperjames says:
ah good idea bout the bend :) if i don't attach one at all, i get no response through the glass
Sep 3, 2009. 2:39 PMsuperjames says:
ah interesting. i gotta find some double sided adhesive film, that will work well. i'm still a bit concerned about the mis-fires though. gonna order those other capacitors. thanks for the tip
Sep 2, 2009. 7:36 PMsuperjames says:
Thanks so much for your help. Gonna order them now :) If I have problems, I'll track you down...haha j/k. cya
Sep 2, 2009. 2:32 PMsuperjames says:
Awesome, thanks!
Apr 22, 2009. 7:00 AMdenanderen says:
this is one great instructable! i'm definitely going to make one of these (with a few adjustments) but i think you can reduce the chances of the plastic breaking because of the screw by just using a washer. (at least i think i'm going to use one) but still a very nice design in which you obviously put a lot of effort.
Apr 20, 2009. 8:05 AMGenerik99 says:
Hehe damn that's pretty cool :) May have to work on some of these posters.
Apr 18, 2009. 2:35 PMjolshefsky says:
That's really clever. I like it a lot.
Mar 24, 2009. 9:35 PMalex-sharetskiy says:
pretty legit how does the capacitive sensor work? what is it attached to?
Mar 26, 2009. 6:33 PMaaron2a says:
could you change how close someone has to be to activate it
Mar 25, 2009. 9:38 AMthinkgeekmonkeys says:
I watched your videos ... and for some reason I feel like eating people alive. And maybe making clothing out skin? Hmm. That's odd.
Mar 25, 2009. 10:12 AMthinkgeekmonkeys says:
Awwrgh gawwrgh arggh!!!!!!
Mar 24, 2009. 11:33 PMtechnoplastique says:
The finished effect is fantastic. These would be so perfect in a home theater kind of room - so much better than anything that 'home theater companies' come up with. Great job.
Pro
Get More Out of Instructables
Already have an Account?
close
All Steps Viewing
Upgrade to Pro today!
347
Author:jeff-o
By day, Jeff is an electronics technologist at a large aeronautics corporation. By night, a mad scientist / hacker / artist / industrial designer wannabe!
